Yamaha MX-600 Amp will not come out of protection. Should protection circuit be rebuilt.. Outputs out of circuit and still in protection.
Hey, have Yamaha MX-600 stuck in protection mode. All outputs are out of circuit and still in protect mode.. What to check next or just rebuild protection circuit. Relay has been replaced and + and - voltages coming off of bridge to main caps..
Input greatly appreciated
MarkAudio CHP90 Full Range Bass Reflex Monitor, Passive Crossover Response Help
Hi all,
I built a fun speaker a while back based on the Mark Audio CHP90 in a bass reflex design using some big oak slab baffles. Very rustic chic. I've been using active DSP on them to handle any issues from the overall baffle changing the response. I recently took them outside to do some measurements to get a better pseudo-anechoic response so that I could export it as an in-baffle FRD and used my DATS to generate a ZMA from in-baffle as well. The goal being to take these measurements of the driver in the cabinet and work on them in VituixCAD to alter the frequency response a bit in a passive crossover, even though its not really crossing over.
I'm attaching my VituixCAD file for anyone that wants to play with it to help out (renamed to *.txt, just remove the .txt and it will be good to go)
Overall I'm just trying to flatten it a bit. Doesn't have to be a heavy natural house curve, but just flattening it would be a nice thing for me. I don't particularly want to make $100 crossovers for this, but I'm just seeing what I can do and what I can tolerate with some basic passive components. Any advice or criticism is appreciated!
I did farfield impulse response gated measurement of the driver, and then did near field of the driver and port and scaled the port's output via area and then summed the near field response. Then I corrected it for the baffle to full space. Final measurement:
As you can see there are a few big spikes I'm trying to potentially tame down, and then maybe lower the upper end in general to flatten it out. Those spikes are around 4200hz, 6400hz and 11800hz.
I used this measurement to generate an in-baffle FRD.
I used this DATS measurement in-baffle for producing the ZMA.
I'm currently working in VituixCAD. A few options, the response on its own and some of my efforts so far.
RAW response in VituixCAD with no components:
Here's one approach I'm looking at:
And then I went overboard with notch filters to hit those 3 spikes. Overall this seems silly and wasteful. Maybe there's a better way? Looking for advice on that.
Any suggestions appreciated!
Very best,
Peerless K040MRF mf driver replacement
Any suggestions where I can get a replacement for a Peerless K040MRF medium frequency driver or what drivers I could use in place of a damaged unit. It looks like this.
I can't find one on Ebay in the UK. It is in a Pro9TL Mk2 cabinet and has failed completely. This thing has a sort of a can on the back of it so doesn't depend on an enclosure which makes replacement difficult.
15" Woofer suggestions for End-Game 3-Way?
Hi DIYers,
After a few difficult years with the further realization of how short life is, and that it can be forever changed in a day, I've been led to a place where I feel if I'm going to achieve life's little goals, now is the time. One goal is a dream speaker, a 3-way of the highest resolution and sound quality, along with good aesthetics, to rival $100,000 high-end speakers. This is not a "no-compromise" speaker, as every decision is a compromise in some manner. Speakers will be used for everything from orchestral, classical, acoustic, pop, movies, and video games in a residential system.
I implore people to recommend 15" woofers, and interesting 12” woofers are also considered, as there is no possibility of hearing these locally. I have mostly been looking at big radiating area, because I like the way they present recorded elements as room-filling and life sized. I also consider myself among a smaller number of listeners that prefer an over-damped, fully stuffed cabinet. My current speakers are Yamaha NS-1000M and Quad ESL-989 electrostatics, and I would like the future speaker to share the high-resolution traits these provide, but with more extension and sensitivity similar to the NS-1000M.
Some drivers I have modeled include a small number from from TAD, Acoustic Elegance, B&C, BMS, LaVoce, Eighteen Sound, Audio Technology.
The bass parameters can be changed as the physics require, but mostly center around the following:
  • Low-pass crossover point of 450Hz, depending on mid might be 250Hz.
  • 8-Ohms nominal impedance.
  • About 94dB sensitivity at 1W. System goal is +88dB after baffle step compensation.
  • Aperiodic or Sealed enclosure, 100 liters target. 150L max, as it the bracing and curved wall thickness makes the speaker large.
  • Enough extension to not need a subwoofer. This one is sometimes at odds with sensitivity and enclosure volume.
  • Rolled or accordion suspension are welcome for longevity. Ribbed paper cones are great.
  • 100W power input handling.
  • Will be used with solid-state amplification.
Audio Card in Linux
Hello.
I register here, because i have a problem with an Audio Card.
Is there a Linux distro in which the APS (Audio Production Studio audio card, by EMU) is working "out of the box" ?
I have test it in AVLinux MX 19.4 (for 32 bit) and it is not working.
Or if there is not, then does somebody know a patch or a setting or something.., that will make it give sound ?
I have tested, in the same distro, two other cards with the same processor (EMU10K1) and they work "out of the box".
Replacement volume pot for Marantz 7C
I used a 500k dual gang PEC carbon pot for my Marantz 7C copy build but unfortunately, as I had heard others warn about, the tracking of the two tracks is off quite a bit and requires rebalancing every time I reduce volume any where near 1/4 turn or lower.
I noticed that Parts Express and some other suppliers I've used in the past does not carry anything over 250K in an Alps stereo pots which I wanted to try. Any suggestions for another brand that is good enough for the task in a reasonable price range. I guess the next question for anyone versed in old tube designs such as the Marantz 7C, would a 250K pot work for the task or would it cause any impedance mismatching enough to avoid?
HK 3490 failure
For a friend I am repairing a Harman Kardon HK3490 receiver. One of the channels was dead. After checking the output stage both output transistors, the bias transistor, a safety circuit resistor R362 and one half of the current limiting resistor R356 are broken. I have found and installed replacements but are still waiting for R356.
Does anyone have an idea what could have caused such a pretty big failure? The power supply is ok and the other channel is working. All the other transistors measure ok.
Reactions: kikoguerra
LS165w-2T noise reduction
A LS165w-2T is an SMPS producing 300v @ 0.3A and 6.3v @ 5A. It's available at AliExpress and is inexpensive and small. There is a review at another forum at
https://www.head-fi.org/threads/review-ls165w-2t-switch-mode-power-supply-for-tube-amp-use.975587/
Would one or more of the experts on this forum be interested in creating something similar to AmyAlice or PO89ZB that could reduce the noise in the 300v output?
If there is already such a circuit, could you let me know where it is?
ray
Hello, my name is Augusto from Brazil. i have a harman kardon HK 3490 with sound problem. Thanks!
My HK 3490 device is very well preserved and has very little use, but it has a significant hissing sound in the left channel. Here in Brazil I do not have assistance or technicians with experience with these devices, so if anyone has had this problem and can give me some suggestions, I would be very grateful.
B&O MMC4 - Stylus repair (help needed)
Hi, i have an mmc4 stylus which had one channel not working/had very very low output. Since I’m too curious not to, I thought f*** it and opened it up.
Can anyone suggest how it is supposed to work?
I can’t find resources/ drawings or anything about the “wiring” of the coils.
After extracting the coils i noticed that part of one had become loose/ potentially even has a break in the wire except its so tiny i’ll need to get a magnifying glass.
Any advice on how to do surgery on it (if its even possible)?
For Sale Audioamp.eu Automatic Bias Control for 4 Tubes
Audioamp.eu ABF-Q Auto Bias For 4 Tubes With Filament Transformer
I bought 2 of these a few years ago and this one didn't get used.
The ABF-Q module from Audioamp.eu is an automatic bias control system designed for tube amplifiers with four output tubes, configured in push-pull (PP) or parallel push-pull (PPP) arrangements. It ensures optimal performance by dynamically adjusting the bias of each tube, maintaining strict current symmetry between the output stage branches, and preventing DC current flow through the output transformer. This approach minimizes low-frequency distortion and extends tube lifespan.
A notable feature of the ABF-Q is its integrated 6.3VAC isolation transformer, making it suitable for amplifiers where the 6.3 VAC filament supply is referenced to ground.
Sold
Introduction from St. Louis
New member from St. Louis. I like to build audio stuff. I have built a number of speakers: Linkwitz Plutos, Linkwitz LX-Minis, Linkwitz LX521.4s, CSS Criton, GR Research X-Statics, etc.
I built the LX-Mini analogue crossover, but it does not work. I came here for looking for help with that.
I am about to build the Amp Camp amp.
I own some vintage audio equipment such as Great American Sound amps, a Conrad Johnson preamp, Denon and Technics turntables, etc. Looking forward to the expertise of this group. I am sure I will learn a lot.
John
Fostex T90A L-Pad/Crossover Enclosures
Bought these from Reallygoodstuffs.com for $350 and they work great! I only ever ended up using them at full volume in my system so I am selling them and just going to a cap. These have the Solen 1.5uF installed and ready to plug & play.
More info here: https://reallygoodstuffs.com/L-PAD Enclosure.htm
Asking $200 plus shipping
Modushop chassis punch design library
I was wondering if there is any support for establishing a “library” on DIYAudio consisting of different designs for custom punch/machining patters (in DWG format) for front and rear panels of various Modushop chassis?
For example patterns developed and actually used by members could be posted in an organized fashion, perhaps by chassis type, size, and application (e.g., generic preamplifier, ACP+, H2). Each design would be accompanied by a short description, e.g. 2 RCA input in 1/2” hole; 2 XLR D/size outputs, and so forth. One could then open files to see if configuration meets their needs and then submit them to Modushop rather than possibly incurring a drafting fee.
I’d be willing to work on this if there was interest and support from DIY Audio.
Modulus 86 Amplifier
Here is a DIY Modulus 86 amplifier with dual mono SMPS power supplies. The boards, and inductors were all purchased from Tom's website, the chassis is a Modushop Dissipante and the rest DigiKey/Mouser. The amp sounds great! See Tom's site for more info: https://neurochrome.com/products/modulus-86
Asking $400 to your door in CONUS
NOTE: The hole on the IEC and power switch are elongated since I mis-measured the height! 🤦‍♂️
Babelfish ᄅſ....or FW J2 on Steroids .... or Not your Father's J2!
:rofl:
Seeing some stones turned lately , I simply couldn't resist Babelfishing urge......
Though , as I already did some mild Babelfishing of our dear and beloved J2 , logically that this time I needed to do something ...... completely different :devily:
due to constant demand and popularity mainly on Far and less Far East , schematic of original FW J2 is still generally unknown or - better said - none of circulating DIY schematics weren't blessed by Mighty Pa (pleonasm here , Pa is Mighty by 42)
few things we all know , and these few things are good and plenty enough for basic postulates of variation of Jazz Standard 🙂
Basic premises :
1. possibility of incorporating less critical ( for acquire) JFets for input LTP, by choice and must possible use of 1+1 , or 2+2 in same ;
2. possibility of incorporating various output devices , of lesser and bigger rarity and/or price
2a. possibility to avoid tearfully matched parts (outputs and other ) , while still easy settable both output offset and OS Iq in broad range of values
I got it all ........ how:
1.easy peasy - use N channel JFets (choice is waste!) , lead them (currents) back to lower output gate via simple and effective current mirror ..... put few cascodes here and there to pet both JFets and fine CM parts (tiny JFets are always grateful for that, but high beta small BJTs like that too) ....... and while we are there - why not using fine emiter follower between CM final end and lower output's gate .......
2. OK - trimpot in front of lower output's gate is trivial ; second part is feeding Optocoupler with CCS , with some current spare , and routing the same in loop around ( in parallel practically) said optocoupler , so we can set Iq of upper mosfet with ease and in broad range
2a.partly already covered above , just to add that output devices can be plain old IRFP150 , same as any boutique part you already have , value of Ugs is irrelevant - easily covered with change of ,say, two resistors
'nuff talking , time for schm (read notes on left side):
Reactions: inyashd
MOBIFO
Went through my inventory and found some "good" old 2N3055´s. Got a little nostalgic thinking of the JLH 69 that I built -69.
Have never seen a compound mosfet/bipolar Darlington before, so I thought I would give it a try. Sims great at 1W/8ohm and outputs over 10W, so I will build a mono pair for my midbass speakers(60-350Hz), when the heatsinks arrive. The upper registers will be fed with IRFP240 FOMO´s. The 193U that I already have are not optimal due to their high DCR, but they will do. Thermally the circuit sims OK, if mounting the IXT on the heatsink.
But is there a catch using an ancient bipolar output device 😉 ?
What I don´t understand is why the IRFP240-version falls off earlier when loaded harder? The sims show the 240 should have a Zout in the ballpark of 0.2ohm and the 3055 0.4ohm. At nominal 8ohm bass response is close to equal. Screenshot with 2ohm load.
Note the sims are not telling it all and are very basic, but indications look good.
What amplifier does everyone use for taking their driver measurements?
What amplifier do you use for taking your measurements when designing a system?
I tried researching what to use but didn't find much. I am wondering if some amplifiers color the sound enough to actually affect the measurements. I couldn't find anything definitive.
I will probably try a couple different amplifiers next time I am taking measurements just to see if there is any different in response at all. My guess is there probably isn't. If there is, I would hazard to guess its either at the far high or far low end of the frequency spectrum.
Currently I use this cheap class D mono amp. Its actually very clean sounding. I use one of these in my bedroom with better sound than I think you'd get anywhere else for $30.
I found a couple places and also heard from A4e that I maybe should be using a class AB. I do not currently have one of those. I had one in my car but it died years ago. Class AB and hot summers don't mix well. I am wondering if I should pick one of these up or a cheaper car audio 2 channel class AB.
The logical part of my brain says to use the same amplifier that I plan on using with the system. My current project I will be running this amplifier as I already own it and have upgraded the tubes. BTW, if you have one of these, upgrade the tubes and it will bring a world of clarify to the high end.
Lm3886 XY board Modifications
I bought two pairs of these boards to play around with and was hoping to get confirmation on some mods I saw on a thread in the attached picture.
Do these mods look correct to implement?
I just had questions:
- why the output is attached to ground via a 10R resistor and 68N capacitor
- is the larger .15 ohm 5W resistor bypassed here?
- is my star ground attached to chassis or floating?
- Finally, where is the best location to cut the trace on the board after the ground input? I understand I am just trying to remove the signal input ground from the PSU ground.
Thank you. Any other recommendations or modifications are appreciated.
RIAA preamp kit recommendations?
As someone who is actually looking for a decent RIAA preamp (any recommended kits out there?)
I recently found Michael Fidler, who offers a rather well reviewed preamp for £500. The construction in this is a whole world apart from what Tom Evans is making. To my mind, this is decent high end construction.
Currently using a Technics SL1700 & Audio Technica VM740ML
Apple MIDI channel mapping over HDMI with Leawo BD player and DLP(Dirac Live Processor)
I am trying to build a mac-based A/V system, and got really confused with the behavior of a few S/W and macOS(CoreAudio?).
I finally made the Leawo S/W BD player play the 4K UHD on my Mac Mini M1(2020), but quickly got embarrassed that the HTP-1 connected to it plays audio with center and subwoofer swapped! I tried to change the speaker config of HTP-1, but no luck. Then I found that AppleMusic playing Atmos track also has them swapped, but changing speaker config got center and subwoofer unswapped. So I assumed Apple Music was doing the right thing to use the speaker config info for output channel mapping, but Leawo BD player was stupidly ignoring it. Email with Leawo support also strengthened my conviction. Leawo guy didn't seem to have any idea what speaker config is.
Then I thought that Dirac Live Processor which I was planning to install anyway could give me the remedy. Written by a renowned S/W company, it was likely to do the output channel mapping of HTP-1 at the HTP-1 speaker config correctly, so the channel swap issue for both player S/W would be resolved. I seem to prove wrong!
The Leawo player and Apple Music are set to play into DLP, and DLP output is set to HTP-1. Changing the speaker config at HTP-1 doesn't work for Leawo player, the same result, though it should impact DLP output channel mapping, not Leawo's. Weirdly enough, changing HTP-1 speaker config doesn't change Apple Music playback case, either!
So, I tried DL virtual device speaker config: it works only for Apple Music like earlier case of changing HTP-1 speaker config without DLP involved!. And unfortunately, this doesn't work either for Leawo!
I am very confused with these behaviors. Is my assumption wrong that the speaker config change of an output device is 'supposed' to impact the operation of a S/W outputting into it? How can these behaviors be explained, and the channel swap issue fixed?
Yamaha AX-900U
Got a Yamaha AX-900U that wont come out of protection. If I measure the idle voltage i get -38vdc on the right channel and 0vdc on the left channel and neither side will adjust but I think thats because it is in protection mode. Wondering if anyone could take a quick look at the schematic and give some direction on where to start looking.
Thanks,
Phil
Using 0V as the inner rail to improve SOA in a pseudo class G setup?
Just a silly thought, but given that second breakdown is usually an issue with difficult loads, is there maybe something to be said for operating in class G but with the inner rail set to zero V?
The idea is that you could have the output stage run with only say 5V across it, and hence get away with only say 2 pairs of transistors, with the steering diodes connected to 0V so that when in third quadrant the transistors would not see a large supply voltage, the outer transistors then also only need to handle half the total supply (and will be the ones dissipating all the power, but a transistor that only ever sees 70V across it has way more SOA margin then one seeing 140V.
When in first quadrant the outer transistors will of course be burning essentially the same power they would in a conventional class AB stage, the savings come in Q3 when the output is supplying current while trying to pull the terminal voltage the other way,
Just a thought.
For Sale Pro Speaker Drivers
Clearing out my closet of drivers that I will probably never end up using. To simplify things, all prices include shipping within the CONUS and transfer fees. I can accept PayPal or Zelle for payment.
1. Altec 412C 12" Biflex Woofers pair. The last time I had these hooked up, 1 worked fine but the other one only produced sound from the inner cone......$150
2. B&C 12CXT 12" Coaxial pair. These are used pulls from EAW speakers and have EAW part numbers. But I am 99% sure these are B&C drivers. The dust caps were removed due to damage. I just never got around to replacing them. Drivers are 16ohm impedance and will include the custom EAW crossovers.......$250
3. Maxo NE1230-8 12" woofer pair. Open box but never used.......SOLD
4. Eminence Beta-8a 8" woofer pair. One BNIB, one open box but never used........$60
5. Eminence Delta 12LFA 12" woofer pair. Lightly used. Foam gaskets have some deformation from a mesh grill that was attached in front of them.......$160
6. Eminence ASD1001 1" compression driver pair. Lightly used.......$50
7. Eminence PXB2:3k5 crossover pair. Lightly used........$40
For Sale Sequerra Ribbon Tweeters
I have a pair of Sequerra Ribbon tweeters for sale. I bought these from the audio shop I worked at in NY 20 yrs ago but the project never went anywhere.
These were apparently used in one of the Sequerra ribbon systems but I do not have any other details except that they are supposed to reach 40k.
They have the matching laminated core transformers that are obviously very over specd. Also have a spare set of ribbons.
Not sure of the current value however I am open to offers.
For Sale Western Electric 417A and Amperex 5842
Here's for sale a couple of 417A / 5842 triodes tested in my calibrated TV7-D/U:
First unit is a Western Electric 417A, presumed NOS. Tests 120%. Production date code: 5739. Printing excellent.
Second unit is an Amperex 5842, presumed used but testing 110%. Production code is smeared, but reads something like *2A
They come in original Philips boxes as shown, but flaps are partly torn off.
55 USD for the pair, plus 15 USD for registered priority shipping anywhere in the world. If bought in Europe, I would accept payment in Euros at the spot exchange rate.
Paypal Friends & Family or bank transfer.
Cheers
Synchronous motor for TT (24V or 110V)
hello.
I live in Korea.
I'm trying to design an entire turntable
I'm thinking of using a synchronous motor, but I have a few questions.
1. According to the results of my search, the only synchronous motor that I can purchase online is the Premotec 110v motor.(9904 111 81318)
Can you recommend another motor? (I hope it is of good quality and has less vibration.)
2. rega uses 24V, project audio uses 16V, 230v, linn uses 110V synchronous motor.
Assuming the same load and RPM (same number of poles and supply frequency), what effect does the difference in voltage have?
I am worried that if the voltage is high, there will be a lot of vibration.
Thank you.
Marantz CD 17 output Is "low"
Buongiorno, mi chiamo Giorgio e sono in attesa dall'Italia (Savona). Sono un appassionato dilettante. Ho un lettore CD MARANTZ 17 con il seguente problema: con il volume impostato al massimo sul telecomando l'uscita RCA è "bassa" su entrambi i canali
Checked the muting "signal" when the CD Is playing and It Is -11.5 volt. I read that 2sc2878 transistors used as Muting, could easily get destroyed/damage under certain conditions. It Is possibile that despite the signal NO MUTE (-11.5 V) the transistors (2sc2878) perhaps damage conduct a part of the sound to ground and therefore the output Is low ? Where could the fault be ? I don't have and oscilloscope. Sorry for my bad English. Thanks in advance tò anyone Who wants to help me. I am attach the cicuit diagram of the muting marantz CD 17. Hi Giorgio
Low-Cost PMC-inspired TL Monitor with DC130A and DC28F
This speaker started as a spinoff from this thread where I was studying the effects of different levels of stuffing/damping in a TL:
http://www.diyaudio.com/forums/multi-way/281281-pmc-tl-stuffing.html
The speaker that inspired this was the PMC TB-1:
Which has a 48in long internal path TL with the following damping scheme, which I think provides a borderline critically-damped aperiodic TL based on the measurements I have seen on-line:
There was a rather lengthy debate in that thread about whether or not the TB1 follows Bailey's TL approach and whether or not a proper TL should have single or double impedance peak. Rather than debate it, I decided to model it.
I then went on to model and design my own little TL box to study the effect of damping but using drivers I had on-hand: a Dayton Classic Series DC130A-8 5.25in midwoofer and a Dayton DC28F-8 silk dome tweeter. Both of these drivers actually have quite nice published and measured performance specs and are great sounding high-value drivers. You might be hard pressed to find another 5.25in class midwoofer with the same performance for $20. Similarly, the DC28F is an extremely smooth sounding soft dome with low distortion and flat frequency response.
Anyhow, my design constraints were to use approximately the same 48in long TL that the PMC TB-1 has, and about the same physical format. I put the vent in an up-firing position at first, but eventually went with forward firing to gain a few dB of sensitivity in the bass. I also wanted a tuning frequency fb of about 60Hz - 80Hz depending on the damping scheme used.
The design of the TL was as follows with a 6.0in wide internal dimension:
The predicted frequency response for this TL depended heavily on the amount of stuffing inside. Here are 3 cases of light, moderate, and dense stuffing. As expected, each case is a tradeoff in bass extension and SPL for light damping with lower group delay and improved transient response with dense stuffing. The predicted impedance curves go from double peak for light stuffing, to single peak for dense stuffing. The dense case tends to an aperiodic TL.
Light stuffing:
Moderate stuffing:
Dense stuffing:
510972d1445868546-pmc-tl-stuffing-pmc-tl4-dc130a-8-all-stuffing-tight-terminus-freq.png
Here are the corresponding Group Delays for the light to dense stuffing, the GD goes from 16ms down to under 5ms at 50Hz which is about the same as a sealed cabinet, but with deeper bass extension.
Light:
Dense:
510975d1445868546-pmc-tl-stuffing-pmc-tl4-dc130a-8-all-stuffing-tight-terminus-gd.png
Here is the predicted impedance for light stuffing:
Moderate stuffing:
Dense stuffing:
The predicted speaker cone excursion goes from a classic double peak 4th order:
To what you would see in an aperiodic TL or a sealed cabinet:
So these plots intrigued me and I decided to go with a prototype build in foam core. I was aiming for the moderate to dense case somewhere in between. I thought it important to get at least a -3dB point at 80Hz to get a sense of some bass output. I redid the model with front exit vent and the stuffing plan closer to how I will implement it using loosely teased out polyfill. Here is the predicted frequency response with a 2kHz XO and baffle step loses included:
And here is the predicted GD:
If stuffing is added to the final leg, here is the predicted response - about 80Hz f3:
With about 7ms GD at 50Hz:
With a semi-bordering on aperiodic TL impedance peak with a mild double bump:
Anyhow that was the goal and here is the build process:
Stuffing plan (adding stuffing in final leg transforms to aperiodic TL):
Here is the completed speaker:
And here are the measurements using a miniDSP and TPA3116D2 amps for an active 2-way. I am using 1st order electrical HPF at 2kHz on the DC28F and a 4th order BW low pass at 1kHz on the DC130A to get an acoustic XO of about 1350Hz. The slopes are quasi-Harsch and allow somewhat of a time-coherent output. I will refine the XO later but these are just to get started.
Raw measurement of the woofer in the TL running full range:
Frequency response showing XO profiles:
Harmonic Distortion:
Phase:
Impulse Response (there is a slight rise and wiggle before the main pulse due to the time delay on the tweeter to get it to be quasi transient perfect with the woofer):
Group Delay (with 1/2oct smoothing for clarity) is about 6.7ms at 50Hz:
I did take impedance sweeps and they look a lot like the mild double bump prediction above.
The TL sounds very nice - the transients are well aligned in time between the two drivers, the bass is clear and precise without the muddiness of a reflex, the mids are articulate and pleasing, and the highs of the DC28F are excellent - very smooth, transparent, engaging, with no sibillance or harshness. I still need to do more work to refine the XO with careful measurements and simulation in PCD, then transfer to miniDSP rather than doing the XO "by eye". I think I might move the XO up towards the 2kHz point but see that there is additional HD from the woofer there to avoid. If I have time, I may even try to design my first passive XO to see how that looks. Of course it won't be transient perfect given the flush baffle.
I am quite happy with how these turned out and am considering a thin 3/16in Sureply wood baffle to permit the drivers a better mount.
Edit 10/31/15: Polar data shown has tweeter rebated and brillo pad diffraction reducers installed
512027d1446305118-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f-pmctl4-2khz-polar-rebate-brillo.png
Edit 10/31/15 - latest Measurements with 2kHz XO and rebated tweeter with brillo pad diffraction control - sounds great and settings are now"locked down" for enjoyment (and to build stereo pair):
XO plot:
512031d1446307612-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f-pmctl4-2khz-xo-rebate-brillo.png
Phase - +/-23deg over 150Hz to 15kHz :
512032d1446307612-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f-pmctl4-2khz-phase-rebate-brillo.png
Harmonic Distortion - about 1.4% at 50Hz at normal listening levels:
512033d1446307612-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f-pmctl4-2khz-hd-rebate-brillo.png
Impulse Response/Step Response - very nice:
512034d1446307612-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f-pmctl4-2khz-ir-sr-rebate-brillo.png
Group Delay (8.6ms at 50Hz - increased 2ms due to BW1 HPF at 32Hz):
512035d1446307612-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f-pmctl4-2khz-gd-rebate-brillo.png
The Pit Vipers
Hey,
Planning on building the Paul Carmodys The Pit Vipers.
Built a couple of amps and pre-amps with a lot of help from this amazing forum.
Recently got a workshop in my possession so I think its time to make a couple of speakers now when I have the space.
The plan is to make something quite simple and I found the Pit Vipers which seem pretty straight forward.
I do have a few questions though. (probably stupid)
1. What is the best kind of material for this kind of speaker? MDF?
2. The plan that Paul Carmody doesnt specify the thickness of the material. Can I just assume the thicker is better? Thickness would change the volume but not to any large extent.
3. He is using a 6" PVC end cap on the midrange. Wouldn't be better to make a proper enclosure?
4. How much damping should be done? All sides, top/bottom?
Greetings from Istanbul
Hello! My name is Deha.
I live in Istanbul, and I work as a mechanical engineer. I have a strong interest in technology and problem-solving, which aligns perfectly with my profession.
In addition to my work, I have a hobby of repairing electronic devices. This hobby allows me to combine my technical skills with hands-on experience, and I find it both challenging and rewarding. I enjoy exploring new opportunities for learning and development, and I am passionate about developing myself both personally and professionally.
audio analyzer for digilent analog discovery
This looks interesting, especially if like me you're a measurement newb and already have a Digilent Analog Discovery.
Anyone here give it a whirl yet?
Audio Analyzer Suite for Analog Discovery 1 & 2
- THD+N vs Frequency
- THD+N vs Power
- Intermodulation Distortion
- Frequency Response
- Input Impedance
- Output Impedance
- Spectrum Analyzer w/function gen
- Oscilloscope w/function gen
BK
Question about Dissipante inner baseplate
Does anybody know why the CAD drawing for the Dissipante inner baseplate is showing the mounting holes on a 10 mm x 12 mm grid, rather than the specified 10 mm (square)? Not sure if all the files are that way, but definitely for the current version uploaded for the 3U 300.
Really threw me for a loop when I tried duplicating the hole pattern on that thing.
LM3875 with SMD
I plan to build a gainclone, but i want to use SMD as much as possible. ( just for fun and learning soldering at the same time, nothing else )
I have both caps and resistors as 0805, but i wonder if thats enough ?
Do i need some 3 or 5W resistor as anywhere except the one on the output ?
Ahh, it's a LM3875, but that's already in the header.
Hi from Australia
I've been lurking on this forum for a while but only recently made an account. I've been building speakers for about five years now - intially simple boxes, then a large 3-way open baffle system around some Wild Burro Betsy drivers, then Frugel Horn XLs, a self-designed curved line array, some Cornucopya spiral horns, and most recently some Karlsonators that I will post about in that thread once this intro gets approved.
Enclosure width + depth that becomes effectively in-wall size?
If an enclosure is hung on a wall is there a width and depth size that makes the speaker behave as if it is in-wall?
For example, if you have and enclosure that is 6.75 inches deep (1/4 wavelength for 500Hz) can you make it a 27 inch wide baffle (500Hz wavelength) to make it behave as if it was installed in-wall? In other words, whatever depth your enclosure is you need to make it as wide or wider than the full wavelength that corresponds with the 1/4 wavelength depth of the cabinet if you want it to behave as if it is in-wall. Assuming driver generating that frequency range in the center of that 27 inch wide/tall baffle, although, maybe that isn't necessary.
  • Poll Poll
The Best Format
Which music format is best?
  • Vinyl Record
    Votes: 6 30.0%
  • Tape (Reel to Reel, Cassette, 8 Track, etc.)
    Votes: 2 10.0%
  • Compact Disc (CD)
    Votes: 10 50.0%
  • Electronic (Streaming, YouTube, Mp3, etc.)
    Votes: 6 30.0%
So here's the argument: vinyl is best, because it's really actually a physical transcription of audio. Others say CDs - they're clearer. And then reel to reel, cassette, 8 track, and those, I'm not totally sure what all the advantages are there. And now we have streaming, YouTube, Mp3, etc. I guess because it's easier.
So I'll let you take your pick in this poll. What do you think is best?
Opamp rolling for Aune X1s
The Aune X1s dac uses 2 NE5532 for I/V converter and 1 NE5532 for LPF/buffer and I want to change the NE5532s to newer and better opamps.
2 things I have noted from looking at the circuit board so far:
1. The power supply coupling is close to the opamp but not the best practice. The 2 coupling caps are located near pin 8, so the negative supply pin with not get the best coupling. (Please refer to the image i found on the internet below).
2. There is no ground plane or any traces on the bottom layer below the opamp.
I'm thinking of LME4562 and OPA1612 which are unity gain stable, not to high band width, decent slew rate (>20V/uS).
I have 3 questions/topics to discuss as follows:
1. Will OPA1612 or LM4562 be a big improvement or the NE5532 is good enough?
2. Will the OPA1612 or LM4652 be stable in this circuit?
3. Is there any better opamp that suits this circuit. I'm also thinking of something fast like LT1469 or LT1358.
Thank you!
Front panel VFD and control knobs modules
I was looking for a display for my DAC project and found 256x48 VFD displays sold in bulk. They looked good so I bought some and made a PCB with everything needed to power and control it.
Module size is 170x46 mm (display itself is 150x40)
To control it I put a STM32 MCU and since the MCU is already there, it makes it logical to make it useful for process all other front panel knobs: encoders, buttons, leds, potentiometers etc. Of course for a specific build it is better to just put everything on one board but at the moment exact set of controls needed is unknown so I've tried to make it somewhat universal by putting two FFC connector on both sides for expansion modules:
On each of these expansion boards there are 2xI2C buses, one MCU ADC input and 6 gpios (unique for both sides).
Main 12pin header has supply input (5V), and MCU GPIOs. Pins are chosen so that I2C, SPI and UART peripherals are available here. So again, pretty universal.
Schematic is nothing special, it is attached.
I do not have the side expansion modules yet but for my purposes I'm going to have encoder with some LEDs+buttons.
Regarding the firmware: the display is supported by u8g2 library which makes it really easy to do some sketches with lopaka app:
I'm sharing this because I have more such modules assembled that I really need and consider selling these in future, the firmware for MCU is also going to be published.
But I have two questions:
1. Maybe it makes sense to create some 'default' firmware for those who don't want to deal with MCU coding? For example, firmware which receives I2S WCK and prints current sampling rate etc.
2. What kind of expansion modules are needed? Of course it is not possible to make it 100% universal.
Reactions: mgb1965
For Sale DCX2496 pro
Hello, This is a behringer ultradrive dcx2496 pro bought around year 2011. It has been in use for approximately 5 years in that timespan.
Perfectly working. Comes with two long cables . Asking $175.
Shipping to canada at buyers expense.
Rogers LS4a Tweeter Replacement
Hi all -
I have a pair of Rogers LS4a's that I dug out of storage and have finally decided to resurrect. One tweeter is blown.
The original tweeter is a 19 mm aluminum type manufactured by Seas - Model H414 TAF/G. They are no longer available. In my research, about a decade ago, it seems like the accurate replacement became the Model H0532.
However, now it seems that this model is no longer readily available.
Before I reach out to Seas directly, I figured thatI would post on the forum to see if anyone knows of an alternative tweeter that would work well or a source for either of the Seas recommended ones.
Thanks!
Jon
Extract audio from HDMI
My recent upgrade from a Raspberry Pi 4 to a Pi 5 left me without a convenient audio out. So I thought I would get a HDMI audio extractor. We'll I did, and I am disappointed. I thought with this device I could replace my Windows 10 Dell all-in-one that I use only for streaming Pandora. I feed the PCs headphone out to my little 6BM8 tube amp and small near field speakers. I really dig the sound from this,but when I switched to the HDMI extractor the sound quality diminished.
The device I bought is supposed to handle 4k at 60Hz, so I thought it would do a good job. Anyone have experience with extracting audio from the HDMI output? I know it's not ideal, but really, should there be that much difference between these two ways of playing audio from say Pandora?
Thanks in advance,
Roger
Vintage "Jensen" Enclosures
Been a minute since I posted here. I have enjoyed my previous project for years. That project was some modified Polk T50s using a Dayton DAS 175-8 and morel MDT29. I fell in Love with the things I heard from that Morel tweeter, but in some respects the DAS175 has left me wanting for a more full sound. Or maybe it was just the overall path I took. I really should have gone 3 way instead of 2. So now I am going for Really 3 way. You see I came across some enclosures I had to have. Like Vintage solid wood. I think it is Walnut. I am including pictures and would like to hear what path you would take for a 3 way. But 1 st let me tell you the path I am heading into. I am leaning towards a Woofer & MidRange in the vintage enclosure and topping that with an articulating Tweeter enclosure on the top. And I will be at some point upgrading to a better subwoofer system. I want to make the sub system to stand these vintage boxes on for a some tall towers> These vintage boxes are currently 16.875 W x 23.750H x 18D internally. I have looked for weeks now trying to choose a proper midrange to work with the Morel MDT29 and the SB34NRX75-6. I also looked at the 10" SB woofer but this particular 12 can work well in a sealed box. Since I will use a subwoofer system I like the idea of faster transient response from a sealed woofer & sealed midrange. I would make the Tweeter box adjustable for depth and cant and also include the Xovr within that enclosure to the back. So an easy to get to crossover I could play with. Your thoughts and ideas? Would you be more apt to build something like the Gema? ???
SB34NRX75-6 + Undecided MidRange + Morel MDT29 ( or one with slightly higher SPL)
Marantz SA15S1 vs CD50N.
Hi, I have a SA15S1 that is not taking cds anymore. It does but it can refuse 10-20 cds then take one. Been like this for a while.
Also mention that it has extern clock/powersupply, so when it works it sound real good.
I change the lacer 4-5 years ago.
So, now I think maybe its time for a new one, how does the CD50N sound compare to a original SA15S1?
Must step up to SACD30N to sound as good?
Frank
HQPlayer Portable UAC Dongle
Hi All! I’m new here, but I posted this on Head-Fi and Audiophile Style, and I haven’t gotten much traction. I’m curious if folks here have any ideas on how to make this work.
_____
It’s 2025, people, and the world needs a plug and play, headless, “it just works,” Raspberry Pi (or other SBC) running HQPlayer Embedded locally. I know, HQPlayer is supposed to need a small nuclear reactor to crank DSD 2048 with unspeakably complex filters and noise shapers, and I am 100% for that at home, but what about on the road? Hear me out…
The Vision:
I think a lot of us have wandered into the HQPlayer conversation after encountering a product from Chord, realizing that handling of digital signals is absolutely crucial to sound quality, getting addicted to the detail and musicality, finding out about the M Scaler, seeing the price, throwing up a little, and then thinking - “there’s got to be a better way” and landing on HQPlayer. Besides giving Jussi a bit of an ulcer with constant comparisons to the M Scaler and its legendary million taps, this process has also had the side effect of Mojo / Mojo 2 ownership among a large portion of the HQPlayer audience.
The Mojo is in an interesting spot in the audio device stack. It’s certainly capable of competing with most modest to moderate desktop stacks in terms of sound quality, yet it is portable. We have seen a significant rise in quality (and prices) of high end dongles that also compete in this space. Of course, DAPs are also reaching ever loftier heights of technical prowess. We can enjoy incredibly high quality audio on the go, and now that we have heard the benefits of HQPlayer, why are we depriving our portable systems of this essential upgrade. It might have seemed crazy in the past to spend almost $300 on software to upgrade the sound of a portable system, but that’s the going price for a battery base for the Woo Audio Tube Mini, and it’s less than half of what people will pay for a Chord Poly just to act as a streaming endpoint with no upscaling at all for the Mojo.
I travel a lot for work, and when I do, it’s with an iPad and iPhone and either my Mojo 2 or Tube Mini depending on how I’m feeling before heading to the airport. I don’t have a laptop, but I do have Roon Arc with Qobuz and a bunch of DSD and Hi-Res PCM files on my Roon server with my favorites saved locally on my phone. So, HQPlayer on a laptop is not really a practical solution, and a VPN would be fine when I have a great internet connection and everything works perfectly and I don’t have to reset my desktop, but it seems janky and redundant when I’m already effortlessly playing my newest MoFi and Analogue Productions SACDs that I’ve ripped to my Roon server through Arc to my portable DACs.
All that is missing is a little box that sits between the phone / iPad and DAC and magically makes the music from Roon Arc sound even better - no screen, no settings, just switch it on, plug it in, and benefit. Think of it almost like a mini M Scaler or a mobile DDC or a Poly-ternative. It would be perfect in the hotel, at Head-Fi meetups / Can Jam, when auditioning gear at a store, and on planes - Rob Watts has said he listens to his M Scaler + TT2 on planes, which is a totally baller move that I would like to replicate at a smaller scale. There are so many situations where this would be useful, and I think it is possible now. I don’t think this is something that we will need to hassle Jussi to do. As a community, I think we can build it, grow it, evolve it, and share it.
Tools and Challenges:
Frankly, when I started looking at HQPlayer about a year ago, I just assumed that someone had already come up with an implementation like this, and you can see my confused posts on the HQPlayer settings thread from late March 2024 just assuming I was tweaking some setting wrong. After doing a bit more digging, I don’t think this has been done yet. I think the parts are all there, but we just haven’t pulled them together into a coherent package. I have enthusiasm and patience for messing around with things like this for way too long. I have a couple of Pi 4s and many of the necessary adapters, accessories, etc. to tweak and test implementations. I have been building, tweaking, and overclocking computers since about 2001, but I don’t know much about programming, formal computer science, or Linux, though I’m certainly willing to learn some bits and pieces if people can explain a problem to me like I’m five and point me in the direction of the necessary info and wind me up.
Raspberry Pi
To me, this seems like an obvious choice. It’s relatively cheap, it has strong HQPlayer support already, Pi 4 is powerful enough for most anything we would want to do with PCM, and with ultra light modulators, Pi 5 might be able to do meaningful DSD. Pi also has USB OTG support built into HQPlayer OS through its USB-C port. There are numerous HATs like Pi Juice that could be used to provide power through the GPIO pins as well as some limited battery and a separate charging port (suitable for a power bank as well).
We have Pi 4 and Pi 5 to choose from, and for a first run at this, I think we will need to pick a lane here. Open to suggestions, but Pi 4 seems like it will be the more mature system with more manageable power draw and thermals, but I could also understand if people feel that this wouldn’t be worth doing if it doesn’t do DSD, which would be more of a Pi 5 thing, if it is feasible at all at this stage.
HQPlayer OS / Embedded vs HQPlayerd
This is where I am out of my depth. I don’t feel like I have a good understanding of the options here, and I am not sure there is a single place to get a straightforward comparison of the possible implementations. This is a question for a person with significant Linux and / or HQPlayer experience I think.
I nearly have a Raspberry Pi 4 with HQPlayerOS working in this use case, but the jankiness level is extreme. It has played from my iPhone Roon Arc app > USB C OTG > Pi4 HQPE > Mojo 2 a couple of times using the USB C into the Pi4 and the USB A out and the Pi Juice HAT with or without a battery (can just be plugged into the wall for full power through its own micro USB port). It requires access to web interface to start playback from the USB port, however, and this would not be feasible for the intended use case.
I think it is reasonable to configure the settings for filters, shapers, modulators, etc. using the web interface once on a home network. It might also be nice to have a few different SD cards that can be used with different DACs, if, say you want PCM for your Mojo but an AK4499EX DAP might do better with DSD. You could just configure each installation the way you like and drop in the card that corresponds to the DAC / Dongle / DAP you want to use that day.
It is totally not reasonable for this use case to have to log into the web interface and enter a URI just to start the music playing. This seems like the biggest hurdle we face on the software side from my novice perspective. Given the level of sophistication of even relatively cheap dongles using UAC 2.0, I have to think that this problem has a solution, it just needs to be implemented.
In my vision, there is no need for a screen, options, or really any level of configuration while out and about. If we are successful in this first iteration, then I could see it expanding into something much more DAP-like. It could have a screen with options, it could replace the phone and act as a streamer, or it could replace the DAC/AMP with a fancy HAT or possibly some version of DSC-1.
3D Printing:
I’m planning to get into 3D Printing in the near future (I have a Bambu Labs A1 on the way), though I have no experience so far. My wife is extremely crafty and would be interested in helping. I already have a number of ideas for different audio-related bits and bobbles, and I could definitely see making a case for the Raspberry Pi and Mojo 2 together. This could obviously be adjusted to accommodate other dongles / portable DAC/AMPs. We could make the CAD files available for people to edit for themselves.
Future:
A couple of interesting thoughts have crossed my mind here as well. I wonder how long it will be before we have something like a Pi Zero 3 with hardware that could come close to Pi 4 performance. I also wonder if solid state cooling will make it possible to run a Pi 5 fast at relatively high power and performance in a small form-factor case (there will be new demos of solid state cooling chips at CES this year). If we get started imagining together, it’s hard to tell what awesome ideas and use cases we could come up with!
Next steps:
First and foremost, I would love to hear feedback and others’ ideas for how to proceed. Is there a possible direction or solution I haven’t thought of? Is it even remotely feasible to configure HQPlayer Embedded / OS / other version to behave in the way I’m envisioning with no need for user input after initial configuration? If so, can you do it or tell me how to do it (preferably like I’m five)?
I think we need to pick a device to be the heart of this thing and prove that the software can work. If it does, then I think we’re off to the races with testing potential accessories for power, I/O, case designs, performance / temp / battery life optimization / electromagnetic interference management / etc. (these are areas where I believe I can be of great service, more so than with the software).
This project also needs a clever name…
Thanks for reading, and I can’t wait to hear your ideas!
MKT vs MKP
Mods, please remove if discussion about capacitors is not allowed.
I have built some three way speakers with a DSP crossover (Nanodigi) and got them to a point where I like the sound and have decent nulls (good phase alignment). So the next step is to try my hand at a passive crossover.
I have used my measurements and Vituixcad to design a passive crossover which gives a similar response to the DSP crossover I like. However, I do not have a stock of parts so will be buying from scratch. For capacitors, and to mock up a first try, is it acceptable to use MKT (Jantzen Compact MKT Metalized 5% Polyester Film Capacitors) for the woofer low pass and mid low/high pass and MKP (Jantzen Standard) for the Tweeter High pass filters. This would half the price of the parts as a first mock up (compared to using Jantzen MKP Cross Caps).
Thanks in advance for responses.
Looking for some parts advice-NAD solenoid
I've recently sent my NAD 614 cassette deck to a repairer as it was not receiving any power. He replaced the motor and drive belt and has now found that the solenoid controlling the lift/dop of the playing head is faulty. Unfortunately he can't source a new one. He has asked NAD but no luck there. On the NAD schematic it is called Ref 83 Solenoid Assembly and has a parts no. 0000P01030. Does anyone by chance know where such a thing can be had or whether an alternative part exists. Thanks in advance.
improving bending wave drivers
I had read about bending wave drivers a very long time ago but then I listened to a Manger loudspeaker more than 2 decades ago which inspired me to build my own loudspeaker with these MSW (Manger Schall Wandler). I think the main reason they sound better (at least in some music relevant aspects) than almost any pistonic driver is that they have a very wide frequency range avoiding any crossover above the low mids and their very excellent time behavior. But the MSW have some significant issues with uneven frequency response and distortion peaks. I found some improvements by adding Moongel absorption pads to the center of these drivers and I wrote about it, including some measurements, 12 years ago https://www.diyaudio.com/community/threads/manger-msw-moongel.208995/ . This year Manger made some upgrades to that design https://mangeraudio.com/en/discover/blog/press-release-the-new-manger-high-tech-sound-transducer-w06 with an upgrade to the center damper which reduced the distortion (I found no measurements to verify that).
I was also interested in other bending wave drivers and I once visited the Göbel loudspeaker factory to listen to their bending wave speakers. They sounded quite good but were never available for DIY and it is strange that I did not find any measurements of those loudspeakers in spite of the fact that Oliver Göbel originally provided acoustic measurements before he actually marketed that design. His most expensive flagship models don’t even use bending wave topology.
There are omnidirectional bending wave drivers like German Physics, based on a Lincon Walsh invention, but I was never interested in something which has so much room reflected sound vs direct sound.
Bending wave drivers are simulating an infinite membrane as the surround is designed to absorb all vibration. In contrast distributed mode loudspeakers (DML) are using a finite membrane. I played around with some of the Hiwave/Tectonic exciters and lost my interest fast in DML. I also considered BMR drivers almost as a hybrid with a pistonic driver and a vibrational device but after testing some of them it also did not divert me from real bending wave drivers.
Manger MSW uses a round (semi) soft membrane material with a star shaped damping structures in the periphery and a central damper. Göbel uses a stiff rectangular membrane with damping laser cuts on the periphery.
I started playing with the bending wave driver concept at least 2 decades ago but about 10 years ago I thought my design sounded better than the MSW when I replaced the MSW with my design. Still, I am playing around with different components, so I think I will never be done tinkering, but I think I should publish something now. That will need to be more than one single post.
There are two main components to a bending wave driver: the membrane and its damping surround and the magnetic motor /voice coil design. The goal is to activate all frequencies evenly and prevent any back reflection which would cause interference.
One issue with the majority of loudspeaker drivers, including the MSW, is that the voice coil is round and concentric to a round membrane, having a constant distance to the perimeter and to the center leading to more specific vibrational modes. I decided to use a rectangular/linear voice coil which has varying distances to the perimeter distributing vibrational modes. I also found that using any shape of membrane with corners like a rectangle causes strong modes which can not be efficiently damped.
This is my recent test speaker enclosure, the walls are made from flax composite with a balsa core. The driver plate is made from an aluminium sheet laminated to Richlite panels with Loctite viscoelastic glue.
Here is a frequency response of one recent version (Fuzz Measure in room at 0.3m)
Step response (the negative dip before the rise and some of the small ringing at the peak is measurement microphone dependent, this is with Umik 2 and Umik 1 looks different there, otherwise identical)
A lot more detail to follow in additional posts, slowly
[3D Print] Chassis Feet (Various Designs)
Over the coming days I will post more versions of various chassis feet here for anyone who has access to a 3D printer to download and try out.
Here are some posts I've made previously for 3D printed chassis feet.
Bare Board Feet (ACA Mini slide on over Hex)
Bare Board Feet (ACA Mini, or others using M3 bolt/nut)
Bare Board Feet (Zenductor II)
Modushop Feet Risers (fits inside standard Modushop plastic feet)
Here's the latest version I made based on dimensions of a commercial chassis foot for sale. You want to print using soft TPU (Thermal Polyurethane) to get close to the squishiness of rubber. Additionally, TPU has some grip (not as grippy as rubber, but works fine), whereas harder plastics like PLA and PETG are slippery and could scratch more delicate wood surfaces if used on heavy amps.
Suggested TPU Print Settings for Large Chassis Feet:
  • Temperature - Depends on your brand of TPU (I use around 220°C for mine)
  • Walls - 2, or 3
  • Infill - Gyroid, 15-20%
  • Top/Bottom - Increase top to 8 layers at 0.2mm/layer. Feel free to do the same with the bottom layer if you don't mind a few extra minutes of print time, but not critical since it's in compression.
  • I suggest using a glue stick for the plate adhesion, but if you know what you're doing, it's not critical to use, just a safety blanket for me since I print on flat glass.
Here's a picture of completed "Chassis_Foot_PrtsExrs_Clone" set with one that failed to finish printing showing the internal "gyroid" structure that gives it extra "squishiness".
Here's the dimensions of these large chassis feet mimics from off the shelf rubber options.
3D prints -- enclosure parts and a coax stripper
Attached you will find a small collection of 3D printable parts I have found useful when building or asembling enclosures. I have a board-mounting block, handy in situations where the PCB mounting holes aren't quite where you want them; a foot (I use peel-and-stick felt dots to cover the hole and prevent scratches), a couple of knob designs, and my version of a coax stripper that uses utility blade cutters. The knobs are a little unusual because I didn't think the plastic would be robust enough to avoid stripping-out the set screw threads. I got around that by using a short length of brass hex stock. It's drilled on one end to accommodate a pot or switch shaft, and drilled/tapped on the side. The hex piece is glued to the knob to fix it in place, and the hex form adds additional strength, in terms of torque. Pots are pretty easy to turn but switch shafts can require more torque to turn them.
I also like the visual appearance of the brass, but it would be easy enough to print a blind hole if you don't want that look. I'll add an STL of one with that feature to this thread.
The only tricky part about assembling the knob is keeping the glue away from the set screw hole. A drop of CA glue will do the trick.
Cheap Compression Driver Improvements
I bought some cheap used compression drivers on ebay. They are the eminence nsd2005-16. i chose them because they have a 2 inch diaphragm, a 1 inch throat and a factory fs of about 578hz. not to mention i bought the pair for $90 shipped. I'm not one to spend a fortune on audio and i figured it was a good place to start. Once ia recieved the drivers, i printed a horn to test them in; the ath a520g2 with extended throat. I also printed a couple metamaterial rear chambers and picked the best of the two. then i added aquaplas to the diaphragm wihich i also purchased from ebay for $23. here are the results.
factory rear chamber, no aquaplas
Metamaterial rear chamber, no aquaplas
metamaterial rear chamber, 1 gram of aquaplas
a lot of this is below the noise floor of my rather noisy ifi zen dac but its what i have at my disposal. i havent listen to music with these but the sweep itself sounded noticeably better. the only problem i see is a deeper/wider notch @ 14k. idk why this is. it could be that i dimpled the diaphragm while applying aquaplas. it popped back but this is a lesson learned. when i get around to the second one i will be more careful and hopefully it wont happen again. then we can see if there is a difference. otherwise i consider this a success.
For Sale UK - Seas A26 driver set: 2x A26RE4 & 2x T35C002
Several years back I built a pair of ‘child safe’ Seas A26 inspired loudspeakers, in large cheap IKEA cabinets with heavy duty steel grilles to prevent little fingers reaching tweeter domes. Following a house move the time has come to get these out of the house. The drivers are in very good condition, have never been driven hard. The cabinets are functional but not very attractive. I built simple crossovers following the A26 design, but with small / low power inductor etc (intended to get me up and running, but I never went back to do a better job).
Will follow up with photos later today.
Open to any offers for the driver set. Happy to provide the basic crossovers too, but I’d suggest that anyone building an A26 or similar Devore style speaker should plan on redoing these properly.
Collection from Edinburgh would be welcome, but I can ship drivers within the UK if costs are covered.
Ping me if interested. Happy holidays all!
Most euphoric high-end midrange you have heard?
What is the most euphoric midrange you have heard? So far I have heard KEF Reference, Dynaudio Contour, Accuton, Seas, and B&W Kevlar.
Based on my experience hard materials sound more similar than different. The higher the young modulus the brighter and more revealing the sound. An excellent goal when the source equipment and music is well recorded. Putting a state of the art measuring DAC will be heard on these speakers. But soundstage will not be artificially expanded and nothing will sound better than what it is. If you are in audiophile with refined taste in well recorded music and top of the line equipment then this is for you.
Poly isn't so much euphoric as it presents a softer tone and sounds more expansive. Giving up ultimate resolution, perhaps changes of equipment are less noticeable but it makes most content sound more listenable. I assume most soft materials are like this.
If my personal preferences tend towards the euphoric and not the audiophile. What paper midrange is most likely to please me with a Sonus Faber type sound? Sonus Faber uses Kapok and Kenaf. On the DIY side we have the paper Revelator, Illuminator, Purifi, Satori, Seas Nextel & Acoustic Elegance.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,786
Members
7,888,453
Messages
Filter
Forum Statistics
Threads
406,240
Messages
7,888,453
Members
507,786
Latest member
alexhmao
