Making car amplifier SMPS with tl494 + DC Protection
Hello everybody :)
As i say previously i'm french and my english is verry bad :eek: and i have difficult to understand
So i would like to build my smps power supply, and i found a lot of post talking about that, but i don't know what to do...
Can someone post a file of a good smps power supply who works perfectly, with list of composants to buy and the schematics pcb please ?
Thanks a lot for your help
best regards
hervé. :)
i tried it with the 10uH inductors and the mosfets got really hot and might be blown. I don't know what might be wrong with it right now so im attaching a picture of how it is set up right now. Does anything jump out?
And thanks for the help and the design and everything. I love playing around with this stuff, but my understanding can sometimes be lacking..
that wasnt bright of me... I tried with another toroid i had, a smaller black one with shiny bits in it. No markings or any way to discern what is it though. I tested it and got a reading for a second on the secondary and then a trace to the mosfets burnt out :|
Only one side of mosfets got hot, and they did get very hot.
The trace was to the mosfet's source. I'm assuming the toroid im using now is fine, but either the transformer is not wound tight enough, or the mosfets are toast from testing with the wrong core.
And thanks for taking the time to help with my mistakes :)
Damn, it has been forever since I have read a double digit paged thread. That being said I just finished reading this one from start to finish. All I can say is THANK YOU to everyone who has contributed here (Perry, Luka, Eva, Risto, etc. etc. etc.). Between the suggested books and everything I have read on here I am reallllly itching to build my own SMPS (gotta get a scope first though...baby steps).
I just figured I would say thanks to those who are sharing their knowledge.
yes, nice and slow, get scope, make PCB, build it, see how this really work...
if I would make one now, for testing, learning, I would make critical thing on daughter boards, so you have one universal mainboard, and you can change things, this will be something like control circuit, feedback... this way you only have to redo small control board instead of everything
I would start with unregulated, so you see how trafo should be done... and it is easy to make it really good... then add regulation (which would mean output inductors too)
One thing I would also say, smaller is better, no need to use 1000uF x 10 capacitors on secondarys, since it will make it only bigger and hard to see how something effect regulation
Something in this lines, I how I make any sense, I just woke up :clown:
