Explendid amplifier designed by Michael Bittner, our MikeB
Can I use MJL21193/4 for outputs? What would be the values for C14 and R31/32 in this case? Any other changes needed?
I have been simulating the SymAsym with these output transistors and the FFT pattern looks strange... Oscilation?
Thanks.
Paulo.
Is it possible your graphs were caused by bad bias adjustment? And your last FFT shows fundamental (20KHz?) at -80db? This is far less than listening volume and distortion is quite large, even if mainly lower order.
Your first graph actually looks normal to me. The blips at 30MHz and beyond are probably digital errors from using more FFT points than the simulation contains. Have you seen my signature?
- keantoken
This is what I get now: THD 1kHz = 0.004503%; THD 20kHz = 0.009347%.
Bias is set at 53mA (higher bias values resulted in more distortion); Vin = 0.5V;
MJL21193/94 outputs.
Is this ok?
[QUOTEHave you seen my signature?][/QUOTE]
Yes, I'm learning LTSpice from your wiki. 🙂 Thanks!
Paulo.
HF distortion will be worse because of the slowness of the 21194/3 devices. Also remember the simulated quality of the amp is affected by the quality of the models.
Increasing VAS current may help, if you have not already. Have you messed with the stability compensation any? It will affect HF distortion.
- keantoken
The Vbe multiplier is not perfect, and I know this because I try to compare AB amps on equal grounds and watch the bias visually. The bias has a large effect on the harmonic profile, and 10 more mA of VAS current will definitely change this, possibly depending on the Hfe of the Vbe multiplier transistor.
Interesting about the Self multiplier, I didn't understand it before.
- keantoken
