900W H-class PA Amp with Limiter
How much power do you want ?
With 2 step class-h with 1943/5200 pairs you cant increase your rails beyond 70VDC per step. Around 3.5kW could be manageable with 14-16 pairs at output for continuous duty cycle operation into 2 ohms.😉
hi apexaudio
greetings can UF4OO4 ULTRA FAST be used instead of HER 154 DIODES also have BYW 80 can it be used.Every thing is completed pcb only
diodes have to be put
1 CAN it be tested with 70 0 70 dc voltage rails in class AB MODE
thankng you
andrew lebon
hi apexaudio
thankng you
andrew lebon
You can use this diodes and test with +/-70V DC in class AB, sound will be same only increase rail voltage and class H will increase power and eficiency.
