Denon DCD-1460 problem with KSS150/210 laser.
- By androa76
- Digital Source
- 6 Replies
I have problem with Kss150-210 laser in Denon dcd1460. After inserting disk, lens go up an down, disk not rotate, just move a few degrees and no disc. I changed laser optic (removed safety blob) to another and problem is the same. Test run gives result Error 2 ...no FGS (focus gain signal) detected, Measuring current on driver transistor shows voltage drop of around 1,4v on 22r ,so around 65ma current sucks the laser. Voltage on Laserled suply jump to 2v after play. No eye pattern is vissible on test pins. I cleaned laser start position switch.
I am confused that new laser is damaged because it shows same symptoms. Any help where to continue'
Thank you.
Thank you.
