DAC-ASH (dac-end 2 up date)
Pictures with my DAC END 2! No final case!
I used hi-end components...AD1865N-K, RA resistors, AudioNote/Shinkoh tantalum resistors(I/V), Kiwame power resistors, Black Gate, Jensen, Nichicon, Wima Black Box, OS-CON, Solen, russian teflon capacitors, MUR ultra fast rectifiers(12-25ns), Electro-Harmonix tubes 6H30Pi(pair)...and more! On DAC END2 PCB, across each MUR rectifiers I used 0,1uF/100V red Wima.
I say again...best sound!!!
Thank you!
Capacitors
Dac End Ash calls for the following capacitors:
Capacitor Vishay/BC (What types of capacitors?)
0.1uF/12V x 6 C26,C28,C30,C32,C34,C36
0.01uF x 2 C38,C39 (at digital input), C40,C41
68nF/63V x 1 C37
Sanyo os-con - electrolytic capacitors:
47uF/10-16V x 6 C24,C27,C29,C31,C33,C35
Electrolytic Capacitors / Rubycon ZLH or Panasonic FC
220uf/16V x 6 C3,C7,C11,C15,C19,C23
2200uF-4700uF/25V x 6 C1,C5,C10,C13,C17,C21
Capacitor Illinois Cap & Wima, etc... (What types of capacitors?)
0.1uF/25V x 12 C2,C,C6,C10,C14,C18,C22,,C4,C8,C12,C16,C20,C24
There is a typo in the "Illinois Cap.." What types of capacitors are for Vishay/BC and Illinois & Wima?
quanghao -- If there are corrections to the DAC ASH can you please report the corrected BOM so what happened in the old thread doesn't happen again in this one? Thanks.
Hi! The DAC board is not wrong
Only In the I/V board, have one wrong. Zenner diot value 1n4142 !
it correct Diode Zenner
1n4742 or use zener diode 6- 15V. Thats ok! May be not use it!
