OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)
1. Jogi = 2PCB
2. qusp= 2-3PCB
3. Bas Horneman = 4 PCB
4. hihopes = 2PCB
5. guglielmope = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 2PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
12.jameshillj = 2 pcb
13.dodo = 1 pcb (one)
14.normundss = 2-3 PCB
15. stoolpigeon 4 PCB
16. Nikon1975 = 2 PCB
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
22. av-trouvaille = 6-8 pcb
23. Jean-Charles = 2 pcb
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
27. Joshua_G needs 1 PCB
28. ernesternest 2 PCB
29. wobii = 2 pcb
30. Jaap = 2 pcb
The Simpler Simplistic PCB , Now i test all PCB and the value!
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 2PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 2PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
33. h-wan = 4 pcb
Many thanks, Helmut
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 2PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
27. Joshua_G = 2 PCB
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
33. h-wan = 4 pcb
Change of quantity.
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 2PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
33. h-wan = 4 pcb
34. ichiban = 2 pcb
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 2PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
33. h-wan = 4 pcb
34. ichiban = 2 pcb
35. Adamus = 2 pcb
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
33. h-wan = 4 pcb
34. ichiban = 2 pcb
35. Adamus = 2 pcb
I added a couple to my order, are you going to let us know when to pay?
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 2 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 4 pcb
32. housing = 2 pcb
33. h-wan = 4 pcb
34. ichiban = 2 pcb
35. Adamus = 2 pcb
36. mikel_ann = 2 pcb
in your schematic you show the i-840 at 20% CCSIma, yet in the Slaas thread first page he says i840 is = CCSIma. Was there a change along the way I missed, it makes a big difference in specing the heatsinks.
thanks
He means that he is choosing his CCS current for 20% more than his max load demand I would suspect. So 20% of the total CCS remains running in the IRF840 more or less constantly. All gets there if left unloaded.
Hi Quanghao,
It's all coming together nicely - a couple of small things that may be worth doing ...
On the LHS board: 1. Relocate the ripple cap discharge resistor - if you use 2 caps simply locate the resistor between them - if just the single 3 pin cap, add donuts to fit that resistor below it (do the same thing for the RHS board) - this then gives you back the room (move the HV track up) to move the R2 like the RHSide (with longer legs on resistor) and ...
2. ... this then allows you to rearange the D5,D6 diodes to RHS of the fet, away from the edge of the heatsink.
3. If you stand R7 vertically, (or move it up to the 0V rail), there is more room to provide seperate 0v track for other components (ie C3) if the o/p terminal is the central 0V point - maybe alter the 0V tracks towards a "star earth" type system.
4. Suggest, change the AC input terminals to the more standard "+V, 0, +V" (centre tap to middle terminal)
5. D5,6 symbols?
No need for double side pcb - hope this helps ...
