Hello,
I've tested 10m45 cascode CCS with the 6c45 but this ccs had a lot of noise (Hiss).
Heve you tested this configuration in the real world ?
Ciao
Guglielmo
There is no reason for increased noise. Otoh the 6S45 is very willing to oscillate so this may manifest itself as hiss. What does the scope show?
Hello,
Ciao
Guglielmo
the problem is the 6c45, I built the 10m45 cascode ccs with 6n6p's and it was dead silent. Excellent sound, much better than SRPP.
Hi! Yes I see, but tube 6h6 or 6h30 use CCs, the sound is not good, I think you use paralle, the sound is better!
Thank
New I/V srage for DAC-end No use tranformer
audiodesign wrote:** To get the best performances I have developed a new output stage for this DAC.
It use a pair of 5687 or E182CC to produce a low distortion stage with an output impedance near to 1Kohm so able to drive any amplifier. **
Vout = 2Vrms
Vin = 154mVrms
THD = 0.2%
Vout = 2Vrms
Vin = 154mVrms
THD = 0.2%
the AD1865 cannot be driven with I2S signals
A simple shift register will take care of that.
Can you post a link or a circuit, for the benefit of all ?
Thx,
Patrick
Creating a DIY non oversampling DAC with PCM1704
What is the point of using a parallel resistors R6-R7 and R8-R9 ?New I/V stage For DAC end,
You can see
Ok! you can see here:
http://www.diyaudio.com/forums/group-buys/155960-dac-end-andrea-ciuffoli-group-buys-14.html
You can se in this link:
http://www.diyaudio.com/forums/group-buys/155960-dac-end-andrea-ciuffoli-group-buys-15.html
post 148
post 148
Hi Quang Hao,
Post 148 is about board color
http://www.diyaudio.com/forums/grou...andrea-ciuffoli-group-buys-3.html#post2035696
The color and board when finis is that!
Could you please insert direct link or explain there.
Thanks.
I/V stage cricuit for DAC-END
The cricuit I/V stage. In this cricuit you can use the sample one Pre, Zoou under 1K.
Andrea Ciuffoli say that :
*** Here the final output stage
THD measurement with and without 10Kohm load.
Output impedance less than 1Kohm
Power supply voltage about 270V
Ik = 2 x 8mA
Freq = 10Hz at -0.7db
Vout = 2Vrms with an input of 154mVrms
THD = 0.3% thd max on 10Kohm load ***
And
**To prevent dc voltage on output durung switch-on and switch off phase a relay will short the output to the ground for some seconds.
The delay circuit is the same used in the my design of Monrio Top-Loader CD Player (value 10000$). **
Ik = 2 x 8mA
And
I have opended a webpage to insert all the information about this project
DAC End - the AD1865N-K with single ended vacuum output stage
- Digital Source
- AD1865 the best DAC
