Offline full-bridge SMPS… need help
file upload
The zip file is jzip but can be opened with most all programs,I tried to upload the pdf files for the models and simulation but exceeded zip file size,so you should refer to these appnotes AND8255 and AND8311.If you have LTspice,unzip file to your folder of choice,all models and .lib are included .The sim should run with little problem if any.
This simulates a 240watt llc conveter(24VDC@10amps) and by changing the load you can see the effects in major components of conveter.All comments welcome.The models are Mr.Christophe Basso's and I only converted the appnotes to LTspice format.
If you have comments or questions please post so all can read,please no PM's.
i have req. 24v\25amp smps supply for batt charger. pl help me because i am new for smps supply .[req. ckt + tx winding ditails etc. }
Can someone tell me 2 tranzistors that have sot23 pakidge and a colector current bigger than 5A , for a totem pole that drives IGBT tranzistors , i heave searched over the internet and the maximum colector curent was 800ma...
ravslanka:
Note that diode near 7812 is turned the wrong way on silkscreen
I would also leave about 3mm or more gap between primary and secondary (under the trafo). Primary tracks do not need to be that wide
Also think about primary and secondary snubbers, they can be pretty big (take a lot of space, depends on trafo itself, how good it is)
apart ftom that, it looks ok I think. Btw, take out those big caps, they are not good for this kind of supply, you need small output capacitance, that means small capacitors, but with low internal resistance, if possible to get. If not, more standard ones in parallel
Krisfr:You need core for what, where in the circuit?
This is a site I found on another thread in DIYA
Products : CWS ByteMark, largest supplier of toroids, ferrite cores, iron powder cores, MPP cores and RF cores
I see I have a lot to learn...
The input filter for the schematic I have shows a 2X10tur-1mm
From reading and viewing the above site information on the products they offer, I need a IRON core for the input filter inductor.
And a Molypermalloy toroidal core for the output of the ETD-49
The schematic says 2X20t-2mm for this inductor before the capacitors and after the Bridge rectifier...
I just want to buy some cores that I can wire up to make the design work. Chas1 gave me the design on this or the new thread, it is called acdc converter by X-Fi and has about the output I want at plus and minus 70V. Here it is...http://www.diyaudio.com/forums/powe...ull-bridge-smps-need-help-97.html#post2329039
I am redoing the pcb layout and I will post a picture soon of my layout.
I am still reading and trying to avoid as many mistakes as I can before committing to etching a board. Time is my friend here. I have some.
Thanks for your time and help, I appreciate BOTH..
THANKS
