Experience with this DIY DAC ?
This is for Havoc08,
I have done the DC input mod to the Tripath - actually no mod needed to the Tripath. Don't remove the capacitor on the biascap just connect a wire to where it goes to the biascap pin (or connect to the biascap pin itself). This wire will be your pseudo ground and goes to one end of my transformers secondary winding. The other end of the secondary winding goes to the input signal pin. No capacitors needed because both should be at 2.5V potential so no DC, right?
Measure the potential between the two wires before you connect just to make sure they are at the same 2.5V nominally (mine were about 2.4 ish). Connect & check the speaker connectors have no DC on them. It's probably good to have a DC offset circuit & adjust it for 0mV. Mine was at 0mV when I was using caps & went to 10mV when I did this - a slight adjustment & it's back to 0mV.
Well worth it - a slight smear on the highs was removed - obviously from the Wima cap I was using. It's probably a good test rig for testing the transparency of caps too (just thought of that)
I bypassed the vol control also - I'm sure I could have wired it up so no DC was running through it but I wanted to get rid of it anyway - I'm controlling the volume on the PC.
Thx jkeny, I'll add you on buddy list and then we can take it from there as you're right... let's not high-jack the thread further.
I'm not sure as I find relying on audio memory notoriously unreliable, for me anyway. I remember the shock of the difference in sound between the stock op-amp o/p stage & the Slagle trafos. The Lundahl's seem not as good as the Slagle at the moment (in my system,etc) but it might be too early to give an opinion (i guess I just did & that was the caveat 🙂)
I was just rereading the other thread and was reminded that the Slagles and Lundahls are quite different animals. The Lundahls are a dc short so some series Rs must be used with them to protect the chip.
@ gamgee
Here is a picture of my monacor implementation.
Input from DAC (before capacitors at L+/-, R+/-) through series resistors of 220 Ohm to connection 1 and 3.
In between 1 and 3 a capacitor of about 7 nF. (4,7 + 1,8 in my case).
From 6 and 8 to the output with a resistor of 1k and cap of 3nF between 6 and 8.
Hope this helps.
BTW this really is worth the extra 20 euro!!!!
The values above from earlier posts really do the trick, I tried without output R and C, but sounded rough around the edges, really unnatural.
With a lower input-cap the sound is less polished. Maybe the pre-amp does not like the HF-garbage.
Would you mind starting a new thread? I am very interested in using this idea and would like ideas on using it with different t-amps/dacs.
Yes, Data, let us know how they sound.
Vaughan, I have another thread about DAC output transformers on which I also posted the Tripath mods - you can post there if you need to ask questions. Ah yes, I see you've already posted on that thread - it's probably no harm to start a new just dealing with the Tripath & Transformer inputs
@ gamgee
Hope this helps.
Thank you GerardA!
ok guys, thank you - i have just one more question:
GerardA, in your post you are using "nF" - this stands for "nano Farad"?
Sometime, in my country, some people use "n" and some use "u" instead of "micro" prefix, because they dont know where to find "μ" on the keyboard.
I don't want to mess something up, so, is it nano or micro range?
Haha, n of nano mu for the other one.What key is that?
I meant nano, you can check this with earlier posts, I think it was Legarem who came with these values after doing calculations and listening test.
But you can try both and listen if you hear the difference!
Code:
outputs 6 & 8 on the trafo go on which part of the RCA respectively)
Does not matter as long as it is the same for left and right.
Maybe you want absolute phase to be correct?
Than you need to do some extra testing/measuring with which I can not help you.
Would be interested myself too!
If you put 1 on negative and 8 on ground/earth/negative the trafo is not supposed to change absolute phase.
Don't know what the DAC is doing.
(Don't make connections between 1 and 8 directly or indirectly)
I bought 4 Monacor LTR-110 to do some experiments with this DAC and a Buffalo24 from Twisted Pear.
For now i have connected the + and - DAC out directly to the primary of the LTR-100 and the secondary to RCA with a 10K resistor in parallel for both DACs.
I attach the results of measurement done with RMAA.
Next i will try a better way of connecting the transformer to the DAC (something like the way descripted by GerardA on post #1285)
Anyway i can say that i really like these transformer out DACs, it seems to me the Buffalo24 is a little bit better in detail and in the positions of the instruments on the soundstage.
Ciao
Andrea
(on the left CS4398, on the right Buffalo24)
