DAC-ASH (dac-end 2 up date)
Pictures with my DAC END 2! No final case!
I used hi-end components...AD1865N-K, RA resistors, AudioNote/Shinkoh tantalum resistors(I/V), Kiwame power resistors, Black Gate, Jensen, Nichicon, Wima Black Box, OS-CON, Solen, russian teflon capacitors, MUR ultra fast rectifiers(12-25ns), Electro-Harmonix tubes 6H30Pi(pair)...and more! On DAC END2 PCB, across each MUR rectifiers I used 0,1uF/100V red Wima.
I say again...best sound!!!
Thank you!
Capacitors
Dac End Ash calls for the following capacitors:
Capacitor Vishay/BC (What types of capacitors?)
0.1uF/12V x 6 C26,C28,C30,C32,C34,C36
0.01uF x 2 C38,C39 (at digital input), C40,C41
68nF/63V x 1 C37
Sanyo os-con - electrolytic capacitors:
47uF/10-16V x 6 C24,C27,C29,C31,C33,C35
Electrolytic Capacitors / Rubycon ZLH or Panasonic FC
220uf/16V x 6 C3,C7,C11,C15,C19,C23
2200uF-4700uF/25V x 6 C1,C5,C10,C13,C17,C21
Capacitor Illinois Cap & Wima, etc... (What types of capacitors?)
0.1uF/25V x 12 C2,C,C6,C10,C14,C18,C22,,C4,C8,C12,C16,C20,C24
There is a typo in the "Illinois Cap.." What types of capacitors are for Vishay/BC and Illinois & Wima?
