The simplistic Salas low voltage shunt regulator
Hi Bill
I apreciated your comment about the caps because due to the lack of BG I might need to use Silmic in future mods.
I experimented with Ruby ZA and ZL and find these to have extraordinary high freq responce (enhancing sounstage with and transients) but loosing bass presence.
In V1 shunt, C2 affects tone very effectively. (Here I found 680u a good compromise between bass presence and detail)
Please let us know your findings regarding the best caps here.
Ricardo
.. it's getting dark early in Portugal, isn't it Ricardo? 😛
Hi Bill
Ricardo
C2 is effectively in the signal path. I found out from my Jung Supereg that the equivalent C2 disturbed the sonic. Eventually I got rid of it. That was after adding and removing the capacitor a few times for comparisons.
No cap is better than any cap. But then I must trust the experts who examine it with a scope and at least model it using Spice. If they find that the zener produces unacceptable level of noise which can be cured by a big capacitor, then I must trust them and follow them. The interesting thing is that how come we can all hear the signature of that capacitor? It must be measurable! Spice modelling could only assume a perfect capacitor with C, L and R. People have also measured DA, DF and other characteristics of capacitors. But time and time again engineers have produced very well measured circuits with electrolytic capacitors in them. At the end of the day, when adopting a circuit I trust the engineers' scope more than my ears. Only when I come to listen to music that I trust my ears but nothing else.
So Salas recommends using a string of LED instead of zeners above 6V. For 12-15V, if I use 8 x 3mm LED1.7 or even 4 x 3mm LED3.2, would the noise be reduced enough to ditch C2?
I have done a lot of comparisons on capacitors. Good quality polypropylene and polystyrene capacitors designed for high frequency applications are usually very good (i.e. not ideal but are accpetable) and the difference between them is smaller. Electrolytic capacitors, if used in signal path, no matter how good they are, impart a strong sonic signature onto the sound and veil the sound. When it comes to which capacitor is better, there is no better cap but really depends on individual taste. The Elna audio capacitors sound quite warm, artificially enlarge the sound stage. The sound is "tube" like. They do not give a nasty or harsh sound. If that is your cup of tea, by all means go for it. The capacitors can even mask the harshness of inperfect systems and make them sound more smooth. However, I think when the entire audio chain is of high resolution, then these capacitors would be "too rich". The cleaner sounding capacitors, like the Rubycon ZL, would be preferrable. I have not found the ideal capacitors yet. The Rubycon ZL is the cleanest among them, but the peaky treble can let a lot of lesser systems down. I have never liked the Rubycon ZA. Panasonic FC may be something in between Elna and Rubycon.
Bill
Iko and Salas,
Thanks for the information.
I am pressing on now and am trying to order the parts. All are available except the ask170.
It can't be found in Farnell, RS Components, WES Components, 3 of the largest in Australia. I also searched Digi-Key in the U.S. and the part is still not found.
Where can I get them? Does any Aussie forum members know where to get it within Australia? I prefer to source it locally, as the shipment fee is about $9, vs anything from $35 to $70 if I get it from the U.S.
Bill
Bill
Spencer is the man that supplies our NJFET habbit. Have $37 in your hand and he will fix ya for 100mg pure Toshiba BL. Err sorry, 100 pieces😀.
Spencer's thread
Thank Salas!
QuangHao
Can you post it 25% bigger, and with CCS IRFP9240 symbols as in the middle one? On the other two they look like Jfets and maybe someone will be questioning. Plus put the word trim in the middle 100R above 2 leds too? What Sala, means in Chinese? There is a tune by Pupils aswell. Make it Salas if you can on the scematic.
Hi Bill
Ricardo
Sorry I am unable to give you an answer.
I believe that there is no way that the different good quality electrolytic capacitors would change the fundamental frequencies. They don't, or they are not capacitors. So basically, I don't think that the Elna or Panasonic caps are richer in bass while the Rubycon ZLs are lack of bass. But I confess that they do sound like what you describe, and I had the same subjective findings. I think the reason behind it is, instead of changing the fundamentals, they perhaps are unable to produce the rapid transients at higher frequencies therefore producing their distortions, possibly in a way like injecting harmonics. In psychoacoustic, we know that it is the harmonics that make us perceive instrument sound, rather than the fundamentals. I guess that the sort of good caps are those that produce "better" harmonics, such as perhaps BG or Elna Silmic, and the bad caps are those that produce "bad" harmonics. I guess the Rubycon ZL produces less harmonics except some higher frequency harmonics.
On a very clean system, the Rubycon ZL produces absolutely no less bass than the Elna, just the sound has har less distorted harmonics. So it is cleaner bass. But I agree that The Elna is less bright comparing to the Rubycon at the higher frequencies.
I hope one day people can measure these effects. Before that happens, we will continue having fun playing with capacitors, being "audiophiles", i.e. sometimes playing with magic. It is interesting that human psychic likes magic. If we take out magic from HiFi, HiFi may have less fun. I like to have that sort of fun, but realized that in order to obtain ultimate audio, I need to step out of the subjective territory, believe in no magic but science, and follow what the engineers telll me...
Have fun.
Salas,
Thanks for your great work. I like it (v1). It is so simple to implement it, given it is a shunt regulator.
Correct me if I am wrong. The same circuits / parts will work with different voltages and current demands, and only D1, R1 and R5 need to be altered to suit specific requirements, but nothing else.
I am sure the information has been given before, but considering that this is a long thread I have not had the time to read through the entire posts, would you mind giving the formula to calculate the required voltage and current, a formula of just D1, R1 and R5?
Bill
Salas,
Would you please give an answer on this?
Bill
I recommend leds in critical or perfectionistic builds, yes, but losing the capacitor presents all the Vref noise to the driver BJT for amplification, even if little. You can check in your application. For OPA627 member Marinos have found a big improvement over battery supply with the V1 shunts in older posts, even if he had the zener + cap plain vanilla.
Salas,
Bill
Forget R5 & R3, its a lift that does something transiently.
ICCS=(Vf3Leds-Vgs)/R1 Decide target current, derive needed R1.
Vref=VfD1+0.6V=Vout Can be Zener or Leds. Measure their Vf at about 6mA
add them up in two matched strings for +/- regs
I'm not an expert, but the noise at the output of the regulator I measured with and without the cap across the zener. With the cap the "grass" was no longer there. Measured various cap values, and the noise was inversely proportional to the value of the cap. But I've said it before, trust your ears rather than my scope. Just because it shows on the scope it doesn't mean the sound is bad; or good.
To avoid confusion I usually say explicitly when I talk about simulation.
I also agree with you, I'd rather not have a capacitor in a circuit, but there are times that it makes sense to have it.
