Switch on delay???
Hello Apex.....
And the switch on delay.....do you still need it?
Macd
Speaker Terminal can be add to any amp with rail voltage over +/-36V DC and rail fuses. I prefer this protect more than protect with relay.
Hello Apex.....
Macd
Hello Apex.....
Macd
Switch on delay can be done with MUTE circuit on amp input with fet. Schematic you can find in thread http://www.diyaudio.com/forums/solid-state/167363-mic-line-eq-preamps-4.html post #35
Turn on/off mute input circuit, without relay at the amp output.
Re
Hi Apex,
how does this circuit work? 😱😱😱 What does this do? If I have this on the input, I don't need a switch on delay circuit. Is this correct? Any progress on Studio Reference PCB?
Macd;🙄🙄🙄
Hi Apex,
Macd;🙄🙄🙄
Hi Apex,
Macd;🙄🙄🙄
Fet short circuit amp input to GND and mute singnal when amp switch off, and umute with delay when amp switch on. DIY version of 'Studio Reference Amp' PCB will be share soon.
Re
Thanks😀😀😀
Thanks😀😀😀
Thanks😀😀😀
Thank You, real diyers like you is the reason for shareing
Found this circuit and i tried it on vector board. Giving good sound.. Can you help me out what cound be the wattage and any thing to be improvide.
Sorry Wrong file attachend. This is the corredt component layout.
MOSFET are face down.
Go to posts #202 and #345, and you can see different for MOSFET and BJT output stages with same topology.
You still have erors on your schematic, I suggest you: do not improve anything, just keep it simple (looks like 'CITATION 12' http://cygnus.ipal.org/mirror/www.passlabs.com/images/citation.pdf). Change some values to make it work correct. You can get over 50W from your amp.
Thank you sir for your kind reply..
Can you suggest which amp is better for 28v +- supply and 4 ohms load, the above or TDA7294 or some thing else with better sound quality.
I suggest you LM3886.
http://www.diyaudio.com/forums/chip-amps/162099-lm3886-schematics-pcb.html
Amplifier with TDA7294 (stereo+PSU) you can find in thread:
http://www.diyaudio.com/forums/chip-amps/162179-tda7294-stereo-bridge-psu.html
- 100W Ultimate Fidelity Amplifier
