Simplistic NJFET RIAA
diyAudio Chief Moderator
Joined 2002
You can either use the 180R as it is and run the leds lower current, or delete it and put a 3k3 1W between B+ and the Led's Jfet to run them higher current. In any case you should test and match them with the jfet of choice feeding them with an 180R or without (fet g&s) if you are to use the 3k3. I would choose the configuration that takes me nearer to the voltage I seek with the particular leds. You use the trimmed down Idss already in your current build.
For balanced I want to use this schematic gain 60dBs:
How many volts
Merlin,
you have ignored Salas' advice and deleted R17 without doing anything else.
Why bother asking questions when you don't implement the recommendations?
What voltage, I cannot read your tiny sketch.
Crop it and repost at a sensible/legible size.
Joined 2009
Merlin,
You don't understand nothing, I'm not implemented nothing, just starting to measure the voltage LEDs string to matched them for 4 channels balanced NJFET RIAA using the last posted schematic.
First to do a bad answer read all posts & you can know that I asked to measure with mine bench psu because I don't have any 9V battery to match the leds, after I asked the current needed to fix mine bench & later I posted the schematic I want to use & I asked how many volts must measure the LEDs string in mine schematic?
Joined 2002
Merlin just do that circuit. Test it with the specific jfets & specific leds or mix 3+diode on a breadboard. Try red leds if you have, first. Use 20V for testing without a 3k3 or 45V with a 3k3. After matched, just copy it in the final builds.
Joined 2009
Now measure 6.04V, it's corrected for the schematic I want to use?
sorry crossed your post with mine post
Joined 2009
BC550C Idss
@Salas
Wich will be the best Idss value for Q3 BC550C?
I have following Idss:
535
536
558
559
562
563
564
565
566
568
574
575
576
578
579
580
584
588
589
591
598
602
603
606
609
611
616
617
618
624
625
641
642
648
652
656
658
660
669
670
678
680
685
686
I need 4 transistors for 4 channels
