One Tweeter Failing -
I have one tweeter (left) that consistently fails at loud volume. The right never does. The tweeter is this one (Peerless by Tymphany D19TD-05 3/4" Poly Dome Tweeter), and the speakers are PSB300s, running from a DENON AVR-900 (100 W per channel). Source for the failure is usually the turntable (THORENS TD 150 MKII A/B - rebuilt by me). But it does happen with the DENON CD deck. Speaker wire is vanilla WalMart Phillips 18 G braieded copper speaker wire. One thing that I did do (before I knew not to do it) was that I cut the right speaker wire shorter than the left to prevent excessive coiling of the right spk wire; amp is on the right hand side of the room.
Question: Is the differential in the speaker wire to blame, or is it that I've got the amp cranked up too high (max) for the speakers?
The rating on the speakers is "Rated for 10-80 Watts at 6 Ohms Impedance."
Thanks.
Modding the Darkvoice 336se OTL headphone amp
FYI, the Darkvoice 336se is a popular tube headphone amp from China. It can roughly be compared to Bottlehead Crack, the latter being better built and pricier. I have not made such comparisons, however.
A few mods have been suggested for the 336se.
I did the Preamp Output ground (remove) mod. I think that made a positive improvement.
Next, I did the LED mod (replacing the 1k R). I used std. red LEDs. Not sure about the results. This may have worsened the sound???? Not sure!
Have there been comments on the brand or type of LED to use? I've heard that color can make a diff. (because diff. colors have different doping materials and diff. current requirements).
Other than tube rolling -- unless you know of any real juicy tubes to install -- suggest whatever comes to mind for further improvement of stock unit.
References:
Darkvoice and Crack Mods | Super Best Audio Friends
Massdrop--thread on 336se
Darkvoice 336i & 336SE Tuberolling PartII | Page 65 | Headphone Reviews and Discussion - Head-Fi.org
Two 3255: Ground Loop Across 3e DSP Outputs
Hello,
The dsp is connected to two TPA 3255 amps with unbalanced inputs.
First question, I connected AGND and + on the DSP outputs to, - and + of amp inputs, respectively, is this correct?
Both amps are powered by the same power supply, which only has a positive and negative lead. I have a ground loop between the negative terminal of both amps and across the outputs of the dsp (I get ground noise even when one of the amps is only connected to negative power in and even when the dsp is not powered on but with its outputs connected to the amps).
How should I break this ground loop across the DSP's balanced outputs?
Thanks!
boostered opamp audio amplifier
I have designed a boostered opamp audio amplifier based on AD820 and TIP125, TIP120.
The output stage is controlled by the currents through the Vcc and Vee power rails by use of the resistors R4 and R5. The bias current through the output transistors is set by an adjustable current source LM334 and the fine trimmer R8 (10 Ohm). The output stage is in common emitter configuration. In this way the amplifier can operate with rail-to-rail output voltage swing.
What do you think about this circuit?
3D printed enclosure plans - a work in progress
​Recently I was going through all of my drivers that I bought years ago and didn't do anything with, and I decided that I should start a new project. Since I'm working from home most days, and spending a huge amount of time in front of a PC, I decided that I'll use some of these smaller drivers to build new desktop monitors. I thought it would be fun to utilize my 3D printer for this project, so I whipped up a design in Fusion 360. This design is a very blatant ripoff of the Sonus Faber Cremona design. That's one of my favorite commercial speakers, and until I can make a full size set, I thought it would be great to have a mini set! The drivers that I intend to use will be the Dayton ND105-4 midwoofer and the ND20FB-4 tweeter.
Here is the design so far:
Right now the enclosures are very basic, and not printable on my printer due to a limited print volume. I intend to build the cabinet walls from laminations that will bolt & glue together. The rear panel may also be made that way. I still need to design the laminations and the interlocking features. I also intend to hollow the sides & back panel out so that I can fill them with sand to help damp them. The front panel I'm not real sure of yet. I'll probably need to print it in 2 pieces glue it together, so I'll need to fool with different ways to split it so that I get a good solid keyed glue joint.
Cosmetically, I intend to wrap the sides, top & bottom panels with a cherry vinyl that I have left over from a previous project. It looks pretty nice for being vinyl, and it'll allow me to wrap the radius around to the front baffle, which I wouldn't be able to easily do with real veneer. The front & rear panels will be a satin black. I may experiment with wrapping the front baffle in a faux leather similar to the real Sonus design if I get ambitious.
The enclosure is just a tad over .19cu-ft as it sits, with the expectation that port volume, crossover and drivers themselves will bring it down to around .17-.18cu-ft. That variation doesn't have much of any impact on the overall response. SPL is with 15w of input, which is right below the driver's xmax at around 80hz. The driver unloads below 50hz, but since I'll be sitting 2' from them, realistically I'll probably never get them close to xmax.
No idea what I'll do for a crossover yet. I may fool with modeling it in PCD, but I don't seem to have good luck getting realistic results using FRD/ZMA files even when I extract minimum phase, so I'll probably take in-box measurements and design the filter from that. Because of the smooth response of the drivers, I'm hoping to get away with something nice and simple, but we'll see.​
Sonus Faber Cremona HYBRID Clone
Hello everybody in a sunny and shiny day from Spain:
Introducing myself (already done in the appropriate forum) I’m Alberto, a 40 years old Guy who, not knowing almost nothing in the Speaker’s DIY world, has started his own project after 2 years willing to do it.
My aim is to clone the Sonus Faber Cremona Speakers but with a very low budget… let me explain:
I’ve been a long time crazy for the Cremona’s, but no way to buy them even in the used market, so thanks to one of my friends, I bought a used pair of Monitor Audio Gold Reference GR60 floorstanding speakers, that I have to say they sounds me like angels singing….
Monitor Audio Gold Reference 60 Floorstanding Speakers reviews - Audioreview.com
Speaker Asylum: REVIEW: Monitor Audio GR 60 Speakers by O'Shag
http://www.htguide.com/forum/showthr...-B-amp-W-804-S
A Review of the Perfect Loudspeaker: Monitor Audio Gold Reference 10 - Archived Threads 2001-2004 - Home Theater Forum
But I don’t like how they look all:
So, with my tight budget I thought I colud use the drivers and Xover from the GR60’s inside my cremona’s enclosure. After some tests and looking for lots of information I decided I would do something like this: my Hybrid Cremona’s:
And… the fact is that I designed from the beginning all the CAD drawings and everything and sent the drawings to a Computer cutting and milling, because the guys who had built the Cremona’s Clone in Spain constructed them by adding lots of layers to build the enclosure, but I was sure I wouldn’t be able to do like that and I thought it was easier, faster and much more safe to build them rib by rib, and the fact is that I was in the right way. I will add some pictures of building process later.
When I designed all the stuff I did with the following parameters:
Very similar volumes that the GR60’s but compatible volumes to the BIG_AL Cremona’s Clone… who knows if I will build with this drivers (that was my first opinion, but the budget is quite expensive for me)
vs
I have already built the enclosure. It took me about 12 hours of gluing ribs from 5 to 5 and putting all the together to build the full enclosure (It took about 10 days leaving 24hours to dry each glued portion). This is the result (still not veneered):
And what happens now? Well, I have to say I’m really satisfied with the result and I’m very close to the starting point of this project long time ago: deciding whether or not to use my GR60’S drivers and Xover or a new drivers configuration, and here you are my options for you to give me your suggestions:
1.- Using the Cremona’s drivers and Xover (or the ones designed by my Spanish Friend) that is for each speaker: Morel Supreme Tweeter + Audiothecnology C-Quence 15 H 52 06 13 SD midrange + 2x Scanspeak 18W8531G00 woofers. All this stuff, Xover included and selling my GR60’s would be a $2100 investement (1550€). The pros is that this is a superb configuration, it sounds PERFECT and the Xover is already designed. The con is the hugh amount of money I don’t want to Spend.
2.- Build my own configuration accdording to my budget. For each speaker: Seas 27TDFC-H1189 Tweeter + SEAS MCA15RCY-H1262 mid + 2x SEAS U18RNX-H1571 woofers. All this stuff, adding a Behringer DCX2496 ultradrive pro Xover to avoid the passive Xover desing, and adding the mic and external sound card for measurement, all inclusive and selling my GR60’s would be a $410 investement (300€). The pros: no much expenses (I could rise my budget in drivers up to $675 or 500€). The cons: adding a new electronic device (The DCX2496) and lots of hours of measurement) and I don’t know the results… until I spend the money and test everything.
3.- Using the GR60’s stuff. The cheapest option, the worst looking but I’m pretty sure I will really have a good sound.
Do you think I will get more sound performance with options 1 or 2 or any other option you can suggest me?
I accept all your suggestions about drivers and Xovers, even if they are different to my ideas, but I need something tested and fully working and don’t want to test Xovers because I would become crazy for sure.
Thanks everybody for looking.
Making mods to a Sony CDP-302
This may be asking for the moon, but what could I do to this old timer to perhaps make it a little better than it is. I have taken a pic of the inside if that helps. I'm fairly adept at modding analog stuff, but digital is unfamiliar territory for me. I might be beating a dead horse, but it just seems so well built compared to todays offerings I can't help but to try.
BTW: It works right now. I'm just looking for any tweaks/improvements I could make.
Thanks for any tips.
*Note: Picture is fairly large.
Sony CDP-302 internal pic.
Tango Hirata XE60-3.5S for sale
Used pair of early Tango Hirata (not the ISO version) XE60-3.5s for sale. Great for most of the single-ended application eg.2a3, 300b etc. They are in beautiful physical condition and of course works as they should. However their factory boxes and papers are long gone.
I am asking USD1500, inclusive of shipping via EMS worldwide. PM me your email address to send pictures.
Soldering difficult connectors
Hi All,
I have made a couple of DIY interconnects using inexpensive cable and KLH bullet, connectors. I think I managed to do OK with them but honestly the long term reliability worries me somewhat.
The RCA plugs use these tiny, flat connectors with U shaped prongs internally. They are flat, small, and have no hole to hook the wire through or around really. Looking at pictures online, the ones I had were definitely not curved and flat.
I'm just wondering, what is the soldering strategy of attaching a tiny wire to the end of a piece of metal when it barely has a place to put it, let alone tie it or put one inside the other?
Symmetrical amp clipping behavior - help needed
I have an amp design here, which evolved from non-symmetrical amps I already built in this thread.
So this is continuation, hopefully for the better.
See the attached LTSpice sim file, and screenshots (for 1kHz and 10kHz).
Everything seems to be working fine, except the clipping.
Looks kind of ugly.
Any help with improving clipping behavior (or anything else) in this amp would be appreciated.
Choice of transistors is determined by what I have (e.g. TTA/TTC, BD140, BC).
I simed it with different ones, to pretty much the same results. Also have higher voltage version with bigger fets,
but for this one I want to use IRF640/9640, as I have too many of them..
As it turns out, this thread evolved into "hands-on crash course in feedback stability", so keep reading if you want to
find out how to evaluate OLG, Bode plots, Phase Margin and Gain Margin.
For dummies.
Most recent schematic: post #69
  • wdrhld_baby_beast.comp.hexfet.10mar2021.asc
Help needed
Since the beginning of the pandemic I have had engineering parts and test equipment essentially dumped on me as companies changed and people moved on to new lives. If I were rational most would have left as e-waste, but I'm not and I'm sure there are others near me who could find utility for this excess stuff, but Its more than I can handle alone.
Is there anyone in the Bay Area interested in pawing through piles of caps, resistors, transistors, IC's, tubes etc. to sort into useful piles and help find homes for it all?
PM me if interested.
F7 clone kit and WHAMMY PCB
1) First Watt F7 amplifier clone kit containing all parts to build a working stereo amplifier (jfets, Semelab mofsets, resistors, pots), two pcbs (one for each channel) and a schematic. Nelson Pass has not released the official schematic for the F7, so this is a best-guess circuit that measures the same but may not be identical. Power supply, panel or hook up components are not included, just the parts to stuff the boards.
$160 USD plus shipping.
About the kit: this was purchased from a diyaudio member in 2020. He did the hard work of understanding the circuit, testing it, sourcing the parts, measuring transistors and pre-adjusting the pots. You can find information from him and other members who reverse engineered this circuit in the F7 thread. In addition to the kit, I will forward an email from him with additional details about his build. He bought and measured extra parts to get enough working components, and I was lucky enough to snag a set made from his excess stock. He tested components in a working circuit, so they are not factory sealed, but were not otherwise used by him or me. I never started construction. Unfortunately, running a COVID home school for my children ate all my free time for the past year and created a backlog of projects. Neither the designer nor I am making a profit: the kit is selling for the cost of the parts.
A few important details: I will share the schematic only with the buyer and only after purchase. The "long and skinny” PCBs require a longer chassis than the diyaudio deluxe and do not use the diyaudio universal heatsink drillings. You will need to source your own chassis and drill your own heatsinks. There is a silk screen error in one channel's PCB documented in the information I will give you. One of the most difficult parts of building the F7 is biasing the JFETS. This is done for you via prematched and preadjusted pots, which must go in the correct position according to the instructions. You still need to adjust the bias current by ear or with measurement, so this is not "plug and play", but much closer than if you sourced parts yourself.
2) WHAMMY headphone amplifier PCB. This is the PCB available in the diyaudio store. I have too many headphone amplifiers and will not build this one.
Save a few dollars at $20 plus shipping.
Shipping to the USA will be via USPS and is affordable. Shipping outside the USA can get quite expensive and be very slow these days.
CALRAD CR-12TX , Triaxial's (rebuilt)
Goodday for those of you who are looking for a good pair of CALRAD CR-12TX , 12" triaxle speakers that have been Re-built , yep new foam rool suspension, cones ahave been coated with PVA style coating and firmed up using carbon fiber ribs. Twweter horn flares are Aluminium and have been damped using, plumbers putty. Tweeter are mylar diaphrams (original). 20 Watss RMS powr handling and the coil DCR's are both around 7.4 ohms on each, Vas is unknown but likely in the 8 cu ft range.
Price is $165 for the pair. OBO
Shiiping from Calgary ALberta Canada Postal code is T3C2A1
Wieght is only around
Hammond transformers available NOS
Hammond transformers 167P100's &167P36 NOS
I have 2 x Hammond # 167P100 , 100vac secondary , center tap , 5 amps.
and
One Hammond 167P36 , 36 VAC center tap , 180 va.
All are NOS never been used , good condition.
Asking $120 for pair of 167P100's
and $35 for 167P36
Shipping from Calgary Alberta Canada , postall code T3C2A1
Payment via e-trans in Canada , or cashiers cheque from us. Will provide complete details including tracking numbers fro UPS shipping to US. Canada Post in Canada unless otherwise specified !
Thanks Rich Allan
Repair service for Braun Regie 550
Hi all.
OK. So here's the story.
1. I have 2 Braun Regie 550 receivers. I am a total sucker for these receivers, and I LOVE their performance and looks. I have the tape deck also, and now all I need is the turntable...ok that's another story.
2. One of them just decided to go into protection. Immediately upon turning on, the protection relay does not click, and of course, there is no sound at all now.
3. Before this, it was having a loud hum on all inputs. I replaced the filter caps (the big silver ones, or coupling caps?) in the power supply.
4. The hum went down a lot. But there was hum still in the phono -- engaging the phono stage gives a loud enough hum at just the 9o'clock position on volume. The hum increased with volume.
5. Very soon, the protection relay refused to click and the receiver has no sound at all.
6. The second Braun receiver has some loud scratchiness in the volume/bass/treble controls....Deoxited a couple of times. Still scratchy. Don't know if it needs anything more.
I am not very good at schematic reading, and would like to know if anyone wants to take on the project of fixing this, and doing a proper recapping of old caps.
** Schematic attached
** Service manual attached.
If anyone has ideas about possible issues I should look at, that is also something I am happy to try. Of course, I don't have any equipment to check amplifier bias and such.
Thanks for reading! Comments welcome!
Sub woofer for Quad ESL 57s with active crossover
I have a pair of stacked quads which I adore refurbished using Sheldon Stokes brilliant book. However my listening room is very large - about 10m x 8m with 4m ceiling so that the lower bass lacks ‘punch’.
I just picked up a pair of old but good B&W 801s and wondered about pursuing an active crossover set up with their enormous drivers.
Has anyone tried anything like that.?
Help assess Impulse Response of LXminis
Hello,
I started with using REW and UMIK-1 microphone to understand my room behaviour. On the way, I measured my LXminis. The Frequency Response is correct, but I'm puzzled with the Impulse Response measurement that does not looks at all like a pure dirac. See below:
- starts with a negative 100% (instead of expected positive),
- then a positive 80% (OK for a small "overshoot" but not that much).
Is this normal and related to the 2 drivers and the inverse polarity of the Full Range (by design inverse polarity to be in phase with the woofer at cross-over freq) ?
Is this abnormal and I should investigate ? In REW documentation, the picture for IR measurements shows a nice positive single peak, as expected, with only few ripples.
Nota, the Freq Response at crossover frequency is clean with no dip, which confirms that the woofer and the Full Range blend well and are in phase at that point.
This may be a quite stupid question, sorry for that. But willing to learn !
JMF
Oscilloscope and high voltage
Hi guys.
I bought a pc based oscilloscope ISDS205A and now I study to use it.
I have a problem with a small standby pulse transformer, which of the primary coil should have < 300V.
In the user manual is said:
2, Oscilloscope with Probe: X1 CAN MEASURE -5V TO + 5V VOLTAGE, X10 CAN MEASURE -50V to + 50V.
3, The Measurement of the Electric Supply 220V / 110V IS DIFFERENT FROM THE NORMAL WAVEFORM MEASURMENT AND NEEDS TO BE RE-MEASURED BY AN ISOLATED TRANSFORMER.
Does that mean if i buy probe x100 I will be able to measure up to 500V ?
Sorry for the lame question,
I am learning now.
Cheers!
Newbie building subs with SB23MFCL45-8 drivers.
Hi Everyone
As the title suggests, I am completely new to building subs and wanted some advice on how to make this learning process as painless as possible!😀
I will try and keep this short but understand that most people here like a bit of background to help determine the best direction.
I should explain that I am currently constructing some floor standers, that started out as mini monitors (Gorens excellent Revelation mk2 www.audioexcite.com >> Revelation Two – Monitor MkII ). A house move and a bigger living room meant that 5.5" woofers just weren't enough! so they are being put into floor standers with 2 x 18w units each to beef up the low end. (active x-overs from 18w to 15w and Gorens passive x-over for the 15W to tweeter). I have built cabs with various panels that can be moved around or removed so I can play with different volumes and experiment with ported or sealed. Luckily I have a cousin who has built active speakers for some years now, helping me with this side of things (building the amps, measuring etc), but he has no experience with subs.
The reason why I am thinking of adding subs to this is because a bit more controlled low end is always a good thing 😀 and I already have 4 x SB23MFCL45-8 drive units (long story).
So now for the questions.....!
I am thinking that maybe a pair of sealed stereo subs, each with an up and down firing driver could be a good choice? (or not? - opinions please!)
Also what would be a good amp for this driver? The mains are going to be running some cheap but nice 125W modules that my cousin uses and rates highly, but I am not sure if this will provide enough grunt for subs?
I am also thinking that as LF tend to excite room modes more, maybe I should look at DSP to try and control this? (Mini DSP 2x4HD maybe?)
If I build these subs, would I be best making the mains sealed to help make integration with the subs smoother? (is that a correct assumption?)
The room they will be going into will be roughly 20sqMetres.
My main priority is clean fast bass rather than huge SPL for mainly rock and electronic music (Pink Floyd, Massive attack, Foo fighters etc)
Sorry if this is a long post. Any help/advice is welcome.
Big tubes on low power
Suppose we take a russian GU72 and run it on perhaps 320V and 20W instead of 600V and 60W or so, could we expect any ill effects on tube life?
I´m asking because I seem to recall something a friend mentioned long ago, something about certain tubes relying on some sort of auto-absorption instead of normal gettering to deal with outgassing. I´ve tried to google the subject without any useful results.
Electrolytic Capacitors for NAD T973?
It turns out that Mouser and Digikey don't have anything in 34-35mm diameter that fit the requirements for 80 VDC and 22K uF.
The caps I need to replace are 34x80mm and 34x100mm. 15K uf and 22K uF both at 80V.
Closest I can source at Mouser is 40mm diameter, which will bump into the bus bars on the PCB and will prevent fitting the plastic cover over the far end of the cap bodies, which secures it from vibration, to chassis.
I found some similar caps in screw terminal, but these are four terminal snap ins that solder directly to the PCB. Originals are NAD-branded.
Who sells these?
GB: Round #7; Fo-Felix AC Filter
**We're on round #7!!!**
I've confirmed how to order parts, made sure it isn't an issue for Comocos. (please no more requesting samples)
So over the years people have asked about the old version, made by someone else.
It's probably time for an updated one. This one is a bit different. You may notice it does not have following capacitors after the choke. I have tried both ways, and my preference is strongly without the following X2 capacitors. Also the capacitors prior to the choke are not varied in size because overall capacitance is more important - and they won't randomly resonate with each other.
The other major change is the addition of bypass resistors for the chokes. These don't ruin the filtration, but they do a good job of quieting the chokes that can get excited by different combinations of things on the mains.
Gen1 w/comoco's
Here's how it is different in settling time from the original.
Here's a comparison between resonances.
*2oz copper PCB (1oz is standard)
*Weco 983ZD terminals, copper alloy and can accept 2 wires for daisy chain. These are also safer, particularly if you use solid core wire that otherwise likes to make cold solder joints you can't see.
*X2 rated capacitors for safety, 4x 0.47uf. They are alternated for CFC (capacitor field cancellation).
*Discharge resistor for X2 capacitors
*Coilcraft Comoco choke w/fuse or Bourns 8120/8121-RC choke w/o fuse & 15/16A/20A(*) max sockets
*Fuse clips are beryllium copper (good for 30A)
*120/230v operation (parts & pcb)
*Mounting holes are sized to work nicely with M3 screws and standoff kits
*Size: 2.25x4.25in
The Weco 983ZD are preferred terminals, but not always available as individual sale. For this reason I'm going to include them in the price of PCB, so that I can meet min order requirements for them and save everyone the shipping.
Price: $13ea ($9 per filter board same as original, $2 per Weco, 2 needed per board)
Shipping: $9 US, priority USPS box
$16 CAD
$17 General international padded envelope (prices may vary due to a crazy world)
If ordering over 4x boards there may be an additional $10, depending on destination.
Need 32 filter board commitments to order.
lordvader 3
Knuds1 4
docjrev 6
Dadbeh 2
gary s 3
wirewiggler 3
JRKO 4
DaveM 4
rtate 3
mrloud 3
loWfi4evR 2
ccliu 2
sampsonite 6
pwagner 4
chiily 3
webber 4
skunark 4
turion64 3
32y0 4
jam econo 4
pistollero 4
jack_b 4
ericimage2 5
Chilkoot 4
dualuxe 1
Converting single speaker terminal to tri-terminal
I have an amp with single speaker terminals, I would like to add two more terminals as I have tri-wire speakers and a sub that connects via speaker level inputs.
Planning to make a copper plate that I can attach like a spade with two holes on the side to to connect two additional terminals. The existing terminal has enough clearance to prevent the new terminals from hitting the back cover.
My question are.
1. Is copper the best material for the plate?
2. Do i need to have the copper plated?
2. How thick would the plate need to be ?
Can someone explain how a.FHXL "works"? Basic acoustic engineering?
I am nearing completion of building a FHXL. I have no idea what the horn is, or why this has its particular design. It would appear that the driver is placed so that half of the sound "goes" over the top into a wedge shape that dead ends. What is the purpose of that wedge? What do the slopes sides do, and why are they critical? What dimensions are cricical? What is the purpose of the fill, and how does fill "work"? If anyone can provide me with a basic understanding I would appreciate understanding the "why" behind the design.
3-Way OB - get the best out
Hello!
I plan to build a 3-Way Open Baffle and want to get the best out of it. The goal is to make compromises that do not limit the sound quality to much.
My wishlist 😀
- Overall good dispersion (horizontally and vertically [WMTMW?]) with a smooth target curve (see Toole)
- Transient XO passiv
- Flat response
- Enough low distortion
I dont hear loud music (never more then 90db), because of my neighborhood.
General Problems with 3-Way OB are that one driver can only play for 2-3 Octave. My solution so far:
Bass- Low Mids:
Some years ago i have seen a speaker that goes incredible low in an open baffle because of a stimulated movement of the complete baffle (there was made some acceleration measurements). Click here...
For my bass section and the low mids i will use 2 or 3 of the Monacor SP-225 per side. (Probably i have to make some test with different baffle-sizes)
I think i could use the SP-255 in this way from 20Hz to maximum 600Hz!
Tweeter:
I think the best solution we can see with the BG NEO 3 (vertical position) on the Aino Gradient Speaker.
Alternative....
.... Radian LT2, Dayton PTMini 6 (They aren't able to crossover so low like Neo3 and if crossed higher its harder to get a smooth vertical dispersion)
..... Peerless OC16SC04 (Higher crossover-frequency and most worse dispersion of all alternatives because of big dipol-width at 7-8khz)
..... Peerless TC5FC02 (At Cone Breakup probably loose of a good dispersion on the baackside of the driver at 5 khz. Compared to this the Neo3 will hold up till 7 khz)
Therefore i think the best selection is the Neo3 (additionaly it has a good reputation) and when we need a better distortion because of a low crossover point probably the TC5FC02 could be a second option!
THE MOST DIFFICULT PART - WHAT COMPROMISES TO DO?
Filler (600Hz-2,4khz):
If we go to ask for the best dispersion, we take 4 of the Filler in a
W
MM
T
MM
W
configuratioin. The best 1,5" i have found:
1,5" Peerless by Tymphany TC5FC07-04
Alternativly Dayton Audio DMA45-4 but not loud enough.
Or only two of Tang Band W23-1287SI
As Info for the Peerless driver, the 'd'Appolito crossover-frequency would be 570Hz and 2,2khz. With these little drivers i can simulate a very nice vertical and horizontal dispersion.
Or is distortion and dynamic that bad, that we should go for something bigger?
Other Ideas?
Best regards, Tomas
Replacing 9 speakers B52 matrix 2000. I need help please.
Hi everyone,
I have 9 B52 Matrix 2000 systems, where I daisy chain them all to make this huge sub wall. Its about time to service them and I was under the impression that I could get more out of these by upgrading the driver. Someone recommended the Faitel Pro HP1010, or 18 sound 18’s because they can handle what the amp is feeding.
Currently the amp I believe provides 600w to the sub channel and 600 is spilt between the 12” highs. So my question is Is there a driver I can put in this box that will hit more powerfully, efficiently (less heat, friction), and lower than what is in these now? I think some of these are loaded with FSW or FTW eminece’s, rebadged.
Or can you recommend a new system that will crush this setup, (everybody always screams bassboss😀) That I can use 3 20a circuits.
Thank you so much!!
First Subwoofer, considering a PR
Hi all,
I've been thinking about doing my first small-medium subwoofer build and I'm hoping someone would be kind and patient enough to critique what I've come up with so far. This is a bit long winded as I'm trying to talk my way to a decision.
My project goal is for a -3dB in the mid-30s, with an overall volume less than 2cf. Maximum SPL isn't a priority. I already own a Dayton 100W plate amp that I'll start the project off with, but probably upgrade in the future. I have a budget of $200 or so for drivers/ports/etc, and I'm in Canada so driver selection tends to be a little more limited but Solen.ca is usually my go-to. I mostly played around with the Dayton Audio DCS255, DCS305, RSS(210/265/315)HF, and MX10.
I've already crossed sealed boxes off my list as I know I can't meet my goals without a massive box and/or DSP which I don't have the ability to do right now.
Finalist 1
Driver : Dayton DCS255-4
Box : 1.8cf, tuned to 32 Hz
Port : 4" x 16" round
Total Volume : 2.3 cf (includes port)
Ported seems like the obvious choice so this is my control, but when including the port my box volume tends to get larger than I want. This ones a bit large for me but I think I could make it work. Digs deeper than I need but overall pretty happy.
Finalist 2
Driver : Dayton DCS305-4
Passive Radiator : 1xRSS315-PR
Added Mass : 200g
Total Volume : 1.8cf
I was inspired to look into PRs when I came across the Meniscus Baby Boomer. I tried to match their claimed 30Hz F3 at 1cf but couldn't even get close. This was my best attempt using a single PR, and the PR costs more than the driver which seems a bit silly for me to consider and makes this the most expensive option. I'd also prefer dual PRs for the force cancelling property.
Finalist 3
Passive Radiator : 2xDS315-PR
Added Mass : 200g
Total Volume : 1.3cf
Really happy with how small this is, but a bit of a hump in response. Might increase the box size a bit to try and get rid of it. Cone excursion makes me a touch nervous too but its at such a high power level I don't think it's a realistic issue.
Finalist 4
Added Mass : 300g
Total Volume : 2.0cf
The added mass is right at the limit of what Greg at Dayton Audio said was "safe" but it still makes me a bit nervous. Excursion limits are under control and it digs nice and deep.
My current front runners are 3 and 4, with 3 taking a slight lead due to the smaller size. I might be able to tweak the sizes of both to get excursion and added mass lowered a little bit but I'm curious what I'm forgetting to consider, and what the more experienced individuals would do differently.
How to disable bluetooth reception on TPA3116 board?
I bought this Board with Bluetooth 5.0:
which works great but unfortunately it is always possible to connect devices even when the 3.5mm Aux is connected.
Is ist somehow possible to disable Bluetooth (preferable temporary by switch
disconnecting antenna or something)
The Bluetooth Chip is an "JL" AS20BP00966-25A4 "JL" stands for ZhuHai JieLi Technology Co (珠海市杰理科技股份有限公司-珠海市杰理科技股份有限公司|杰理芯片)
the chips is likely either an AC6905A or AC69025C (most likely last one because of BT5.0)
the chips would have the following pinouts:
System tuning vs Perception and Finding Neutral
OK, I subscribe to a more scientific approach to the idea of what SQ is...In a perfect world a Razor flat system measurement at listening position probably would interest me. etc etc bla bla bla....Perfect flat is not achieved in our rooms (mastering studios control rooms etc) but a best as possible of maybe +/-1.5db in a really critical listening environment? +/-3db elsewhere? I dunno...whatever is possible is fine and not my issue. We use measurement microphones to tune systems. A microphone is not the ear, and there are enough differences to start a whole, other, debate lol....non the less...my point is this! Why wouldn't I be better off, tuning my system, aiming at as flat as possible, using my ear.....instead of a microphone....my thinking is that everyone has there own personal "frequency response" and that with practice....you would achieve an even more natural system FR, than a microphone could....
Maybe using a signal generator?
I can't be the first person to have thought of this and I am curious to where this discussion goes.
Heatsink tempertures/transistor performance
Ive been measuring the temperaturs of the heatsinks on the amplifiers ive neen working on over the last few months, and they are all very different, but the one im working on at the moment has a very high temperature (53c)
most i have worked on get up to at most the mid 40's
can this affect transistor performance and eventual quality of output?
so a bit like a PC processor, the hotter it gets the less efficient, without the heatsink and fan it would soon fail, as would the transistors
with the processor it slows as it gets hotter, or too hot and i wondered if the same could happen to BJT'S?
D&B D12 amp and Q1 loudspeaker matching
Very newbie question here. I am buying my first line array for small venues (<1000 people).
The Q1 is rated 400W RMS @ 8 ohms. The D12 is rated 800W RMS per channel @ 8 ohms. So in theory, the D12 is able to power exactly 2 loudspeakers per channel. Am I right? The 2nd loudspeaker will be connected in the line-thru of the 1st loudspeaker, and putting the D12 amp in Q1 preset should do the correct impedance and crossover settings, right?
Just want to make sure I am not underpowering or overpowering the speakers.
  • Locked
AEM6000 Based 50W Amp
The AEM6000 is an extremely well regarded amplifier making use of Hitachi
lateral MOSFETs. It was designed by David Tilbrook as a successor to the
ETI477, and published in Australian Electronics Monthly in the nineteen
eighties.
With changes in availability of components, the AEM6000 is now extremely
difficult to build. The amplifier was designed prior to the widespread use of
modelling tools, so is not optimised. Additionally it makes use of a large
single-sided PCB, with through-hole components throughout, like most kitset
amplifiers of the period.
This marks my fourth iteration of this amplifier. My first was reasonably faithful
to the original, differing mainly by substituting 2SK1058 and 2SJ162 flatpack
lateral power MOSFETs for the TO-3 devices in the original, plus substituting
an SST-404 dual JFET for the original input JFET. Iteration two was simply a
50W version of iteration one. This and the iteration three design (100W) alters
the topology slightly, dispensing with the differential-symmetrical VAS stage in
favour of a simpler non-differential stage. VAS and second stage transistors
are higher-performance 2SC3503 and 2SA1381, and the compensation
networks and biasing is optimised for increased amplifier speed whilst
reducing quiescent consumption
Power supply 4x4700uF. Bias 65mA,offset 5mV.
Specifications
Power handling: 50W RMS into 8Ω load.
Frequency response: +/- 0.1dB from 20Hz to 20KHz.
Gain 16 (stable with gain as low as 6).
Distortion + Noise: <0.0005% (1KHz, 0.1W to 50W into 8Ω).
<0.003% (10KHz, 0.1W to 50W into 8Ω).
Noise (input referred): 8nV/√Hz (measured at 10KHz, input shorted).
Slew rate: 10V/μs
Input impedance: 100KΩ (set by resistor).
Size: 75mm x 50mm PCB.
Power supply requirement: 2 x 40-60V DC. Lower voltages possible.
Idle power: 5.6W with +/-40V supply.
Price 90€
Eton silk some vs the Magnesium Ceramic Dome?
Good afternoon everyone..Happy 4thof July. So I have never used a Eton tweeter before? I have use seas textile domes.and other planner and tweeter's and the L.G. metal some tweeter's from the past..So I have a few questions? I would really like to use the Eton magnesium ceramic dome model number 29HD2. I also like the sound of the silk Dome model number 28SD1. So can anyone tell me how the Magnesium Ceramic tweeter's sound like?Are they bright or tinging sounding? Thanks Jeff
Converting active monitors to passive
Hi everyone
I have these Neumann KH120 studio monitors, I quite like the sound but there are some reliability issues.
A while ago one of the monitors died. The problem lies within the smps.
Before that I had a customer bringing another one with the exact same problem, and on the internet there are several reports of smps failures.
I am not inclined in paying the official repair centre to fix the monitor and then having the same problem again at some point in the future.
I won't get much money for the broken speaker so I am starting to think I could have a play with it removing the whole psu + amp board and converting the speaker to passive.
I am totally new to crossover design so I am wondering wether this project would be worthwhile at all.
Very keen in knowing any opinions from who is more experienced in this subject
Here are some specs for the KH120 active monitor
NEUMANN
Breakups are the hardest thing to do!?
I've always wondered about how far I should drive breakups.
Some say 20dB is enough, others say 30dB, others go for 40dB or more.
after the driver (eg. Tweeter) overlaps, how much does masking affect the ability to hear these breakups?
Here's my driver + LP filter. Measurement conditions 0.5m, on baffle. Equivalent to 90dB/1m.
Are my breakups adequately suppressed? Perhaps this is one of those things where I need to test empirically with a DSP...
Full Range/HF vs Traditional Tweeter
My journey of using small full range drivers for HF duties has only started in the last year or so. Currently using Fostex ff85wk/SB Acoustic SB13PFCR25-8. Presently I'm crossing high but am also experimenting crossing low around 350 or so. I realize I might be talking heresy but for those that also listen to a lot of classical music, have you found the sparkle of strings and brass slightly veiled when compared to a traditional tweeter? My lineup of traditional tweeters involves a Focal TC90TDX and some Elac products. My implementation of the Fostex may be lacking and I have no measuring/designing capability other than what I can plagarize from forums like this. However, I do have a little background in listening because I was a public school band director for 36 years. Thanks for any and all suggestions.
James from Australia
Live in Western Sydney, Australia.
Long time reader and almost first time poster. Have been quietly assimilating information from this and a couple of other great forums.
Several months ago, purchased and built the Elekit Amp and Pre-amp, with upgrades and most recently the Lundahl transformers from Victor. Built birchply bass reflex speakers using the Super 15's from Audio Nirvana in an Ambience set-up. Built a PC with a EVGU audio card, lots of storage and generally play Flac files via JRiver, which works well as I've networked it to be available on several devices/bluetooth speakers throughout the home. Love the phone's ability to remote control the music from anywhere in the home. Also have a Planar turntable (entry level) that sounds a lot better than I think it should.
Room set up isn't ideal (5.5m X 6.5m with a vaulted ceiling) but I hope to move it all to a more ideal area on the near future.
I have a Richtor sub woofer (stolen from my home theater room) and use it with the bass plugs in, along with recently building 2 of the bucket subs which sit in each corner of the room out of the way, driven by a fairly basic dayton audio plate amplifier (they just add that subtle fill-in bass).
I've most recently purchased a Umik mic and started doing measurements, trying to understand REW and adjusting settings in JRiver. Have tried a couple of sets of tubes and gone back to the original ones for the measurements.
I think it's sounding better than ever and continue to thoroughly enjoy the clarity and sound stage as I tinker along...
James
QQ: Elevated heater wires - twist pairs together or keep separate?
I have a design I'm currently designing the build out for. It's a cascode with B+ of -320V to +320V thus the design has separate heater supplies to stay within the heater-cathode limits.
Is there any benefit from twisting/platting/tying the different heater pairs together?
The only issue I could see is ensuring the conductor to conductor insulation is high enough (ie from the lowest heater reference to the highest taking into account any AC peaks). Given they're running off separate isolated secondaries the only other issue is a small amount of capacitance.
It would look neater..
Nord nc500mkll DM. Problem Help please
Hello
I have bought a Nord nc500 from my friend butt sadly he dropped it the floor with the male XLR connectors in so it broken pretty bad
The cable inside on the XLR did loose and I can't understand how to get them back
I take som picture and hope someone know how to do!?
Vit for me is the signal bit is the light blue that to or........?
I know how to welder to the XLR , but I don't want to brake my amp.
I'm a hobby electric fixer so I can fix some stuff (I hope this)
All answer will make my day
Tanks PETER from sweden
Selling Tango NC20F Interstage Transformers
For sale is a good working pair of Tango ISO NC20F interstage transformers.
Specifications easily available if you Google. They are currently installed on my amplifier. Going to decommission my amp. They are the best interstage transformers i have used so far. Send me a PM with your email if you want see some pictures.
US$850 + delivery cost depending on where you are and the service you choose. Paypal will be the mode of payment.
Next steps: grid and supply chokes for C3g drives 45B
My monoblocks are progressing nicely. Of course, I would like to advance the cause and tweak the schematic. As a baseline for the monoblock sounds, listening is non-fatiguing, taught bottom end (though not extended as I would like), smooth top end. Tonality is to my liking, natural and no extremes.
But, there is a slight bit of veil over the sound. Just the slightest opaqueness. So slight. So, I have a few ideas that may help remediate this issue. I am considering 3 alternatives, possibly all 3 eventually. Here are some ideas:
1. Replace the existing 100K grid resistor to a grid choke on the C3g.
2. Insert a new choke in front of the RC network feeding the IT / C3g.
3. Insert a new choke in front of the Russian 50uK Ultrapath cap which feeds the OPT.
All 3 of these option are highlighted with the blue boxes on the attached schematic.
I need your thoughts on these 3 options. Are these option expected to materially improve the monoblocks?
Thanks in advance.
View attachment C3g-45B 6.29.21 copy.pdf
Ground hum through speaker
Hi everyone,
I have a power amp that has ground hum coming through the speaker of one channel, even with nothing connected. It’s not loud, just about audible from listening position. I have attached a picture of the inside. The channel that’s humming is the speaker output nearest to the power input.
I’m not an electronics expert, but I have tried a few things. I removed some zip ties and moved the power cable away from the audio output cable. I have also used a chop stick to check for any loose components but found none.
Do you have any other ideas to try? I recognise that playing around with certain aspects of the amp can be dangerous, and I will be sure to discharge caps and anything else you suggest.
Thanks.
5x LME49811, 4x Panson's PCBs, Thermaltrak
I've had these since 2010, but at this point I don't think I'll build an amp with these.
(Although it's enough parts for 4 channels, so that would be one cool use case.)
So for sale here are:
5x LME49811
I got these as samples direct from National Semi back in 2010.
I think I also still have the printed invoices with my name on it, if that's enough proof of these being genuine, although I'll have to go to the storage to find it.
5x MJE15030G
5x MJE15031G
5x NJL3281DG
5x NJL1302DG
These are the power transistors to be used with Panson's circuit for example. I got these as samples as well from ON Semi.
And 4x Panson Audio Labs PCBs 'Compact Series' V2.1
Compact Series
The price for everything is 85 EUR + shipping and PayPal fees.
I don't want to divide it up and sell only select parts, maybe if there are two buyers who want to buy 2 channels worth of parts each.
Thanks.
Laplace transfer function, poles and quality factor
Hello,
I am working on my theoretical skill, and I struggle a bit understanding the geometric interpretation of s-plane regarding eigenfrequency (natural frequency ?) and quality factor.
On this document (cf screenshot), I read that poles at constant frequency move on a circle when modifying the quality factor?
Is it because of this "natural frequency" term ?
It goes strongly against my intuition that constant frequency is equivalent to constant imaginary part of the pole.
http://jahonen.kapsi.fi/Audio/Papers/Equalization.pdf
I am understanding wrong ? is the document a bit inaccurate ?
Would you have some recommendation about resources I could use to understand those thing ? (signal theory, linear stuff, DSP, and so on). I am not too scared of maths, but I really enjoy pedagogical stuff that gives intuitions.
Thank you very much 🙂
Toshiba SC - 335 and Toshiba SY - 335
Firstly, may apologies as I know very little about musical equipment, and I hope this is not in the wrong thread, but here goes,
Las week i purchased an old sound system. Brand is Toshiba (model number listed above) and it also came with a turntable.
When I brought it home to set up, I noticed the turntable does not have a needle for playing records (stupid, I know, but like I said, I am totally unfamiliar with all this) Are needles easy enough to come by? Do I need a specific one or are there generic ones I can pick up?
Also, when I brought it home and set it up, I tested the radio on it, it works fine but it seems to be stuck on full volume, which is pretty loud to put it mildly. I am looking at the back at all the cables and I may as well be looking at heiroglyphs.
Could anyone please help me and shed some light on these issues?
Thanks in advance,
Stefan
value of record sales in 2021 to surpass CDs
wow!
How vinyl records are trying to go green - BBC News
“There were 22 times more vinyl albums sold in the UK in 2020 than in 2007 - with sales leaping from 210,000 to 4.8 million.
The most recent figures from the British Phonographic Industry reveal sales grew by more than 30% in 2020 alone, bringing in revenue of more than £86m.
For the first time since the late 80s, the value of record sales in 2021 is expected to surpass that of CDs - although it still lags way behind digital streaming and downloads.”
And now we have to worry about the environmental impact, something that was not an agenda item back in the day.
LTspice models for Sanken 2SC6145/A2223
Apparent deficiencies of these models:
The 2SC6145 model has higher apparent Re at higher currents due to difficulty in modeling the curve in the datasheet. Furthermore, the high value of Nk may cause convergence or solver errors. Removing Nk should fix this, and the majority of Hfe droop is due to quasi-saturation anyway.
(I'm sure there are more deficiencies, but those are the apparent ones.)
.model 2SC6145-Y_kq NPN ; Revision 3 by keantoken - March 1 2019
+ Bf=93 Br=8 Re=8m Rc=16m
+ Rb=4 Rbm=0 Irb=0.3 Vaf=1000
+ Is=5p Ise=200f Ikf=200 Nk=1.9
+ Rco=0.68 Gamma=255n Vo=100 quasimod=1 Qco=100p
+ Tf=2.45n Cje=9.7n Cjc=880p Vje=0.68 Mjc=0.48 Fc=0.9
+ Xtf=30 Itf=15 Vtf=0.95 Xtb=0.9 Eg=1.16
+ Vceo=230 Icrating=15A mfg=Sanken
.model 2SA2223-Y_kq PNP ; Revision 3 by keantoken - March 1 2019
+ Bf=99 Br=8 Re=10m Rc=18m
+ Rb=2.38 Rbm=0 Irb=0.9 Vaf=500
+ Is=3.5p Ise=50f Ikf=3 Nk=0.15
+ Rco=395m gamma=14n Vo=30 quasimod=1 Qco=100p
+ Tf=3.65n Cje=8.3n Cjc=1.6n Vje=0.68 Mjc=0.48 Fc=0.9
+ Xtf=50 Itf=110 Vtf=2.6 Xtb=1.4 Eg=1.16
Revision 3 - Updated Ft behavior with measure capacitance values thanks to astx.
Sanken 2SC4883 and 2SA1859 SPICE models with quasi-saturation
I like the C4883/A1859 from Sanken, and have tried to model them well using the datasheet. It was tricky, but I'm pretty satisfied. I matched Vbeon, Ft, Hfe and quasi-saturation. Adding quasi-saturation makes Ft and Hfe MUCH more accurate, so I'd say this is in a new league of SPICE models.
The behavior shown in the datasheets is what I modeled, so I'm not sure about Early voltage or Hfe slope at higher voltages, but I think everything is close enough for a practical simulation, especially with quasi-saturation added.
Notice that the Vbeon curve on the datasheet specifies Tc=25C. If Tc is held constant, that means Tj increases with Ic! So I had to estimate the tempco and subtract that in order to get a match.
Where the Hfe chart and the Vce chart disagreed, I went with the Vce chart since it seemed more detailed. The discrepancy was not small at all!
.MODEL 2SC4883A_kq npn (Bf=140 Ikf=100 Is=600f Vaf=100
+ Rb=1.7 Re=105m RC=0 Rco=6 Ibc=150f Vo=30 Gamma=250n
+ Cje=1.2n Cjc=72p Tf=875p Vtf=1.2 Itf=1 Qco=8p
+ Nk=1.2 Br=2 Var=22.9 Ikr=36 TR=85n
+ Xtb=0.34 Xtf=1.36
+ Vceo=180 Icrating=2A mfg=Sanken)
.MODEL 2SA1859A_kq pnp (Bf=162 IKF=10 Is=500f Vaf=300
+ Rb=0 Re=0 Rc=90m Rco=3.25 Ibc=150f Vo=120 Gamma=22n
+ Cje=1.5n Cjc=72p Tf=1.9n Vtf=1.9 Itf=1 Qco=8p
+ Br=2 Ikr=10 Var=23 Tr=188.8n
+ Xtb=0.138 Xtf=5
  • Locked
Valve amp inrush question
I have just finished my new valve amp and I am now aware that there is a large inrush current.
Here the HT is connected to a GZ34 and then CLC, and the filament supplies a Rod Coleman regulator.
The question I have is, can I just add a thermistor straight after the plug (as shown above), and if so, can someone tell me exactly which thermistor I should use?
Thank you so much - I feel very old to be a noob, but hey ho.
Thanks again
Bass
T1000-1bdcp
Hello, working on a T1000-1bdcp. Power supply was smoked so I replaced power supply mosfets, output mosfets, 2 transistors on ps card, all three rail caps, and r200 on bd card. The amp powers up and plays but is drawing 3.6 amps at idle. The amp has a small speaker pop on turn on and draws less current when gain is turned up and as gain goes up I am getting a whine in speaker. Any advice? I have swapped a known good ps card and bd card with no changes.
  • Locked
Measurement Parameters - How many can be considered all?
How many parameters would need to be tested so that two or more amplifiers with all results matching could be considered to be identical soundwise?
Looking at various audio test equipment manufacturers' websites, I come up with this quick list.
Gain
Sensitivity
Power
Frequency response
Bandwidth
Phase Shift
Input Impedance
Output impedance
Slew Rate
Distortion (THD,IMD,TID)
Distortion vs. Output
Signal to Noise Ratio
Crosstalk
Anything else?
and if an extensive data base of all measured amplifiers existed, would it even be possible to find two designs that match on all the tested parameters?
If so, Would those amps sound identical?
DIY stereo amplifier
I found a DIY audio site for India region, they are selling prebuilt Dayton speakers and other DIY speaker kits but they don't have any stereo amplifiers, prebuilt or DIY kits, they are selling individual components, are there any schematics available for stereo amplifiers online, I can use to build them? Some DIY speaker kits come with cabinets, some don't, which would be better, if I buy just the transducers, capacitor kits, can anyone here tell me what dimensions the speaker cabinet should be? All DIY speaker kits come with soft dome or hard dome tweeters, the prebuilt Dayton speakers come with Air Motion Transformer tweeters, which is better?
General Toroid Trafo Question
I realize that I'm a little off topic here, not being specific to audio power. This trafo is however going to be used to power an aluminum casting furnace that is to be used for casting misc. audio components.
Here's what I need:
110V 1phase primary to around 1-6 volts secondary, with high current handling on the secondary.
What I did:
Coiled a 5" wide 'slit' of Arnon7 NGOES electrical steel into approx. 4.5 ID x 6 OD by 5" tall. Taped in place using high temp. flash tape. Wrapped single layer of aluminized fiberglass and taped in place with flash tape. Wound 12awg magnet wire to 110 turns. Wound 4awg single turn secondary. Applied power....SPARKS. Removed secondary and checked for shorts. No shorts found. Added 30amp fuse wire to primary (plus 20amp mains breaker) (no secondary winding) and applied power. No fuses/breakers tripped but the enamel burned off at exactly the mid point in the winding. This further confirms my belief that a short is not the issue (regarding bare wires in contact, I mean).
Okay, now what? The main thing I am aware of is that my aspect ratio is very bad, approx 1:1. And I know that 2:1 is optimal, or 1:2, depending on how you frame the definition. Is this the issue? Or am I way off kilter elsewhere too? I know that the Arnon material is pretty exotic stuff so maybe that is not helping matters either?
What to do? I had originally planned to coil the Arnon and then saw it into two cores for the ideal geometry, will that perhaps solve the problem?
Voxativ 'New acoustica'
Anyone built these, or have any opinions on them?
Voxativ AC–1a PRODUCTS
attachment.php
Quote from their website
AC-1a drivers
1,799.00 EURO
(Note: pricing is for a selected pair of drivers)
The newest entry-level Voxativ 8-inch full-range driver is equipped with a specific array of neodymium pill magnets to enhance bass response.
Each pair is delivered with the build plans for the 'New Acousta' back-loaded horn inspired by the original prototype loudspeakers built by Inés Adler that culminated in the birth of Voxativ.
This model also offers great resolution and best bass response when used in a Hagen Monitor or Tower configuration with or without Absolut system configuration.
Technical Details
Frequency Response
20 - 20.000 Hz
Efficiency
96dB (3 kHz) 1W / 1m*
Capacity
50 W nom / 100 W mus
Impedance
10,3 Ohm
Qts
0,46
Depth
3,2“ / 8,1 cm
Diameter
7,5“ / 19 cm
Weight
2,4 kg / 6,0 lbs
Sales price is for one selected pair and includes a digital download of build plans for the New Acousta.
Sundown SAZ-5000D Preamp Board Issues
Hello all. I've got isssues with a Sundown SAZ500D preamp board. It is not outputting any audio to the driver card. I recently solved this problem by swapping out IC102 (JRC074D) and it worked. However,the driver card failed and since then ths preamp board is no longer producing any audio. I replaced this IC again but now, I've got 6.2V of DC on pin 14 of this IC and no audio. (According to the datasheet, pin 14 should be output 4). When i crank the gain, bass and sub knobs all the way to the max, there is a small half of a sine wave riding along the 6.2V of DC but that only appears when i turn the gain, sub and bass boost pots all the wat too the max. I have swapped out this IC 6 times for brand new TL074 ICs and everytime i drop it in, the DC reappears in pin 14 and no audio. However, with the IC removed, I've got -0.6V on pad 14, -0.7V on pin 13(input 4). On all the other pads which are supposed to have audio (according to the 074 datasheet), there are sine waves present, but there are no waves present on 13 input. Can anyone advise me here on what else to check? I have got two of these preamp boards with the exact same problem. Will attach a schematic and some videos for reference if i can.
  • AQ20_SCH.pdf
    AQ20_SCH.pdf
TPA3255, TPA3251, PSU for this amps
Amp in photo.
TPA3255 in 2.1 mode, 2 satellite channels and subwoofer channel
TPA3251 in 2.0 mode.
All amp have PFFB
PSU LLC, 48V for TPA3255, 35V for TPA3251 , auxiliary +20v and +- 20v
AMP+PSU $140+ delivery
Firstwatt F5 DIY x2
BOTH OF THESE AMPS ARE SOLD
THANKS FOR THE INTEREST !
I have 2 Diy f5's for sale, both work great,were in my HT bi-amped decided need more Headroom so off they go asking $375 each plus shipping
ARCAM Alpha One repair
Hi folks
My Arcam Alpha one CDP has stopped reading disks. With no disk in the machine it displays 'disk'. When a disk is inserted it spins it up and tried to read it, during this time it displays '01' then the display returns to 'disk' and it has failed to read the disk.
I'm wondering if I should replace all the electrolytic caps in the servo section?
Or is it much more likely that it is the laser that has failed?
Is there a procedure to potentially diagnose the issue?
The SM is particularly unhelpful and just says send it back to ARCAM for repair:
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,910
Members
7,893,351
Messages
Filter
Forum Statistics
Threads
406,474
Messages
7,893,351
Members
507,910
Latest member
LiamY
