hi coolet
greetings since you are a pcb expert can a pcb software make a
pcb from the schematic have KICAD SOFTWARE using schematic capture
editor is it possible
thanking you
andrew lebon
yes orcad is capable from schematic to layout. but this is well done in digital circuit. for audio it is much better to use manual routing. i don't know about kicad i never use that software.
Apex,
I've made another PCB layout for the power supply unit. It's biiger than yours, and most people will certainly use yours because of size, but I prefer a more symetrical layout, and with larger tracks, for heavy current capability.
I also made provision for TO-220 diodes (I love the MUR series). You can use MUR1560. I also installed snubber capacitors in parallel with the rectifier diodes.
View attachment Apex Regulated PSU - Nabuco Layout.pdf
Apex,
That is nice profesional pcb, and I'm not sure for: 'most people will certainly use yours because of size', I first will use your pcb🙂
Regards and thank's for share.
Thank you Apex! I'm happy to help, as you helped us with your very nice circuits!
I suggest you to use three pins dual diode MUR1640CT or BYV42 becouse mehanical reason. Pins are to thin, and two pins can be easy broken with three pins that's not hapen.
Very good job Apex!
I´m using Diptrace for PCB design. A very good software even in its free version.
Very good job Apex!
Do you mean 'good job Coolet' or 'good job Mitchel' for pcb designs?
I mean good job for you regarding the amp.
regards,
Thank's, if you think this amp is valuable for diyers🙂
That is how long DIY should last. 🙂Regulated PSU 30years old with MJ15003/15004.
OS
OS
...and how 'new schematics' are old 😉
Mile Hi!
With which voltage is supplied Audio Amplifier APEX SR50?😡
Greeting,
PSU for SR50: +/-45V DC rail voltage.
Mile, and can be eaten with a + /-38V for 4oma load on exhibit?🙄😕
Regards,..
Regards,..
Yes +/-38V DC rail voltage for SR50 will be OK useing 4 or 8 oma load.
- Studio Reference Amplifier
