Fotios , just about the best I've seen here , right up there with the best aska's and aussieamps (my previous amp porno stars) BRAVO !! 🙂
OS
OS
So , for a catchphrase idea it could be :
diyaudio.com
don't matter ,fotio's doin' it better !
diyaudio.com
Fotios,
A quick estimate shows that you punched about 3,500 holes only in the bottom panel. Assuming the same amount on the top panel (conservative) and 10 seconds per hole (conservative, not counting center punching, deburring, assuming one pass drill (unlikely for soft aluminum) etc...) it means you spent about 20 hours at the drilling press. One hole badly off and you could need to start over.
Unless you have a CNC tool, you are a true hero.
Aussie Amps NVX300
Just finished some mono amps, also used Anthony's soft start and speaker protector boards. Will be adding Per Anders Rectifier boards once I decide on what diodes to use - any suggestions or opinions on Phillips BYV32E-200?
Fotios,
Holy sh*t! You are right! I hadn't even noticed those holes were done by hand....WOW!
Even to layout the centres must have taken some time.
Pictures of the revised amplifier Charisma 0K6 (see in post 713 the initial design and why the revision). I must point out that everything in this project it is designed, constructed and machined in my home with my hands except the heatsinks and the transformer.
IT IS AN ABSOLUTE DIY PROJECT.
Holy moly! That's absolutely incredible.
I now have a "Fotios" folder on my hard drive with all these pics.
HI Fotios
The best DIY ever see![]()
Agree.
Congratulations Fotios! Well designed, nice built!
How did you do lettering on a rear panel?
"Work in progress since 1995" 😀
HI Rumors ,we have the same problem ,the work is always in progress ,never definitive amp , before i put in the box I build a new amp ,as always sound better !! never end
now I have switch to tube , a new better world
hmmm """ a new better world""" ???? well not especially ... you may want rephrase to a """new other world """
kind regards sakis
...Even to layout the centres must have taken some time.
I used a piece of Veroboard (perf board) as the drill template for my ventilation holes - no marking out.
Brian.
😀 ok waiting for a j2 Pass .....
but for now my EB in class A is in the dust !
I speak only for me ,based only on my diy
Turntable sound magic
Open baffle sound magic
tube sound magic
no cheap way......I start to thinks that speaker 86/88db plus hipower SS is the wrong way to look the problem ,(industry $$ way) ,better (need to tray) 2 watt set with 98/100db speakers ,my next project I will report when done
best
tube sound magic
best
thinks one moment
Who told you that for hear good music you need a boxy speakers??
the industry $$$ !!
why ? are small, nice ,hight W.A.F !
who told you that you need MDF (Carcinogen) for boxy that sound good??
the industry $$
why ? is cheap !!!
the industry $$$ !!
the industry $$
why ? is cheap !!!
Thanks John
Indeed, i have spent 6 months to finish it.
I am really very satisfied and not because the success of project. I am very satisfied because i have not paid neiter one Euro, be it so counterfeit, to any VAMPIREmachinist, pcb constructor or graphic artist!
That is the real pleasure!
Regs
Fotios
How about a picture of your lab/workshop/bench for us to drool over in addition to your fabulous amplifier workmanship... Thanks
Pictures of the revised amplifier Charisma 0K6 ...
Fotios: "you da man!" 😀
Very honored Doctor Fótios... wonderfull job.... i am astonished!
You are really very good fotios..the man... Da man!.... honorable man!
I have observed a lot, into de details, to see some signals, clues, that was made at home...screw holes misaligned and so on..i found some..but was not easy...congratulations!!!
I was searching to find failures we normally do when working at home.... a non industrial construction, alignment, position of holes and so on...it looks something that went out from a factory!
Wonderfull job... please, inform how long time you have spent to build this wonderfull amplifier... 4 years?.... how long take the mechanical chassis work?
Dudainc.... when they recognize (they did... the scientific acoustic community) that they do not know everything, seems to me they really have a deep and sophisticated know how...this is needed to conclude our human natural limits...our ignorance...others goes delirating thinking they know everything... the biggest the pride and arrogance the smalest is the inteligence.
Se você não entende de motores, e de mecânica, tem dificuldade de avaliar a qualidade do reparo de um mecânico..é preciso conhecimento para perceber falhas...é preciso conhecimento para perceber o quanto somos ignorantes.
If someone has not the knowledge about how to repair an automobile engine, this one will have trouble to evaluate some repair man work quality (performance)... as we need know how to evaluate others...we need know how to understand how we can be ignorant too.
"È preciso muita inteligência para concluir que somos ignorantes... e é preciso conhecer bastante para concluir que ainda falta muito a aprender"
abraços amigo,
Saudações
Carlos Eugênio
abraços amigo,
Saudações
Carlos Eugênio
omg, Fotios plz tell me that you used a milling machine or cnc, because if you did all this with standard drilling equipment I will never try again to drill any chasis for my projects 😀 I think I need a
Excellent job man, what can I say.
Is the back label vinil sheet printed in laser printer?
Thanks guys for your kind words.
I will try to resolve your queries. As we say in Greece, THE GOOD CRAFTSMEN MAKES A GOOD TOOL USEFULL; NOT THE INVERSE!
The main issue here, it is the elegance of the amplifier's enclosure. In such issues i have an inborn talent. I have as well an inborn talent in fine works. I try to tell you the truth, and i hope you not take this as arrogance! I don't like the bulky enclosures with the lot of thick alu decorative pieces on the front plates. I don't like the Gothic or Baroque style. I like the frungality, the slim lines and the harmony in construction. Like the ancient Greeks!
Fotios
Fotios
- Post your Solid State pics here
