Thank you Peter,
I think I am beginning to understand why there is a large cap on the output of the 8V regulator.
EDIT: a) Motor speed control could be affected by the performance of the 8V supply. b) Noise could pass through the secondary regulator without some sort of filtering of the 8V rail -- but 1000 uF is too big for that -- still thinking about that one...
a large cap at the output of a voltage regulator serves to lower the output impedance of the regulator. One byproduct of reduced output impedance is an improved transient response. It will also help with ripple rejection, but there is not much ripple left after the input cap and the regulator.
Thanks okapi!
Have you or has anyone tried bypassing the caps on the output side with smaller caps? like a 4.7 or 10uF bypassing the 1000uf?
There is no snubber capacitor across the transformer primaries?
Has a snubber been attempted?
okapi said:a large cap at the output of a voltage regulator serves to lower the output impedance of the regulator. One byproduct of reduced output impedance is an improved transient response. It will also help with ripple rejection, but there is not much ripple left after the input cap and the regulator.
You might get away with a smaller capacity if you use a lower ESR cap.
To explain this: the company I work for is an OEM of industrial electronics. The power amp of a measuring device we produce for a client has shunt regulated PSU's. Sometimes we have to use an electrolytic cap in a key position where a certain Wima cap is preferred but not available on short notice. The Wima cap (I think an MKS) has a much smaller capacitance than the substitute elco. I presume this has something to do with ESR.
i recieved my dac today, i opted for the toroidal transformer that came with it. Its has a +8v and a 0 which i presume is the only connection i need to make to the dac board if I am bypassing the opamps.
It also has a +13v, 0, -13V winding. I am making the psu from the pdf file on page 2 of this thread. Do you think it is possible to use the +13 0 -13V windings to power the cd player? is there any benefit of making the cd player in the same unit as the dac?
I bought a +12 0 -12 toroidal from RS spares for £15, but i am thinking i could take this back if i can use the spare windings from the dac transformer.
cheers stuart
cheers stuart
surfstu said:i recieved my dac today, i opted for the toroidal transformer that came with it. Its has a +8v and a 0 which i presume is the only connection i need to make to the dac board if I am bypassing the opamps.
cheers stuart
Toroids provide relatively little HF noise isolation between their primaries and secondaries, and even less between secondaries in a lot of cases. I think you would want to keep the supplies entirely separate right down to the transformers in order to reduce the likelihood of noise injected from one supply to the other. The motors in the transport are noisy and also draw relatively large currents during seek, etc.
Also transformers have AC outputs, not the dc ones you seem to imply via the use of +/- symbols. AC transformers are generally specified without polarity. Examples based on yours would be 8V or 0-8V and 26VCT or 13-0-13 volts, etc. Other conventions also apply, but polarity does not.
Cheers Kevin,
am picking up my ez51 tomorrow and i'm ready to go with all the bits...
bought from ebay as a graded product for £22.99
cheers stuart
cheers stuart
Good luck, project is a lot of fun!! 😀
Just be careful, double check everything before applying power.. Don't ask me how I know..
cheers kevin,
now i will be forever wandering how you know to double check everything before applying power,
i thought this was quite a simple mod, care to share you headaches?
cheers stuart
cheers stuart
surfstu said:cheers kevin,
cheers stuart
Hi Stuart,
Talking in general, dint of hard experience,etc.. Mine is based on the RC-EZ32 which uses the same chipsets from the same family, but uses an external micro-controller like the actual Shigaraki. I blew one up..
Kevin
Check out the bel canto CD-2. It uses the CD-Pro2M mechanism, but it looks like the door switch is replaced with a proximity sensor. Very cool idea!
http://www.belcantodesign.com/images/prod_CD2pop_angled.html
Nice player Peter! Looks sharp. I like your wood cutting board as a base too. Nothing wrong with that in my opinion. I'm going to start using that since my wife likes the plastic cutting boards better anyway.
You said all in one player, meaning it plays SACD as well, or did you mean DAC and transport on one cutting board?
Very nice job Audio1st !!!
I am jealous seeing your perfect looking spindle...😎
BTW
Should the pc-board not rotate in order to get the switch and connections through the backplate...😕
EDIT
I get it...you will not be using it as a "transport only" anymore
BTW
EDIT
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
