900W H-class PA Amp with Limiter
hi
hello sir
can i use this pcb is that ok ?????
thanx......
hi
I don't know, it's not my pcb design, I must build and test before suggest anything to you, but I haven't time, and I not use this schematics in my new products. If you want improvements on B500 and H900 it's on you or other peoples to do this, I can help with my expirience and advice.
hello sir
i want to add some more pairs in h900....
i want a pcb layout .....
can u pls tel me how can i make pcb lay out....
thanx...
hello sir
thanx...
You don't need add more pairs in H900, it's powerfull enough. Makeing pcb design is not that simple, but if you want add some more pairs, make pcb only for 4 more pairs and paralleling it with H900 pcb, it's simpliest way.
