Heater current draw question.
I am working on a pp am build, parts gathering and circuit decisions.
I my power transformer rectifier heater winding is rated at 2 ma and the rectifier I would like to use has 1.8 ma draw per data sheet, am I stretching things with this load?
Or if rated at 2ma it's good at 2ma?
Just wondering what rectifier?
The closest I could think of would be a GZ34/5AR4 having a heater current of 1.9A.
In any case if it's a 5V heater, be aware the the heater winding will be floating on B+, so must not be connected to anything else.
6d22s.
Just re looked at the data sheet.
1.9 amps
Separate windings for tubes vs rectifier.
The 6D22S was originally a tv damper with 6.3V indirect heaters.
https://frank.pocnet.net/sheets/164/6/6D22Sspec.pdf
The datasheet even allows heaters common with other tubes up to 600V B+.
Remember, the top cap is the cathode and goes to B+.
Also you should be aware that a single 6D22S is only a half wave rectifier.
In which case you get DC in your HV transformer winding which will saturate it's core and cause it to overheat grossly.
For a full wave setup you need at least a second 6D22S tube and a center tapped B+ winding.
And another 1.9A of heater current, so a total of 3.8A ...
So I'm am using 1 half wave rectifier tube and two diodes forming a center tap.
Bright is the wrong term?
The tube in the picture is not a half wave rectifier.
It has 2 plates, two diodes with common cathode in one bottle.
That works.
But both 6AU4 and 6D22S have only one plate.
For your hybrid bridge you either need 2 tubes with one plate each
or a single rectifier tube with 2 plates ...
Reactions: mr ed
