if a pair of interconnects can change the sound of a system, then why wouldnt these things make a difference, what ever they are? They have impeadance, then they probably have a sonic signature. All this rf stuff and super/semi conductor stuff may be a red hearing and its just a simple RC or RL circuit?
If so, that will show up in very basic measurements.
I had a pair of 'speaker" Bybees on loan, and they did a very little "something" to the sound, but I could never tell if it was an improvement or not.
So I measured them on my General Radio 5 digit LCR bridge, no hint of inductance, no hint of capcitance, very very small amount of resistance - like a piece of wire.
Very interested in SY's measurements, if he has access to a better bridge.
Regards, Allen
Audio Consulting Switzerland was where I first spotted Bybee's, many years ago
And I believe Modwright used them extencively
That was before he designed his own amps
I havent seen any of above even mention Bybee's for several years, or anyone else
Hi John,
Figures. That would be difficult to measure in that case.
-Chris 🙂
Are you saying there may not be a main element??You can damage them by overheating the main element, (if any).
-Chris 🙂
Regards, Allen
thanks Allen, thats interesting. Wonder what these things are?
Audio Consulting Switzerland explained them very detailed, and with pictures of internals
from my poor memory it may have been something with ceramic and carbon
I tell you what. You can give all the money collected so far to me and I'll give you a resistor to measure for shot noise!
On one hand I can see why some of the posters on this thread have donated funds to this cause - to put this ** to and end once and for all; on the other hand, shame on you all for getting suckered into this!
Should I use a smaller torch than normal?
You can prob'ly put that oxy-acetylene rig away 🙂
Flame on!
That might possibly be worse. Best to get on and off the joint as quickly as possible.
se
Hi John,
-Chris 🙂
This Bybee guy is a genius with a flare for comedy. He doesn't mess around here with a product that actually functions instead of other normal things with certain easily expected levels of performance. He makes a thing, out of secret stuff, that does secret stuff, and even got people that can measure darned near anything measurable to buy one just so they can. You have to admit it's funny! I'm also looking forward to the actual results.
Possibly that's all there is. I've admitted my expectation- that it's performance art. But there's lots of things beyond an LCR bridge- I'm surprised you didn't stick one in your preamp and check the effect on distortion and noise.
Are you planning on starting measurments or some other tests before "disrupting" the insulation/coating any further? Because I readily admit I'd have had an Exacto blade on that thing in minutes.
I'll strip enough of the dip vinyl off the leads to solder, but won't otherwise molest them until others have had their crack (so to speak) at them. If Cal wants me to check what the ceramic contents are afterward, well, that's why God invented atomic absorption analyzers. 😀
Now let's not bring "God" into this - we already have one unsolved "mystery" <cough>sarcasm</cough> to deal with.
Hope to see some numbers by Monday, SY!
Gary Pimm has a very fancy LCR bridge, if it's needed. But George probably does, too.
"That which can be asserted without evidence, can be dismissed without evidence."
— Christopher Hitchens
ZAP
ZAP
ZAP
Amen
- General Interest
- Everything Else
- Bybee Quantum Purifier Measurement and Analysis
