hello sir
how can get more power from h900 .??????
what changes have to make ...
thanx....
Increase the rail voltage and add more devices at output stage is logical approach in simple manner.
hi
hello sir
how much power i can get on 2ohm lord vd h900 .??????
thanx sir.....
How much power do you want ?
With 2 step class-h with 1943/5200 pairs you cant increase your rails beyond 70VDC per step. Around 3.5kW could be manageable with 14-16 pairs at output for continuous duty cycle operation into 2 ohms.
hello sir
thanx sir.....
workhorse,
140-70-0-70-140dc
14-16 pairs
around 3.5kw
is this possible using TLO step driver with b500?
You need to use other types of drivers which are fast.
hello sir
thanx sir.....
I have already answered you
workhorse,You need to use other types of drivers which are fast.
if i use mje15034/35
instead of mje15032/33
will it improve?
apex,and any replacement for bav21 ?????
IN4937 1a 600v fast recovery diode
can this replace bav21?
workhorse,
will it improve?
Both are same except voltage difference.
workhose did you mean the gate driver?
Yes
Recovery time of 1N4937 is 200ns, and BAV21 have 50ns, MUR120 have 50ns and you can find lots of similar fast recovery diode.
apex,
sorry i repeat the question
hi apexaudio
greetings can UF4OO4 ULTRA FAST be used instead of HER 154 DIODES also have BYW 80 can it be used.Every thing is completed pcb only
diodes have to be put
1 CAN it be tested with 70 0 70 dc voltage rails in class AB MODE
thankng you
andrew lebon
You can use this diodes and test with +/-70V DC in class AB, sound will be same only increase rail voltage and class H will increase power and eficiency.
- 900W H-class PA Amp with Limiter
