Transformer laminate rust removal?
I probably should have said that they are loose plates. Sorry.
^ Absolutely true! In addition, rust means bulging, the lams' total volume increases, you'll expect issues while packing the correct number of lams into the bobbin.
OTOH, just surface rust on a complete lamination stack isn't any problem at all, electrically spoken.
Best regards!
True, hopefully attacking the rust first. Then neutralize and treat for corrosion. The vinegar is acting very slowly, which is good, but its quite a bit of surface area. I wonder if black oxide would be a good idea? And another question, does the hardness of the material change its sound? I could easily harden the plates to any hardness. Soft, to tool steal.
