Experience with this DIY DAC ?
Other ideas:
- Should the voltage setting resistors (removed) for the 317's be linked out.
- Is there an issue with current, too little / too much.
-Not if you have connected the ground from the STR to the ground on the DAC board.
-No you cant "tune" the current on the STR.
Did you messaure the voltage on the CS8416?When you messaure,use the ground on the DAC board,not on the STR´s.So you´ll see that the ground is properly connected.
Well I've just ordered some new D44H11s for the STR.
I was getting 10V at STR input AND output which, according to Teddy, means they're probably fried. How that happened - I have no clue.He says it may have something to do with them not being heatsinked. Could be but I find it strange as they were only under power for a few seconds.
I was getting 5V at upsampling board "5V" pin but got 10V on CS4398 chip(pin 22) I have a spare CS4398 but will wait until I'm 110% sure everything is right before powering up.
Green leds on STRs light up as do red ones on DAC board - if that means anything.
I always use the DAC ground when measuring.
When looking from the back of the DAC (power in end) is the right leg of the bottom blue reg resistor connected to ground? I used this for my STR ground.
Black wire in pic:
Gigawork DAC :: IMG_1902.jpg picture by RichLund - Photobucket
Hi Bill
I have a Gigaworks schemetic but it shows a CS4397 chip and various others that are not on the current design DAC board. Must be an old schematic that hasn't been updated.
What is the current draw of this DAC circuit. The STR's are giving 1.5 - 2mA
Someone correct me if I'm wrong but the total draw is around 400ma for the digital chips.
The sch I have is rev5 or 6, shows all the options, 8416,dr9001, 8421,4397, 4398,etc
I seem to be getting rather confused over the positions of the switches on the DAC with regards to how they should be set when the upsampling board is fitted.
The illustration that came on the CD with the DAC shows the switches in the same position when the upsampling board is or isn't fitted. Surely this isn't correct?
To add to my confusion I've just realised the labelling on the switches actually says 'no' and not 'on'. I'm loathe to mess around with these switches; how should they be set with the upsampling board fitted please?
With the lettering facing you, from left to right, up, down, down, down.
The labelling is confusing,the switches are actually off, on, on, on.
The switches are different without the upsampling, off the top of my head, up down up up, but I may be wrong on that
Yeah, i read the specs wrong. That's the current source. Depending on the devices it should be around 2A
quote from Teddy:
"A 2SK363BL has a current limit of about 12mA, and the D44H11 has a hfe of about 200, the combination of the two allows a maximum current of around 2.5A. The D44H11 can withstand up to 10A and 50W so in practice the circuit is protected against short circuits at the output (I have tried it...). Note however that using jfets with higher Idss will allow higher currents."
Here are the two photos supplied with the DAC to illustrate how to set the switches -
Confusing, isn't it? 😕
I've now fitted the upsampling board with the switches set as per the photo(s) - sounds OK. I'm using an iMac as source with digital output set to 24/48.
Can somebody send me the schematic for this DAC? I'm about to buy one and replace the analog stage with a pair of Lundahl transformers.
BTW, I have been working on my own design for a cs8416-cs8421-cs4398 DAC when I stumbled on this thread. IT's hard to argue with what looks to be a very tidy design for like $125.
As a note, you can get this DAC in a reasonably nice looking enclosure for <$250 if you email the seller.
Thanks,
Sheldon
stokes@quadesl.com
Another update to the STR problem. I found this info on a PFM thread regarding regs in DAC's:
"And you have to watch the start-up times are very close, because many bitstream dacs will lock-up if the various rails do not remains sufficiently close at start-up. Check the small print of datasheet, it may mention that rails have to remain within, typically, 0.6v."
So we need to set our regs very carefully and taking our time watching the outputs. I am looking into using a fixed resistor instead of the trimmer to set the Vout. Maybe this will give a better parity between reg outputs.
