"Grounding" LM 3886 (and other chipamps
I have read through a number of threads about the LM 3886 and the design of the PCB to mount it on. One much discussed point concerning the grounds on the PCB´s concerns the power ground and the large currents going through it and the possible problems of havoc that can be caused by this if done wrong.
Most of these designs have the same or a very similar sequence of connections on the edge opposite of where the LM3886 is mounted and which is , from left to right : negative rail , ground from psu , positive rail , then speaker out + and speaker out - , and then the input and its ground.
So forgive me if there is some error in my reasoning and explain why , but based on my long years as a tecnician and working with discreete amps mostly ,what speaks against forking the input ground trace going to the center of the caps adding the speaker out ground there ? This would change the sequence of connections as follows and would keep the high currents completely away from the rest of the PCB , along with the associated problems ? And all other grounds remain as were....
Sequence then would be from left to right : negative rail , ground from psu , speaker out minus , positive rail , then speaker out + , and then the input and its ground. As is done mostly with high power discreete amps the speaker ground then returns directly to the juntion of the filter- caps . Board size stay the same and could possibly be further optimized. I cannot judge that as I have no experience with it except of what I learned reading in all the threads.
If I am , for whatever reason , wrong please correct me Thanks Michael
elac design flaw lm3886?
Hi.
I been helping out and repairing several elac active speakers.
they have a lm3886 which amplifing the tweeter and tip41 and 42c for the rest,
there is also a tda180 circuit which i dont really understand,
but the problem is that the resistor gets really hot connected on the negative rail to ground.
also had a lot of capactors bad which is replaced.
the negaive vee supplying the lm3886 and tip42 plus tda180 which connect directly to ground with a 2w 500ohms resistor. get burning hot, and it measures 25 volt over it.
I looked at other circuits but cant see any using 500 ohm, on the postive side I measure 9k ohm to grund.
any idea?
best regards after midnight in norway...
Niklas.
Fairchild 670 Drip Time Constraint PCB's
Hey Everyone I need some help
I purchased a Drip Electronics Fairchild 670 board back in 2013 for $400usd. I received the board from Gregory at Drip, but he forgot to include the Time constraint Pcb's in the order. I have been asking him for the missing Pbc's for almost 8 years now, and he always fails to get back to me, or says he'll take a look with no follow up..... I guess i'll just go **** myself then..... (sorry my rant is over) :redhot::redhot:
I'm at the point where I have to get them printed myself from another company to finish this build. Anyways I thought I'd turn to you all. Does anyone have the time constraint pcbs, that can send me a picture. Or possibly a schematic for the time constraints. Anything would help at this point.
Thanks for your help
OTL tubes amplifier based on the ecl84
Who said tubes amplifier had to be warm and lush ? This one certainly isn't 😀 I've got a prototype of this amplifier working on my bench and it has serious slam.
It is based on conventional building blocks: mu-follower for the gainstage, white cathode follower for the output stage. The little triode in the ecl84 has some serious gain, which compelled me to use a relatively heavy feedback to take the gain down. The trioded pentode sections are run pretty hard at 170V and 25ma each. The tubes aren't very expensive but I'll try to run the amp a bit colder in the long term (something like 160V, 23ma). Into a 300ohms load (headphones in mind are AKG K340, senn HD600), it translate into more than needed power.
All the coupling caps are mkp, resistors are a mix of 2W and 0.6W metal film, depending on position (and applied voltages).
attachment.php
The power supply is coming straigth from tubecad's website, with a small twist to use 200V rated caps on a 380V supply. The heaters are biased somewhere around 90V. I use AC and it's silent (no hum) with high impedance headphones.
attachment.php
Kinergetics Chiro C-500 Amp problem
Been trying to restore this 5-channel amp for a while, BUT the main power PCB has several missing traces (delaminated and gone bye-bye. No schematics seem to be available.
If anyone out there owns one of these amps and is willing to take a few photos of this PCB, I'll be able to have a working amp. Would be happy to pay you for your time & efforts! It is pretty easy to get to and I can give you some simple instructions on opening it up.
Thanks!
Ivan
Jose Duddy New Member
Love Android and Google. Installed new car headset Android 9.1. I am a singer and entertainer and Android is my hobby. 26 wifi philips light bulbs. 5 google minis, 1 google hub max, 1 original google home. 3 google chrome cast 4k, 1 nest doorbell, 1 outdoor nest cam, 1 nest thermostat, 1 Nest X Yale door lock. Needless to say I have built a google eco system...lol.
Thanks to everyone.
Please direct me to a forum to discuss Android Car Headset, and installs and upgrades.
Android car headset 9.1 - Google Photos
Why do these B&W metal domes sound so good?
I'm trying to understand why these B&W tweeters don't have that typical metal dome harshness? They sound alot like planar drivers with very detailed upper top end and never ever get nasty even at very high volume levels. I usually can pick up on the ultrasonic response peak by ear listening to the upper piano notes or cymbals but these things don't sound like they have any breakup mode even though they should. I don't have a good enough measurement mic that has the frequency respose to measure that high where that peak usually resides. Maybe the acoustic lense has something to do with this, suppressing it?
I have the same tweeters in my B&W DM580s. They have better midrange and top end than some $5000 speakers I've heard. I'm baffled by how much dynamic reserve these things have being a 2.5 way design. They are crossed over fairly high around 3.5k 3rd order, so that probably has something to do with it, plus they can play as loud as some larger 3 ways. I did rip out all the old electrolytic caps and installed PP caps which made a massive difference everywhere.
So I just wished I knew the secret to why these tweeters are so good. I have a pair of Thiel tweeters made by Seas that sound similar, but not as open and dynamic. I used to turn my nose up at metal domes, but these B&Ws converted me.
D Class IC amps, are they safe without a heat sink?
I'm new to this so please forgive my noob questions
I'm building a ported boombox style speaker from ply with all my components boxed in. I've had a D Class IC amp in the past with a heat sink, it was only 15W per channel but it got really hot! I placed it near the ports so it got good air movement and everything seems fine.
But for this project I'd like to build something 50W per channel with D class IC amp but a lot of the suppliers don't have a heat sink attached and I'm wondering if I need to attach my own? Can I place it near the ports without a heat sink? Or is it just fine to box it in a separate compartment and forget about thermal management all together?
Thoughts?
Thanks 🙂
PINK TRIANGLE PT TOO PSU PROBLEMS
Dear DiyAudio:
I got a PT Too for trade, but with issues. The last owner told me that it didn´t work, and I have now taken it apart.
It works, although not properly.
I know this doesn´t fix the bug, but:
-all electrolytic´s replaced
-rectifier replaced
Just to be certain the problem isn´t there.
But:
When trimpot on the right is turned to max and the trimpot to the left is turned to min, the motor runs quiet and as it should on 33. But when switching to 45 the motor just vibrates, not turning. When turning the left trimpot clockwise to 10 o´clock, the motor runs as it should, but now it just vibrates on 33. I have measured the two voltages at the motor (33/ 45) and it´s aprox 90V and 107V (when adjusted to the right speed with trimpot left). So the problem is that it´s not possible to adjust the trimpots to work on both speeds.
Anyone familiar with this?
Thank you in advance!
Reverse engineering of famous chassis
Hello, everyone,
it all began at my friend’s request to do the CAD model and detailed drawings of the Audia Flight Strumento N1.
Over time, I’ve done the same for several chassis (Goldmund Telos, Vitus 103, D’Agostino Relentless, etc.) and Kyron Kronos body.
Some of them are adapted to the use non-original components (Strumento’s buttons, Kyron’s tweeter and mid-woofer) but otherwise my models are exactly the same as the original.
A few images of projects and, particularly, their realization, could be find below.
So, I can create 3D models, containing complete details and fastenings, of famous or less-known 😉 chasses. Having a model and drawings, you can produce them in any workshop.
I must add, reverse engineering doesn’t infringe anyone's copyright.
  • D'Agostino 2:3.png
    D'Agostino 2:3.png
  • KYRON 3:4.png
    KYRON 3:4.png
NOS tubes for sale VT25, 6V6
Hi there,
I am selling the following:
Pair of VT-25, NOS in original boxes. Asking $140.
Pair of Jan-CTL_6V6GT/G. NOS in original boxes. Asking $80.
I will ship to USCON only for $15.
Free To Good Home
XKi for W5-2143 free to good home. I threw this together a while back and never did anything with it. Have not cut wings yet but everything else is done. Even lined with 1/2" felt. Would prefer DIYAUDIO member in DFW Texas area to pickup off my front porch so I don't have to ship. PM me if interested. Thanks.
DIY 12V Car audio power supply - troubles
Hello everyone!
It is the first time that I publish in the "power supplies" section.
I am building a switching power supply to be used in the CAR AUDIO field, feeding it from the wall network, obtaining an adjustable output voltage from 12.4v to 14.4v (and beyond).
I made a project from scratch.
The power supply uses the SG3525 PWM controller which drives an IR2113S driver which in turn drives a pair of very powerful IGBTs.
The power supply is regulated, and keeps its output stable even when we are absorbing almost all the deliverable current (or at least it should) and through a potentiometer that adjusts the reference of a TL431 which in turn drives the LED of an optocoupler, I get voltage regulation and setting.
I made the PCB and installed the main components to start testing it, currently I have not installed the protections (short circuit and thermal) because I was interested in knowing if at least it did its primary job (produce enough voltage and current as I thought it would).
After doing everything, instead of immediately using the direct electrical network, I used a transformer to isolate myself from the electrical network and obtain a lower voltage to avoid disastrous failures, in fact, with 78Vdc on the large capacitors, everything was fine, the power supply produced the voltage desired, but obviously little current, in fact by loading the power supply with a 40w car bulb, the voltage dropped to 7 volts.
So, I used a bigger isolation transformer, and with 110Vdc on the big capacitors, still all right, and the voltage was also more stable, the current delivered, higher, and the voltage dropped a lot less (down to 10v).
Everything seemed ok to me, there was no abnormal heating anywhere, so I switched to direct mains, first with a 220V - 40w incandescent bulb installed in place of the primary fuse and I got a lot more stability, but obviously when trying to absorb more current, the bulb started to light up and choked everything, then I replaced the bulb with a 47ohm 10w resistor, and I still got some improvements, then finally I decided to remove everything and install the fuse, now the problems started, because the power supply turned on without problems, but as soon as I connected the car bulb in output, one of the two internal diodes (of one of the 2 double power diodes) spontaneously shorted out suddenly, and having no protection systems I broke the two IGBTs and the driver accordingly.
Cabbage! everything was going well, I would have also installed the protections and I could have fully tested my power supply, but something went wrong. Maybe the output filter? Perhaps the absence of Snubber on the output power diodes? It wasn't just a coincidence, because I fixed everything, and it happened again. I will post the schematic and some drawings of the waveforms that I saw on the oscilloscope before the failure, I have drawn them by hand, because it all happened yesterday, and I did not have the thought of taking pictures of the screen.
And of course, this is the videotest:
video
thanks to all,
Aids are appreciated!
Mario
hum resolved (hope it will be useful)
The subwoofer I built (described in a previous post of mine) was starting to make an annoying hum.
The connection of the ground cable to the signal terminal was loose. Once the cable was fixed, the hum completely disappeared.
I forwarded this post because it was not easy to understand the problem as everything apparently worked.
I hope it will be useful.
Affordable(?) 3-way
I’ve been intrigued with the Philharmonitor BMR reviews, but had no desire to part with that sort of money, so I put together a pair of 3-ways using Hivi RT1.3 tweeters that Santa brought, and my Nomex 6.5” woofers that I have had for ages. I did splurge and bought a pair of Tectonic BMRs for midrange.
I salvaged and reconstructed cabinets from some TL enclosures, 8” wide and 12” deep.
I went totally active with the aid of a couple of Minidsp 2x4s. I already had one serving my LXminis.
I picked up a a Rotel 100w x2 amplifier for $60 on CL to go along with the NAD 7100 and 2155 that I used with my LXminis.
Crossed at 900hz and 3500hz LR4 and with a little EQ, they sound really good.
Very impressed with the mid driver, which I played full range for a while before final assembly. Female voice is to die for.
I’m going to replace the woofers with Dayton RS180p-4 since the Nomex drivers belong in my 2-way speakers. The Daytons are on sale at PE and may provide a little more low bass.
Stay safe and keep building.
Peter
general and specific amplifier building questions
Transformer secondaries are 24Vac, recommended fuses 6.3A slow blow, 25A rectifier, 10.000 µF first cap, 140.000 µF second cap.
The toroid only 300 VA for mono, no inrush current limiter needed.
For raw testing I would like to keep it as simple as possible.
So the obvious question is, can I turn that on without blowing something ?
Does it make sense to put a 5W 0,33 ohms resistor between the caps ? and will it withstand power on surge ?
I could cut the 140.000 down to 120.000
Linear L-240 recap and...
Hello team, I've lurked on various audio repair forums a long long time. I'm finally ready, (I think) to get involved in a recap.
The subject at hand is a NZ made, likely in the 'heyday' for these vintage amps we know and love. Linear L-240 is the manufacturer and model.
The only 'data' I can find on this amplifier is here:
Happy birthday L240 • Heat • Public Address
Manufacturer may be mentioned here:
LINEAR Electronics Ltd Auckland New Zealand | Audiokarma Home Audio Stereo Discussion Forums
So the hopes of finding a datasheet are slim to impossible. Cool. Now I'm fairly new to soldering, but have access to a slick temperature regulated iron and I've been reading the how-to and tips for years. I think I'm ready to tackle a project. I also have a few friends who do this professionally, so I have the luxury of a few guides.
Now the amplifier worked momentarily, then began a feedback noise coming through. I suspect its the big capacitors in the power section, but as I'm learning, I would like to go through a full recap, to get a bit of practice in.
I've made a list of the capacitors. Are there any other things I should look at replacing? I've done some reading that suggests as long as capacitance remains the same, upping the voltage is okay. I've also read suggestions to keep the physical size of the capacitors the same, so that the legs pop in the circuit board without much mangling.
How would I go about measuring my current capacitors size to compare to the modern day offerings? Is there a physical sizing guide? Use a micrometer? Just a ruler for height / diameter? Are the physical sizes listed of the capacitors on mouser and such?
Any other challenges you wish to point out are helpful too.
I've included a couple photos of the project.
Dustin
Nikko 220 mica insulators
Hello folks....I'm currently trying to refresh my Nikko 220 amp with a recap and I'm having a hard time finding replacement mica insulators for the power transistors. They must fit a 2SC2565 transistor as an example this being one of them. The old insulators measure 38mm long by 20mm wide with holes centred 25mm between. If I can't find new ones I'll have to clean and reuse the old ones but I'd rather not do that as one of the old ones is cracked. I've done a Google search and checked Mouser but can't pin it down to a correct one. Any help is appreciated.
European El Cheapo-ish build
In another thread (https://www.diyaudio.com/forums/tubes-valves/362926-stereo-tube-amp-build-advice.html) I asked about advice for a first tube stereo amplifier to build. Gladly a lot of people joined. After quite some switching back and forth and after extensive reading, searching and preparation I've just received my first goodies. Sourcing took a lot of time...
I chose some nice transformers from Amplimo; not El Cheapo. Not a dozen emails of every step in the delivery, but it was at my doorstep in no time. The packaging was top notch and they included a printed datasheet of the transformers. Perfect.
Attached you'll find a pdf with a lot of info I collected mostly from diyaudio threads and the original El Cheapo thread. It's not completed yet, just like the rest is not perfect.
I've also made my first PCB, which I'm planning to send to Aisler for manufacturing.
I've made the schematic in diylc as I've done before, but also in kicad once I thought a PCB would be nice. I also made a layout, not nearly as detailed as I would like, but I needed some hardware to make it more tangible.
Lastly, I made my first CAD drawing in QCAD. I've had good results with just printing (previously using inkscape) that to scale and stick it to the chassis for drilling. I've tried CAD programs before, but they were not my cup of tea. Somehow QCAD seems a lot more compatible with me.
I plan to keep you guys updated with the build progress.
In the mean time, any comments are appreciated. It's my first stereo amp build, so I can use the help.
  • ElCheapo.pdf
    ElCheapo.pdf
ARTA and USB interface
Greetings all,
I need a new microphone, and doing my due diligence, I came across a reference, claiming that certain measurement software, namely ARTA, has problems with USB interface, e.g., when doing averaging.
So I am now considering a non-USB microphone. As I understand, they need a phantom power and perhaps an amplifier.
Are there any stringent requirements in regards to the phantom power, e.g., noise, or will one based on 78XX series regulators work? And what about the amplifier?
I am looking at the EMM-6. Any other recommendation?
Kindest regards,
M
Parallel Primary Inputs of Two Different Signal Transformers
I want to 'split' a balanced line signal so I was thinking of doing the following.
Balanced Line Output > 2 x 10k:10k Transformers > Separate Outputs
The balanced line output would be common for the primary inputs of the two transformers.
  1. Do you forsee any issues with this configuration?
  2. Will the input impedance of my system become 5kOhm? If so, what will be the output impedance now?
Optical or Coax Input to DAC
I recently ordered a couple of DACs and I've only ever used the internal ones in various devices.
If I use one on my computer, I'll obviously use the USB input. But what about other devices that have both an optical and coax output. Is there any reason to choose one over the other?
I'm sure there are technical differences, which I'm interested in, but I'm mainly concerned with any audible differences.
Does it just vary depending on the particular DAC, in which case you just try both and listen? Or is there some consensus 🙂rofl🙂 that applies to DACs in general?
How to get rid of hum in a 6AS7 Headphone Amp
I am in desperate need of some help. I would be very appreciative of anyone who can help me solve a problem with hum.
First, some background. I built the following headphone amp and it works perfectly, no hum.
Nobsound 6N5P+6N11 Vacuum Tube Headphone Amplifier Board DIY KIT Single end Class A Amp|Amplifier| - AliExpress
Next I got more ambitious and built the following headphone amp:
A Single-Ended OTL Amplifier for Dynamic Headphones. – HeadWize Memorial
This headphone is almost identical to the first. The amp part I built is exactly as in the Headwize link. The power supply for the filament is identical to the one from aliexpress. The high voltage power supply is a custom based on a bridge rectifier, followed by 47uf cap, followed by 50 ohm voltage dropping resistor, followed by 330uf cap, followed by 50 ohm voltage dropping resistor followed by 47uf cap. I have separate transformers for both filament and high voltage. The negative of both transformers is connected to circuit ground. The high voltage supply is on a separate board. The filament supply is on the same board, but on the other side of the board. the filament transformer is about 2 inches from the 6AS7.
The problem is that the Headwize amp has a severe hum. The hum is the same no matter what the volume is set to. The hum starts about 30 seconds after power on. If i turn the power off, the music continues to play for a few seconds without any hum. Also, I tried using 4 D batteries for the filament supply and the hum went away.
I have tried everything I can think of to solve this problem with no success, so as I said in the beginning I would greatly appreciate any help I can get. I used high end parts in the Headwize amp, hoping to have a better sound than the aliexpress one.
Pcm2902 sound good!easy use!
My friends told me he need USB DAC for computer record and KARAOKE with computer,I have use Roland UA-25ex many year,they have good parameter,
but I believe it so expensive.when my friend asked for me design USB DAC,I connect TI FAE,he suggest PCM2902 is excellent,cheap and good sound.So i works for it 2months,Test today ,sound excellent.I'll upload picture as attachment.
Friends on diyaudio have question why changing song there are POP sound,I found why!due to pcm2902 out signal need cap for dc isolation,you can try it once time,If you still have same problem,please mail me.
2type,one have 48v phantom power supply and combo XLR,other simple no phantom power only use XLR for banlance input and output.
Neurochrome DG300B Modified Build
I have had a set of boards for this amplifier for some time and I have finally started the build. I have some questions about the layout of the amp. Some background:
I am not an engineer (I am a nurse!) and this is my first project. Please do not assume that I know much.
The output valve will be the 6c4c which is a 7-pin version of a 2a3 and not the original 300B. I will be using the changes to the circuit detailed in Tom's build notes. I will also be inserting a Tribute AVC before the driver stage, making the amp a single input integrated. More on the AVC later.
Power transformer is a potted C-core from AEE. Output transformers are Tribute which I was very fortunate to get. Without testing my plan is for the Power transformer coils to be orientated front to back (so top to bottom on the diagram), OPTs left to right.
Top plate will be 450mm wide, 350mm deep. I have the aluminium already so not much scope for changing this. The Power transformer is 125mm square, the OPTs are 90mm square. The AVC is 50 x 50 x 100 and does not fit under the valves/PCB (amp becomes > 130mm tall which is too much for me)
Below is a very simple diagram with a proposed layout. The rounded square on the left is the Power transformer. Two squares top right and bottom right are the OPTs. Rhombus represents the 4 valves with 6c4c top and bottom, input valves (6n6p) left and right, each vertex representing a valve. These components are all on top of the aluminium top plate. The vertical rectangle between the OPTs is the AVC which is under the top plate. There is not quite enough room to fit the valves between the OPTs (OPTs are 90 x 90mm, distance between outer edges of 6c4c valves in Tom's boards are 164.3mm, the long axis of the rhombus). Call this Option 1.
Option 2 is to leave the Power transformer where it is but flip everything on the right side so the valves are now on the right edge and the OPTs and AVC are now moved approx. 80mm towards the centre. This has the advantage of getting the small signal valves further from the Power transformer but it is not as aesthetically pleasing.
These two options have the advantage of placing the inputs of the PCB closest to the rear panel, keeping wiring short.
Option 3 has OPTs back in the corners on the right side but would rotate the valves through 90 degrees so the valves can now sit between the OPTs. This also rotates the PCB under the top plate so the signal path from the input sockets to the PCB is now longer. Option 3 maximises the distance of both OPTs and valves from the Power transformer and could be the most aesthetically pleasing with the possibilty to have the 4 valves symetrically arranged between the two OPTs.
Any obvious preferences in these 3 options or is there something better I have not even considered?
Universal Remote Power Supply
Hey team,
Quick question for those who have enough in the mind palace -
I am itching to produce a universal dual mono supply in a chassis - to be configured with umbilical to compact heatsink-ed amp chassis....
So, let's say I wanted to build on PSU to power the following (theoretically): Aleph J, M2x, and F5T builds.... 2x600VA yielding 32V rails? seems perhaps a bit high for the Aleph, but can be biased down... is it too low for the F5T?
I'd love this so I can continue to build and swap around without incurring higher amp chassis costs (bulk) as well as Transformers, and the like.
FWIW, I rummaged around the forum a bit, but there is since there are differing directions on rail voltage, maybe someone can chime a solve-all answer in.
Thanks in advance!
300B LTspice model, SE with A-A feedback
I have a 300B and it is very dynamic and so on. But amplification is a bit high.
The trannie is LL2752.
So up came the idea of a internal feedback (anode-anode, not across the output transformer.
This is the basic idea:
The lower freq limit is lower than the -3db of the input (should be 25) but is modelled as 43 Hz. is fine with me. Lowering will give a little rise in the Va curve at the bottom end.
The high freq is quite high, at 80 kHz simulated.
Without feedback I get 8 Hz. And some 30 KHz. measured.
With different drivers I sometimes got 60 KHz measured,
any comments?
Illustration of critical inductance
When using a choke input filter after a rectifier, some people prefer a multi-section filter, for example, L C L C: 5h-20u-5h-20U because it should reduce hum more than the same total L and C quantities used in a single section LC filter such as L C: 10H-40U.
Because the critical inductance depends on the minimum current to be drawn, it seems better for overall regulation when the minimum current is small, to use the singe section filter and put all the inductance before any capacitor filtering.
This would be for anode supply of class AB circuits having a low idling current, and in instrument-type regulated power supplies that have a wide range of load current. It should help to keep the no-load voltage from rising so much.
Parts on hand for this project are two 5H inductors and two 20uF capacitors. How to arrange them?
The chart shows data from PSUD for a proposed high voltage supply. The program was run using constant current loads from almost zero to 2A.
It shows that a single 10H choke followed by a 40uF capacitor gives better voltage regulation at lower currents (0.25A) than a two section filter mad of two 5H chokes and tow 20uF capacitors.
I hope this makes sense. I wish I had a 20H choke or higher that would take the current.
isolation/support for HEAVY Altec vot
Hello,
I am looking for some diy solution or non audiophile price ( so general purpose) so isolate my Altec Vot cabinets they are above 100 kilogram( 220 pounds) . I have no way to check the weight. So it could be a bit higher. Maybe i will add a bag of sand on top lol but i need something to give a better isolation than the rubber wheels.
Something like a ''pile '' of 4 square inch of 3.5 mm 1/8 inch thickness cork ''sheets '' like the ones on my wall or get some thicker cork panels normally used for temperature/sound isolation? I can make a sandwich of cork and lead sheets.
Any ideas are welcome.
Greetings,Eduard
Replace ALPS Pot on Rega Mira
Hey all,
Did some digging online and I haven't come across a thread on this that I could find.
Anyone ever replace the volume/selector switch ALPS Pot on a Rega Mira series integrated? I've seen the scratchy intermittent switch is very common, but I've never seen an actual replacement solution.
Does anyone know if this would work?
ALPS 50KAX2 50K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
Thanks for any thoughts or experience!
MOSFET for capacitor multiplier
I plan to use the attached circuit from Menno van der veen's article on AudioXpress in the power supply of a single ended EL84 amp. The voltage after the rectifiers will be 320V. The current is around 100 mA max.
I found this MOSFET IPAN70R450P7S from Mouser. The datasheet link is here https://www.infineon.com/dgdl/Infin...N.pdf?fileId=5546d4625f2e26bc015f499adf55405f.
What are the specific requirements for the MOSFET in this circuit? Is there any concerns on using IPAN70R450P7S? Since this part has built-in protection diodes, do I still need Z3? What will be the voltage drop across the circuit?
Hypex SMPS400A180
Hi. I have one monitor speaker that have 2 bridged UcD180 modules on 8ohm load for bass and 1 of same module on tweeter duty with this power supply.After 2 years of working ,last week on power up it wont work.As an electrical engineer myself i found that on power up 2 transistor of the supply board poppd up.The 2 in question are T7 and T14. The first is an smd part and i cant read it what it was,with some intuition and a little schematic i draw i think is an high voltage pnp part.The T14 is an npn KSP44.I already emailed hypex to ask what part number it is so i can change it myself and no answer for now.I must mention that the fast 5A fuse is working,the bridge rectifier too and the caps are good.Is only missing the low voltage startup part.
I ask is anyone have a module at hand if can make an macro picture of the tiny transistor to see the number printed.
Thank you in advance.
Daniel
PP amp driven with balanced input source
As a I am wrapping my current project (RH807 SE amp) I am thinking of the next project to build on this experience.
My DAC has 6.4V rms balanced outputs. So I was thinking of using this to design a PP amp without a phase splitter. Volume control would be done using a stereo stepped attenuator for channel. Would the topology a good starting point? Ignore the component values as I have not optimized the o.p. yet.
ECL82 Class-A amp - No sound
I built my first tube amplifier based on this schematic:
Single Tube amplifier
The amp powers on and I hear a subtly audible hum from the speaker that I would atribute to the power supply and heater wires.
I''m not getting any audi out, just a slight "hissing" sound.
I've modified the schematic below - I currently have the audio input from the pot with a 220k resistor in series and no ground. I'm thinking this is the issue, but not sure.
5W_ECL82_SE_amplifier | Zack Fedor | Flickr
Using a Triad R-23B power transformer
5k 8ohm output transformer from China (nice one though)
8 ohm speaker
USSR 6Mb8 tube, tested strong
1N4001 diodes on the rectifier
All componenets either new or in perfect working condition
I would appreciate any input 🙂
Communications Rectifier hot swap NPR24/48 information
Hello,
I have many NPR24 hot swappable rectifiers which were used in RF communication centres. These plug into a magazine and run in parallel to provide large currents for comms gear such as paging and LTE Transmitters.
Not Audio related however, these Switching power supplies are exceptionally well built and utilise ZVS topology as well as Power factor correction to minimise interference. The control uses a Atmel Mega32L and communicates using RS-485 modbus link (I think) communicates between the SM60 supervisory controller.
The NPR series where made back in 2007 by Powerware now bought out by Eaton.
I’ve contracted Eaton a few times regarding technical info, schematic and the modbus register map and as expected, got blown off. Can’t give information as its propitiatory line. Shame!
I feel there’s life left in these old girls and I’m finding plenty of used ones coming up on the web for not much at all. I’d like to save them from land fill or going to green waste and reverse engineering how to talk to them.
Question is, is there anyone with information about these such as register map for the modbus and schematic.
Somebody out there probably repairs them in early days.
Please PM if you can help out. Pictures attached
Cheers
FS pair of paper mache 160hz tractrix round horn
DIY paper mache round horn. Mouth diameter is 26 in. Throat is 1.5 in. Mounting flanges for JBL 2450 series compression driver included. Pin point stereo imaging even if put in corners. $100 for the pair. Local pick up only in Oceanside CA 92057
Splitting the stereo cable to feed two amplifiers
Hello!
Not long ago I've removed the player in my car and put a Raspberry with USB connected SoundBlaster Play3 and a TPA3116 amplifier. The sound became very, very nice. Unfortunately I've physically damaged the amplifier and I have to change it.
I'm want to split the signal from the SoundBlaster with an Y cable to feed two TK2050 amplifiers that will feed the front and rear speakers separately.
What do you think will happen? Will the sound be better in terms of quality and power or it will be a downgrade because of the lower input signal?
Is there a chance to burn something? I'm thinking about a 7A or 10A fuse in front of the amplifiers. Will electrolytic capacitors do some protection without bugging the sound?
The cars is Chevrolet Venture with original speakers.
Thank you!
High impedance IN EAR headphone
Looked around in this part of the forum but could not detect a thread about high impedance in ear headphones.
Currently I am using a Sennheiser HD650 headphone for my headphone amplifier which is an absolutely great headphone. But it is an over the ear type and after listening during a long time ( 20-30 min.) it becomes a little bit uncomfortable.
So I want to purchase also a headphone which is an in ear type but all the types I see on the internet are low impedance around, 30 Ohms sometimes even lower.
Are there in ear headphones which have an impedance around 80 to 100 Ohm or preferably higher?
Sure Electronics AB32514 noise hiss
Hi
I have 2 sure electronics AB32514 amps and one of them has developed a nasty hiss at idle. Both amps were completely silent for a long time but one has now degraded. The noise is pretty loud, it is removed if I set the SW1 to off without the volume control board connected but gets worse once the volume control board is inserted. I also get a whistle when using the smps power supply but not on battery power. The other amp is silent on smps. If anyone has any suggestions I'd love to hear from you.
Did I just kill my Minidsp 2x4HD
notes : i have posted this in minidsp forum but looking at many threads without reply so i think i might get help here
I want to start my measurement and connect my 2x4HD and UMIK on my pc. Then I found for new firmware upgrade that are available for UMIK and start upgrading process, this is where i'm playing music at the same time.
But when UMIK firmware upgrade completed, suddenly 2x4HD stop working where no more sound and the LED does not lid anymore. I try to plug-unplug power connector and in a glance there is short lid from led when power is plugged but then no lid anymore
considering that i upgrade UMIK firmware where at the same time 2x4HD board is also plugged in, is it possible the software stupidly send the UMIK firmware to 2x4HD board that made it stopped working? Because the software also can not connect to the board to reverse the process, maybe is there any hardware reset button or pin?
Virtual ground isolation and pre-amp with current limiting resistors
I am building a phono pre-amp and i was toying with the idea of running it from the 18v DC supply in the turntable, which i have done a transformer swap on. Then I can just install it in there without using a new power supply.
So I built one of those capacitor and voltage divider virtual split rail.
I was testing - i have a +15-0-15 supply that makes this work fine. So I realize I'll have to isolate inputs and output earth with coupling capacitors. I did that and the phono signal still passes through and gets amplified.
Then I'm trying to run this NE5532 with this virtual power - using one of the rails as an input of 0v 15v - it measures (pos)7.5-0-7.5(neg) which connected up with the circuit and i've isolated the inputs/ouputs - linking their earth ... but now earth/0v is floating. So basically that kills the signal. Since they are isolated with coupling caps I thought, ok then I'll use the 0v that is actually now the negative rail for the pre-amp but its 0v otherwise as the 0v/ground and then i should have my input signal basically as before. Since 0v was ground before and it worked.
Doesn't work. Looking at the data sheet the NE5532 wants 5-15v +/- as min to max +ve and -ve supply. So I've got 7.5, should be enough to function.
My working circuit has 100 ohm current limiting resistors on the +ve/-ve supply of the op-amp which I do because it is one thing (along with bypass caps) that helps make it stable. Earlier I built unstable pre-amps and I copied this idea ... but maybe at this voltage that is a problem? I still have to test it like that ... but any ideas or circuit examples of how this kind of power supply changes a circuit and keeps the virtual ground isolated? Thanks - and sure, just link to another thread if I'm just repeating history.
Visaton BG 20 91L BR
Hi folks! I've checked some threads here about the bg-20 and thought I should at least share what I built afterwards.. This is my noob experience with the Visaton BG 20 full range driver.
I needed a couple of speakers for my newly acquired Xindak MT3 tube amp.
In waiting for a kit of better drivers I made a couple of BR boxes with these super cheap bg-20 in the mean time.. They are on 91 liter because that was what I had material for. 110Liter+ looked better in the simulations though.
They are tuned at 40hz.
I am impressed with the sound compared to the price and I will keep these speakers for daily listening on another amp when the new speakers are built.
If I build with bg 20 again I will probably add a couple of tweeters for more presence, but for daily background music it isn't needed.
Sorry for my crappy english..
Anyways..
Cheers!
//PacMandalore
Reactions: bedrock602
Simulate an electret microphone LTSpice
Dear All:
I'm trying to simulate an electret microphone.
I'm using a 8v DC voltage source connected to an electret mic through a 4.4K resistor.
Is my simulation Ok with the 4.4K resistor in Parallel with the electret, or do I have to put the resistor in series?
Regards.
Alfredo Mendiola Loyola
Lima, Peru
Adding a pre-out main-in to a Rotel RA840BX4
Hello DIY enthusiasts,
I have an integated Rotel RA840BX4 amp that I used to enjoy a lot but had to put aside because it lacks pre-out and main-in connections. In my preferred setup I have a MiniDSP connected between the pre amp and the power amp to fix issues with the room acoustics and to serve as a crossover for my subwoofer.
However, I assume that it might be fairly easy to add those. Looking it the schematic, I guess that I could simply add those by making a cut at the position I marked with an arrow (image below). That seems to give the desired low output impedance (delivered by the NE5532 OPAMP + 100 Ohm resistor R715) and high input impedance (15K Ohm resistor R601 + capacitors).
Would that work as desired?
Thanks! René
High-Pass filter messing up the treble
Friends,
Summary: Highpass filter impacting signal above filtered range ... why?
I'm running a tri-amped + sub system, with electronic crossover. I still had the passive crossover lying about that I used in a previous iteration.
The problem is that when I'm mucking around with the electronic crossover (symetrix Jupiter 8) it's happened on more than one occaision that I flatten the curfve for the tweeters, sending full range signal down the line... oops. So far no blowups (tough little Vifa D19TD!), but I wanted to put the high-pass from the crossover back in the line to have some protection.
Only when I do so, the treble on low volume really suffers - that's 3 meters listening volume, and it's unbearable on quieter passages. The highpass I also notice really attenuates the soft background hiss that comes out of the headphones jack of my raspberry pi (waiting for the balanced audio HAT).
The electornic crossover cuts in at 2500Hz with steep 48dB LR filter.
The passive components are per graphic C1 5.6uF L1 1.4mH. Only hooked up the high-pass.
I would have expected that the filter attenuates the signal, but it comes across really grainy, almost staticky, on low volumes. High volumes seem OK.
I've bypassed the coil and just hooked the cap in series, to same effect.
When I pull the cap out of the line, the signal comes through as it should, regardless of volume. I can dial it down until the treble gently fades behind the background hiss with my ear hard up against the 8 Ohm Vifa D19TD tweeter. With the cap in between, the background hiss is nearly gone, and the treble just stutters away.
From my calculation the filter should only take effect around 1800Hz and leave the signal above alone. What am I doing wrong?
I really want some protection (from myself doing stupid things) but I don't want to compromise the sound even at minimal hearing volumes (night time listening).
aragon 4004 mk2 schematic needed
hello all- i have an aragon 4004mk2 that suffered a spike when the negative power supply rail on my preamp failed. 1 channel popped a fuse and i found a couple of driver transistors shorted and a shorted current regulating diode.
it looks like i need a schematic to proceed further.
if anyone out there can help, i would be most appreciative.
regards, leapingknome
Aragon question...
Hi!
After having sold off my Yammy M-80 quite a while back, and then an episode of lost funds with a previous diyA purchase, was finally able to get a reasonable deal on an Aragon 8002. Big difference in design/layout that I like; super clean. Nice noticeable improvement in sound quality.
Anyway, noticed one channel was running a touch warmer than the other, so I dived in and did the "check the bias thing). One channel read 18mv over the resistor, the other was ~30mv.
I re-set them to 10mv just as a starting base point (seems to be the magic number for a lot of amps. Runs cold and still sounds great. I know that this amp supposedly is supposed to run warm~hot, so the question is...
What is the ideal bias for the 8002?
Thanks.
bluesmoke
SMALL EXTRA: One odd thing (lucky me; like always with amps), I've noticed that when I've listened to the amp at low levels from a cold start, about 1 hour in the left channel seems to break up. As soon as I turn up the volume and run it for a while, things are fine when back down to quiet listening levels. Weird... It FEELS like a relay problem (me and relays... starting to hate them), but both channels seem to be making solid contact. Could still be a relay problem (oxide from arcing~ I can't see), but just wondering if there might be any alternative suggestions. Can live with the weirdness for now, but this is just shouting "fix me!".
Grundig NF-10 amp restoration
Hi all,
I recently bought a Grundig KS580 and am trying to restore it piece by piece. I will be posting my progress in case it helps others. [image]https://www.diyaudio.com/forums/attachment.php?attachmentid=934646&stc=1&d=1616398663[/image]. So far it looks like everything is working. Except... it looks like someone went through the amp and pulled out the tubes and output transformers. [image]https://www.diyaudio.com/forums/attachment.php?attachmentid=934647&stc=1&d=1616398663[/image]
I plan to get 2x ECC83s and 4xEL95 in place of the 2xELL80s. However, I could use help finding replacement output transformers to go with the EL95s. Here is the relevant schematic [image]https://www.diyaudio.com/forums/attachment.php?attachmentid=934639&stc=1&d=1616398230[/image]
I am new to analog electronics but here is where I am at so far:
From reading around and peaking at the datasheet, a push-pull (I think that's what the schematic is) EL95 is 10kOhm primary impedance
[image]https://www.diyaudio.com/forums/attachment.php?attachmentid=934638&stc=1&d=1616398230[/image]
Speakers are 5ohm each and, if possible, I would like to wire additional 4ohm speakers for a 2-5ohm load.
Am I correct in that this means I need 10kOhm primary and ~4Ohm secondary? Would something like a Hammond 125DSE suffice? or are there better options?
General question about mid and woofer selection for a three way
Hello, i am fairly new to diy audio, although i have done two projects.
This is concerning a general question. I have seen a lot of speakers using a 5.5 inch mid or mid woofer like the scanspeak 15m or 15w. With my current knowledge i dont understand however why most of these designs then use an 8 inch or 2 8 inch drivers instead of 10 inch drivers.
Shouldnt one be able to cross over at 220 hz lr2 for example? Or is this generally rather high for a 10 inch driver?
All the 10 inch three ways i see are using a 6-7 inch mid. And to me it seems this makes for problems concerning tweeter/mid crossover.
On a side note i am considering building a 3 way with the 15w and 25w8565 crossed at around 220 with second order linkwitz. This gave reason for my question...
Thanks in advance
Audax PR170M0 –100 dB or just *94 dB??
I’m looking for a pair of good, moderate price, high efficiency dynamic drivers, covering higher mid – lower treble, and the most often mentioned is the 100 dB Audax PR170M0.
Others are the Eminence Beta 8 and 10, JBL 2123, PHL 3451, Ciare PM250, some Supravox and the PHL 1040 & 1060 (yes different size > different response patterns).
Audax is now made by AAC, and the PR170M0 is back on the market for US $ 70 at Madisound:
www.madisound.com/cgi-bin/index.cgi?cart_id=1765800.22568&pid=107 with as before “100 dB efficiency”. .
I ran the Madisound specs through Unibox though, and the maximum SPL at 2.83 Vrms 1m was only 94.4 dB!
In deference to the driver, the nearest spec driver, the “100 dB” PHL 1040 came in at 99.4 dB, but that’s only 0.6 dB down, not 5.6 dB down!!
What’s happening, revised specs/ mistake at Madisound??
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,781
Members
7,888,188
Messages
Filter
Forum Statistics
Threads
406,225
Messages
7,888,188
Members
507,781
Latest member
Ronny2001
