I don't have any 0.1uF caps on hand so I won't be able to do anything until next week. When I'm done I'll post some pics just to make sure everything is OK before powering up.
@ gabanyayaya
Like you say the blob has to be removed to cut the connection from inputsignal to the cap and it will then automatically be connected from input signal to trafo to cap???
Then the inputmass has to be cut from the dac-mass too. Is this done by removing the connector? Like the underside of the printed board and the top are connected by the foot of the inputconnector??
This would explain the problems some people have when they replace the inputconnector with an external one....
Any tips on a good trafo?
@ gabanyayaya
Yes.
This is looks like originally :
Digital RCA > on board input > solder blob (bypass connection to pulse traffo input) > input cap
Then we change for adding a pulse traffo :
Digital RCA or Some wire > on board input > pulse traffo input (cut the blob first) > output from pulse traffo > input cap
You can see that the solder track from on board input is connected to the pulse traffo input and the output is linked to the input cap....
Which inputmass.....???
As for the under side...I just remove the connection....no issue here....I'm happy with the Newava traffo suggested in the early part on this topic...
Like Bill said, the mass/earth/ground from the input has to be seperated from the mass/earth/ground from the DAC-board by the transformer.
It looks like you didn't have to do much to do this so that is why I think this is done by disconnecting the inputconnector from top and bottom of the board. You did not check this by chance?
from what i can recall, the mass/grounding connection for the digital input is connected to the grounding of the spdf cable. i trace back the grounding track and it leads to grounding of the input pulse transformer next to it not to the board grounding....so that's right. so far i haven't experience any noise from it.... does this version is similar to any dac you have since there so many version here from the chinese supplier...
Hi guys;
I can't play this dac with a 192 khz source.
Everything is ok at 44, 48 and 96 khz, but with a 192 signal (by the coax) there is an horrible scrap sound.
I've check everything with the upsampler board..
Thank you so much..
Thank you so much..
Hi, a simple question here: in case of external output transformer and using only the coax input, it's enough the 9V/0,5A supply, right? No need for the 2 15V suppies, am I correct?
In case of use of the usb input the 2 x 15 are needed?
no
Hi guys;
Thank you so much..
I asked the same question and they said I need to apply a hack to make it work at 192.. which is stranged becuase the seller did not mentioned anything about no hack to make work at 192khz. check post 1540 on page 154
Just picked up some 0.1uF poly caps. These things are a lot bigger than I expected(1/2"x 1 1/4") Does 0.1uF seem right? The schematic I have isn't clear(post 1567). I can't make out if it's 0.1uF or 0.1nF.
LME49860 vs OPS2107
HAFP wrote:
How are the LME49860 comparing to the other Opamps in sound quality?
-Chas
HAFP wrote:
Opamps; LM4562 sound much better than the NE5532's; faster with more top end.
You should give the OPA2107's a try. IMO, not as digital sounding as the LM4562's, kinda of tube like qualities; but this is subjective, so please don't bash me on this...
Just got some LME49860's which I plan to break in on my small DAC project board and compare to the OPS2107's.
-Chas
That is the right size but if it's for the digital input it should be a ceramic cap, not poly, and they are tiny compared to polys. They should be NPO, X7R type.
Thanks Bill.That is the right size but if it's for the digital input it should be a ceramic cap, not poly, and they are tiny compared to polys. They should be NPO, X7R type.
I already installed it with a poly(orange drop) cap. Did a quick listen last night and it sounded good. I'll pick up some ceramics but in the meantime what are the consequences of using a poly cap?
-Chas
Chas,
As respects using opamps for this big DAC kit as well as the smaller DAC kit in the output circuit; IMO the OPA2107's gave the best overall sound.
The LME49860's pretty sound similar to the 4562's; clean and fast.
The 2107's has a hint of that analog "tubey" sound; which may be good or bad, depending on your taste.
The opamp versions with the metal case have slightly lower noise.
The transformer output is the way to go with this DAC; as the tons of posts note here.
I'm still out as far as the transformers on the small DAC kit; the effect there was not so drastic as using them with the big DAC.
Cheers
My first impressions with the pulse trafo are that the bass has somehow increased. Is this possible? Details don't seem to be MIA but for a minute there it felt like I was listening to the A-20s.Thanks Bill.
I liked the balance of my DAC with the little japanese(Ramsa) trafos so I'll have to take the time and live with this new setup to see if in fact there really is more bass or if it's just my ears playing tricks on me.
I feel like I'm talking to myself here but anyhow...
I just noticed that some people appear to be using a 75 or 110R resistors instead of caps with the pulse transformer. Now I'm really confused.
Swapped the poly cap for a ceramic one and temporarily put in a 100R(didn't have any 75Rs on hand) across secondaries.
It's sounding great. Is it better than without the trafo? I honestly don't know. One thing though - no more heavy bass - in other words balance seems to have returned to normal.
Has the trafo settled? (I know that Lundahl output trafos are notorious for having a long break in period.)
Is it the ceramic cap?
Is it the resistor?
Where my ears playing tricks on me the other day?
Was it the bass from the kids downstairs listening to hip hop that was resonating through the floor and muddying up the sound?
Whatever.
I think I might try and install one of these on my Squeezebox's digital output. Apparently it's a worthwhile(inexpensive) mod.
Is it the resistor?
Whatever.
@McCrackers
I thought there already is a 75 ohm resistor standard on board?
Then now your impedance is too low and you'll get some extra jitter I presume...
About the cap I understand that a ceramic has a more uniform resistance at the frequencies we are dealing with here (2x16x44kHz and higher).
Interesting the way it sounds to you!
BTW I ordered a lundahl 1572 too, hope it improves the sound still further!
Gerard.
Gerard.
@McCrackers
Gerard.
I see. In that case I'll try without the R. Hopefully I'll notice an improvement.
Theoretically - if I placed one(trafo) on my source(Squeezebox) would the one on the DAC then become redundant? If so I might just remove it and move it over to the SB.
I know this is going to sound weird but the DAC had been unplugged since this morning so I just snipped the R away and plugged it back in. Now it seems louder and that "huge bass" is back. I have a feeling these Lundahls do need to warm up a bit before sounding their best. Either that or I need a vacation from DIY.
- Digital Line Level
- Experience with this DIY DAC ?
