"Yo, I just received the DIR9001 and mounted on this DAC with the UTC A-20! Great upgrade! Great bass!!! Highly recommended! "
Oppsss,where did you buy it from?
Found this abundance of diy regulator links. Some might work. Just check out...
Power Supplies and Regulators for Hi-Fi Audio
Just scroll down to Teddy Regulator (Three-terminal shunt and series regulators ) and read the description....
Thanks.
This regulator's output impedance varies with the current drawn; hence, it may or may not suit every purpose.
Hmmm...
Thanks.
Hmmm...
Not sure if it makes a difference, but I think that was in reference to the TeddyReg. Doesn't everyone have SuperTeddyRegs? Maybe its not an issue with the STRs?
Yes. I thought about that too(wishful thinking). I don't know if the topology is similar.
raindrop_hui from ebay
Just use Salas shunt board from Quang Ho like Ryssen did..
That's what I might end up doing.
Since nobody has outright said these are a lost cause I'm still waiting to see if someone will come up with a solution. But I'm becoming increasingly pessimistic.
Looks like Lucasz Fikus is try to make big bucks from this DAC....
The best dac KNOWN TO ME TODAY, according to fikus
Will you guys wiiling to spend €1300 for lampizied china dac???????
So many dac tested and cdp lampizied and yet he choose this dac....???
Nope, not at all. But we aren't his target audience I hope.
Also, I'm skeptical of his tube circuit.
Skeptical you shall not if there's a A-B between transformer output CS4398/97 vs Tube output ala Lampizator...
Looks interesting but he doesn't mention which chip he's using.
I simply use the best D/A chip known to me at given moment or any D/A you choose as your favorite. Every week - it may or may not be a different DAC because my job means progress
Let's just buy one. What's €1300 to help prevent nuclear holocaust?
All parts are overspecified, usually old stock, mostly military, preferably Soviet made or Warsaw Pact. (Disarmament is a part of my mission). Remember - every Lampizator DAC or kit - means that ONE MORE missle or MIG is grounded. “Make Mozart not Nuke Hekatomb!”
Every month, Fikus discovers another " BEST Dac in THE World " ever produced.
The list is long , CS4397, AD1865 Audionote, Sabre24, Sabre32, Behringer SRC2496, Fulcrum, Sony ....
R.C.
R.C.
Hello Friends
Let ask me friendly:
What has Lukas activity to do with this thread?
Nothing!
He tries to make big money? Forget about, just calculate!
Please let us stop this thematic in this thread.
Franz
Nothing!
Franz
Piero 7
Contacted raindrop hui, and got this reply
"We have the DIR9001 module of the picture provided, but it can only suit for the DIP 28 socket pins assignment of this DAC, not exactly to replace the CS8412/CS8414 directly, if you have the DAC or DIY by yourselves, then the DIR9001 is fine for you, please advice"
I presume that the DIR9001 works fine and is a good upgrade? If so I will ask him for a price and maybe give it a try
Dave
Dave
Piero 7
Dave
It works, but mine has a false contact and tapping on dir9001 board stop playing 😡 I have to check all solders on the board
Will an AC power line filter like this one give any improvement for this DAC?
AC power line filter for Hi-Fi and Hi-END audio DIY - eBay (item 260582792454 end time May-08-10 12:50:04 PDT)
Hi , have'nt been on here for ages, l'm wondering was there ever a sticky made for this dac project?
Right Channel not working ?
MMmm hope someone can help me
I have version 2 of the DAC with UTC-20 transformers that have been working great, until the other day when the right channel stopped working.
I checked the signal continuity with a multimeter and everything is normal, I can readings from the DAC to the Transformer and from the transformer to the RCA connection. any ideas ???
- Digital Line Level
- Experience with this DIY DAC ?
