【need help】Has anyone measured the resistance between the LME49810 VCC/VEE and GND pins?
I've found some used LME49810s that I'd like to collect, but I'm having trouble judging if it's genuine. After the production was discontinued, the high price made fakes appear on the market~
Its font seems to be slightly different from 49830, and the stroke lines are a little thicker.
Sadly, for some reason, I'm currently unable to build a circuit to test it.
Previously, I successfully differentiated LME49830 quickly with reference to the experience of others. The pin resistance between VCC/GND of the genuine 49830 is approximately 60kΩ (Pin15 and Pin3), and that between VEE/GND is approximately 40KΩ (Pin10 and Pin3).
Out of the same idea, I want to know what is the resistance value between VCC/VEE and GND of LME49810, can anyone help me measure it? thank you all😉
Install Question
I have 2 digital designs amps hooked up in my truck .
1 of the amps is hooked up to the midrange speakers and the other map is hooked up to the tweeters .
When the amps are hooked up in the truck the amps do not work they don’t power up I checked the voltage at the amps terminals and I get 5 volts .
If I unhook the amps and I test the power and ground wires I get 14.4 volts .
I pulled the amps out of the truck and bench tested them and they work perfectly fine .
I went back and tested the battery and ground wire measuring the voltage on the power wire with the black probe to the ground wire and it reads 14.4 volts . If I hook the amps back up I get 5 volts on the power wire .
Any ideas what might cause this ?
Persistence.
One thing I have learned over the years is with troublesome or new electronics is to be persistent in trying to find faults or solutions to problems.
Giving up at the first problem just isnt on.
In 1980 I was fed up with being a labourer so went to the job centre.
I noticed a training scheme called TOPS (training opportunities scheme.)
So I did the maths entrance exam.
I failed by a few percent.
So went away and swotted up on the things I couldnt do in the exam.
Went back for a resit and passed (just.)
I started the industrial electronics course in July 1980.
On the first day I was looking forward to learning some electronics but got met with another maths exam to make sure we had enough to do the course.
I struggled badly even with some of the basics.
I was given some extra lessons learning maths to catch up.
After my first week studying electronics and maths we did a weekly exam and I barely scraped through.
My tutor said he was worried I wasnt going to make the grade.
One of the other chaps left the course due to problems.
I caught up with the maths and got up to speed with the electronics by also studying in my spare time in the evenings.
After a month or so we did a weekly exam and I was only one to get 100%.
At the end of the year we did city and guilds exam in industrial electronics and I passed with distinctions.
I guess the moral of the story is dont give up.
Just put the effort in and you will eventually get by.
I watch videoe's on youtube about Einstein and other geniuses and some of them got poor exam results early on.
But they kept going and eventually made it to the top.
NAD 320BEE capacitor query
Hi, I've just opened up my NAD 320 BEE and noticed that one of the big 15000uF 50V capacitors in the power section is starting to bulge. I've found what I think is a suitable replacement but the service manual says the original cap has a 10% tolerance. The one I'm hoping to replace it with has a 20% tolerance. Is this likely to be a problem? Many thanks for taking time to read this.
Buzz after changing tubes in preamp
Hello
I have a very interesting problem.
Recently I have ordered three Gold Lion ECC83 tubes for my DIY Marantz M7 preamp. I wanted a change in my system so I decided to change old JJ ECC803S’s. I have swapped the tubes and started it up. After the initial warm up of heaters, high voltage kicked in and immediately there was a buzz on my mid-range speaker on only right channel (there was no buzz with JJ tubes).
Tubes played beautifully, but there was that buzz (does not depend on a volume level).
I measured it with oscilloscope which can be found in attachment.
So I decided to swap tubes one by one with JJ tubes to find a problem (JJ tubes are still good). First one was the cathode follower tube (U3 on schematics, in attachment). I swapped the tube and there was no buzz. So I had two Gold lion tubes (preamp section) and one JJ tube (cathode follower) and the buzz was gone. Then I wanted to check if that tube is bad. I swapped JJ tube from cathode follower (U3) with another Gold lion tube from preamp section (U2). JJ tube was now in preamp and Gold lion as cathode follower again. The buzz was back.
So my conclusion is that the problem is in the Gold lion tube as cathode follower and that the tube itself is not bad. It seems that the Gold lion tubes are more sensitive than JJ tubes.
I tried to shield the tube itself with an improvised shield (aluminum foil wrapped around cardboard tube box and connected to GND) but there was no difference.
The high voltage is regulated with linear regulator and the heaters are powered via DC voltage (linear regulator as well). I have posted schematics, pcb layout, oscilloscopes measurements and photo of the preamp inside the housing.
On the preamp_1.jpg photo, red lines are AC line of power supply and green lines are AC lines for VU meter lamps that can be switched on or off (the tube buzzes either in on or off position). All AC lines are quite far away from the U3 tube.
So my questions are:
- what could be the problem?
- why is only the Gold lion tube affected with this and why the JJ tube is not?
- why did I hear u buzz in my mid-range speaker on only one channel (difference between buzz in left and right channel)?
Thank you in advance
  • preamp_sch.pdf
    preamp_sch.pdf
Orbitsound Dock E30 inspired single box stereo speaker - design considerations
I really like the Orbitsound Dock E30. The sound quality is great, airsound effect cool and it is small enough to fit into a suitcase when traveling by car. I would be afraid to put it into checked luggage while flying. This gets me thinking...
Here is some nice exploded view: https://barnabyward.com/project/dock-e30
Showing us that:
  • all three speakers share the same volume
  • there are three passive radiators
I wonder how all these interact. I wonder if the small full rangers are something one can buy or if they are custom made.
Also, the "airsound" effect is adjustable, it says +-12 dB - would that be just a simple relative volume for the S component? One review said that at minimum setting the sound si practically mono (need to try that).
I wonder if something of similar performance in a smaller travel friendy package (with lower SPL of course) could be built. The box itself could be 3D printed, it could use e.g. three of these https://www.madisoundspeakerstore.com/approx-2-fullrange/sb-acoustics-sb65wbac25-4-2.5-full-range/ or maybe, on the cheap side, Visaton FRS-5X or maybe the 2" inch Sica full range or smaller BMR drivers? I should still have some TEBM35C10-4 from another project. Any suggestions? My favourite 3FE22s would end up with a too large box...
For the bass, this looks like a possible solution (taking 0.5l of volume though and quite expensive for what it is): https://www.soundimports.eu/en/tang-band-pr08-a.html. Any other suggestions for low volume bass? Maybe a bit of EQ boost would be all needed - and it would save one amplification channel as well.
For the amplification, I have tried some nice small bluetooth class D amps, there are plenty of them. No option for EQ there, some have bass/treble EQ built in, but I prefer the ones without. Powered from a laptop brick, since I always have at least one with me.
While thinking out loud like this, I think the BMRs will be a good start in a simple printed box with external processing and amplifications. Then, at phase 2, all of this would be built into one box. Another line on my never ending list of potential projects🙂
Dual power to single power rectifier filter
While browsing I stumbled across this little unit.
https://www.google.com/url?sa=t&rct...0636547.html&usg=AOvVaw1cK44bh8dR93w0nk2DjbJz
As I have several +/- trans that I have removed from none working units over time, I wondered in it would be any good to convert them to a single line.
Also if I had say a +/-25 VAC tans rated at 300 watt. What could I expect when passing the voltage through this unit. More VDC of more power, or no change?
Cheers
Strange output transformer measurements - please help explain
I have a pair of custom made PP output transformers on EI130 laminated core. The core is a common laminated silicon steel core used in mains transformers. The number of primary is 2 x 1600, the number of secondary turns is 2 x 80. The turns ratio is 20.
Now I wanted to measure the primary inductance, so I connected a 1:1 isolation transformer to the primary and applied 240VAC to it. I measured 12.1VAC on the open secondary, which is about good. The primary current was about 0.8mA. From the XL = 2*PI*f*L I calculated XL = 300kohm, and L = 950H. Is it realistic? I think it is a bit too much 😳 I still have to measure stray capacitances, and where they resonate with the stray inductance.
I also tested it by loading the secondary with a 12V car headlight bulb. Considering the primary and secondary resistive losses all is good. The DCR of the primary is 285ohms, the secondary is 0.5ohm. I had 130mA on the primary and 8.7VAC on the secondary. It seems that is 26W power flowing through the transformer, and the bulb gets some 22.5W after the secondary loss.
Anybody ever measured a commercial OPT? What primary inductance and resistance you get normally? Perhaps my open-circuit measuring method is not correct.
6N2P-EV vs 12AX7
Can someone speak to similarities and differences between 6N2P-EV and 12ax7, given that:
Both are wired for their correct pin out @6.3V in the same circuit and the power transformer has adequate current for either.
(I believe 6N2P requires 40ma or so of additional current over a 12ax7)
Some have said 6N2P-EV to be more closely related to a 6SL7.
I’d rather not rehash the better known differences, but instead get down to what might be some differences “beneath the surface”
Opinions abound as to where they stand in the scheme of things. With the best NOS 12ax7’s in “absurd” cost territory, what do you all thing of the 6N2P-EV’s worth in circuits traditionally with 12ax7’s?
What are the relevant differences we might need to consider?
My understanding is that if the 6N2P-EV is an equivalent, it would be at least in theory superior to the 12ax7 as from what I gather it has a grounded shield on pin 9 to reduce crosstalk? They also seem to be rated for more hours and are built to be more robust (for mil application). They are also WAY cheaper than a 12ax7 Telefunken!
By the same token I’ve also heard 6N2P-EV has more fluctuation from sample to sample.
I have swapped 6N2P-EV and 12ax7 and heard repeatable differences, but I’m not sure if the same would probably be true if I swapped 12ax7 for 12ax7 of different make or manufacture. I.e. just normal variance.
I didn’t do double blind testing. I’m just not set up for it, so take my casual observations with a grain of salt.
Unfortunately also i don’t have a curve tracer or I’d do some detective work... but I’m greedily eyeing the uTracer so that might come to fruition sooner rather than later.
So, I figured I’d ask those much more adept than myself:
Can I assume the 6N2P-EV is a drop in, given attention to the above or is there something I’m missing?
Are the data sheets accurate to real world samples? Same operating points?
I wonder if anyone out there has gone through and tested a couple dozen or so of these from different factories and can provide some info as to their spread as well.
What are the best years and factories?
Are there other 6N2P suffixes that are superior? I believe EV is a ruggedness criteria.
As an aside: Someone I spoke to who was from Russia mentioned that from Gorbachev onward the quality of tubes and other mil parts was not the same. He said he definitely wouldn’t buy tubes manufactured in Russia after 1991 but ideally none before the mid-80s. Do others share this view?
Thanks in advance for your thoughts and insights.
Questions regarding wavelets and phase measurements
We spent saturday afternoon and evening to align a 5 way horn system using wavelets. I have two questions about the method and the resulting phase measurement.
1. When using wavelets I would assume that you set delays of both speakers so that the center of the wavelets align, not the first sine peak as shown here (From top to bottom: 1. original signal, 2. low-pass filtered with LR4, 3. highpass filtered with LR4, 4. sum of both filtered signals):
The green line IMO shows the correct point to align them, the red line clearly shows that this point in time would be ambiguous as the low pass filtered signal has a longer period length, the high pass filtered one has a shorter period length. only point they sum correctly is if the center of the wavelets are aligned. All in all that should be plausible, the summed signal also shows a 180° phase shift at the crossover frequency as is to be expected from a LR4 filter.
Are my assumptions correct?
2.: Here's the minimum phase as generated from a measurement in REW for the whole system at the listening place (grey: phase, axis on the right - purple: SPL, axis on the left):
I thought that each of the 4 LR4 crossovers would show a 360° phase shift around the crossover frequency? Why does the resulting phase appear to be almost flat from 20Hz to 20kHz? Seems that either something is off here ore my assumptions about the 360° phase shift of LR4 summed signals are incorrect. OTOH as I pointed out the top graph clearly shows the 180° phase shift at the crossover frequency for the summed signal. I'm a bit puzzled here. Maybe I misunderstood what the term "minimum phase" really means, would these phase shifts from the LR4 filters not show up in the minimum phase plot?
Reactions: krivium
Frame grid voltage triodes for audio?
I want to learn about small frame grid triodes, how do they behave differently from a coiled grid triode in V1, splitter or driver positions? What was their reason to come into use? etc... I'm organizing tubes to clean the basement for Easter and see I have a crapload of 2HK5, 3HK5, 4HK5 and 6HK5 tubes. And probably other frame grid tubes too when I start to look them up. When I started this hobby I was buying TV-repair tube caddie's at swap meets whenever I saw one.
Google didn't bring up much about ?HK5 tubes for audio. Anyone try ?HK5 for audio?
https://frank.pocnet.net/sheets/201/6/6HK5.pdf
2ohms or more ... good quality speakers?
I am not sure if this is the right section, but if a moderator thinks it should be more appropriate to be posted in the multi way section, please do it for me!
I'm looking for a good quality and probably higher SPL than usual pair of 2ohm speakers for a germanium amplifier that cannot withstand high currents and high voltages.It can deliver 1... 3 Amps and up to 6...7v rms and that's just all about it...so i'm looking for a nice speaker or multiway speakers that can move very well on this "magnificent" output.
It may be that a 4...8 ohm regular high spl speaker would do the job, but i'm not experienced in this area so i'd like to hear your advice. I thought that maybe the Fostex fe line would be a good value for the money and pretty sensitive but i'd like to keep this topic open for anything around the idea cause i might not have anything against going active and multiway thus multiplying the power with each additional amplifier although I wouldn't look to power anything more than just a normal living room like 5/4/2.5 m yet if it's a padded room it may need more watts than what I'd expect.
Thank you!
Dream multicell horns
Some days ago, I had a dream about friend's band playing on a small stage with a strange PA system. There were so.
me subwoofers of unknown type, but on top of them were huge multicell horns - 4x4 cells, mouth size maybe 120 x 120 cm, each cell had its own full range cone driver around 3-4" size. Since the cells did not have to come to a single point, the front was less curved than a single driver multicell.
Has anything like that ever been used? Or built? I vaguely remember discussing such an idea here.
I can see this with 3FE22s with ca 30x30 cm mouth cell. Is it a completely stupid idea to build such a monster? I imagine it could have a killer low distortion midbass to midrange and very high sensitivity. I wonder at which frequency beaming would start. If such a thing could be optimized in size to be usable from 150 (200) Hz to 3-4 kHz and used with a matching dispersion horn tweeter, it could be an impressive system both visually and sonically - since I really liked my printed multicell horn.
Zyklop: interesting new FAST by Visaton
Hi all,
Here is an attractive new design by Visaton, a FAST crossing at 270hz towards their B80 full range speaker.
Cleverly, the BR opening is between the FR and bass cabinets. It does look nice, for sure:
Details (in German) including plan are here:
ZYKLOP
Zyklop
Listening test in magazine Hobby Hifi can be found here:
Strassacker: Lautsprecherbausätze (Lautsprecherboxen-Bausätze) und Lautsprecherlösungen
I don't have the magazine to see the measurement under 30 degrees but they say that it is best to orient the speaker towards the listening position, the B80 beams from 5000 hz upwards.
Comments?
Visaton W130X
Friends I am new in DIY and found a driver Visaton W130X that is different and not much data on implementation.
Idea is for 2 applications Powerful Bookshelf 2 way maybe 1 Full and 130x as woofer or 2 woofers
and a Compact Hideaway type subwoofer that can be used for music and movies
1-2 drivers room is 16ft -25ft
Experts please suggest
regards
anand
Simple Universal Speaker Delay Using A Triac
This project is aimed at those wanting to add a simple speaker switch on delay to an amplifier to eliminate the annoying and possibly speaker damaging thumps/pops/bangs that many amplifiers make when first powered up and the sometimes strange noise when powered down.
The term "universal" comes from the idea that the design can be scaled to suit most amplifier power supplies and that the delay time is adjustable.
The aims of the design can be summarised as,
1. To work with a wide range of transformer voltages.
2. The switch on delay must be repeatable and reliable and must give the "full" delay time even in the event of a brief mains interuption or cycling of the on/off switch.
3. The relay should drop out near instantly on power off.
4. Power saving is used by running the relay at reduced coil voltage yet with a high voltage "pulse" to close the relay smartly and reliably.
These points will all be explored by understanding how the circuit operates. That in turn should enable the user to be able to alter the circuit to suit their own requirements.
The circuit...
I drew the circuit in Spice more for clarity as much as anything else, however I found that it was possible to simulate it as well although the component
values used in the simulation are different from the "real world" values that the circuit works well with. This simulation problem is almost certainly
caused by the Triac model used. So on to the real circuit... understand how it works and you can modify it to suit.
(And why a triac ? To "kick" the relay with a high pull in voltage require that the device driving the relay operates quickly. A transistor "drifts" into
conduction as the base current rises which would not pull the relay in quickly enough when the relay is fed from the power saving series resistor feed)
The power supply.
D1, C1 R1 and R2 form the PSU for the circuit. The AC feed can be taken from across one or both secondary windings depending on the voltages of the
transformer. The circuit is not ground referenced in any way.
D1. Half wave rectifier.
R1. Can be added if desired. A small 0.5 watt resistor both acts as a safety feature (consider it a fuse) and also might make life a little easier for C1.
R2. Helps discharge C1 when power is removed.
C1. Is the "reservoir" cap. The small value ensures a rapid drop out of the relay on power off. This cap should be of good quality, possible a slightly larger 100 volt component as these have a more generous ripple current rating.
The timing components.
R3 and C2. These are the "timing components". R3 has to be "low enough" to supply sufficient base current to Q1. So to alter the delay C2 value can be
varied.
The trigger circuit.
D2, R4 and Q1
D2, the zener ensures that no base current flows until the voltage across the timing cap has reached the zener voltage plus vbe of Q1. R4 ties the base of
Q1 to ground to ensure it never "floats" when the zener is non conducting. Q1 conducts when base current flows. Q1 should be a reasonably high gain device.
The Triac.
The triac is a BTA16-600SW device. This is a "sensitive" gate trigger type (easily triggered) and has a low "minimum holding current". Triacs are
interesting devices and can be triggered in one of four "quadrants" depending on the polarity of the voltage across the main terminals. Once triggered the device remains conducting and can only be turned off by interupting the current flowing between the main terminals.
(Refer to the pinouts of the triac in the data sheet AND NOT the LTspice symbol which to me is back to front)
MT1 connects to the relay.
MT2 connects to ground.
The triac is triggered by pulling the gate to ground. This is done by trigger Q1 as explained earlier.
The remaining components.
The relay coil is fed via a series resistor. You will have to determine the value of this depending on the relay. Get this value correct and the relay will
run on a much lower coil voltage than its rating saving power and producing less heating in the relay. My relay was a 12 volt 500 ohm device. There is nothing to stop you running two relay coils in series or parallel depending on what suits best. The triac seemed happy with holding currents below 10 ma.
C3. This "kicks" the relay with the full supply when it activates and ensure a smart and rapid pull in. The value can be up to a 100uf if the supply
voltage is low. Even a 22uf works well on the higher supply voltages.
D3. The clever bit. When the triac triggers the voltage on MT1 falls to near zero. We can use this to pull the voltage on the timing cap to near zero via the diode. This ensures that the timing cap is ready to "start again" should there be a brief mains interuption or quick operation of the on/off
switch. The diode also serves as a snubber network across the triac in series with C2.
Real world components values.
470K and 47uf works well for the timing components R3 and C2. These give around an 8 second delay.
For 18 Vac input the zener should be around 6.2 volts.
For 36 Vac input a 15 volt zener is better.
R4 is 560K
Select the series feed to the relay to suit.
The pictures.
1. The circuit diagram (but refer to text for values)
2. The timeline of operation showing the delay, the voltage across the triac and relay and the relay current.
3. A close up of the transition period.
4. The relay "kick" current.
5. The triac pin outs. A1 and A2 are "main anode" which equate to MT1 and MT2 (main terminals).
Finally the zipped folder contains the simulation files which will run in LTspice.
  • Simple Speaker Delay Simulation Files.zip
Sony CDP-C201
Hello,
I am new here, so my apologies if this is in the wrong area. I have a Sony Stereo system from 1990 that I am trying to restore, the CD player a Sony CDP-C201 is giving me some trouble. It’s very intermittent where at times the laser housing will not lift to read the CD, when this occurs just lifting with my finger fixes the issue for the time being. I have applied Super Lube to the gears, but did not know if there is another lubrication area that I should be looking at? I’m pretty novice at this and don’t want to damage anything beyond repair.
Should I get a Fluke or a cheaper multimeter?
My old Craftsman multimeter was lost in a car Break-in. I've decided to build an Amp Camp Amp and a Korg Nutube preamp and then whatever this new hobby (rabbit hole) puts in front of me. Should I get a Fluke 289, with graphing capabilities or a cheaper multimeter and a bench multimeter or an oscilloscope? I need a multimeter in my tool box and I play with electronics a bit.
Does anyone have some wisdom that might help me to get tools that will help me without wasting a lot of money?
Thank you in advance for sharing your wisdom and/or point of view.
Cambridge audio a1 mk1 not powering on.
Hello so i bought a cambridge a1 mk1 (the original version) off someone and they said that the main board glass fuse blew and to change it and it would work. However after changing it the amp still doesn't turn on.
None of the other fuses had blown, it was the T3.15A which blew which is the last fuses. I also read a few youtube comments which said it could be the transformer since none of the first fuses blew.
Can anyone help me?
I have a DMM so can test things if needed be.
Rookie questions
Building my first set of speakers and keep coming up with questions. They are the Swans HiVi 3.1. Ordered parts for the upgrade. I soldered all the parts just like the pics because i wasn't sure if the caps and resistors were directional. There is only one coil upgrade and i was wondering if it was directional, or didn't matter which leg went where. The other coils were self explanatory.
Thanks Paul
Sharp SC9570AV distortion, missing output channel
~15 year old, wasn't plugged in/used for past 3-4 years.
I have a recording of the working speaker, kind of cracking high distortion. Nothing out of the other one. These are using his 120w. I have some 10w PA speakers that both work on, so it probably has issues with the higher load from the 120w speakers but I might be wrong
I brought a 40W PA amp to his house and hooked his speakers to and both sound fine on it
Caps DO look good, but might be dried out
First recording is on AUX from Cable receiver. That in itself sounds worse than the second selection, which was the receiver
I know it's not a high quality brand that some of you deal with, but this man dosn't have much money right now, cost him a good bit back in the day. Single package amp, I think A-B, on fairly big heatsink with fan
CD does not work but I bet it's the belt
Pignose Hog 30 repair and mods
I have recently come to possess a Pignose Hog 30, which I would like to use with my bass ukulele (Self contained electric acoustic u-bass) (yes I know my ubass has it's own built in amp, but I still have the output available and I'm hoping to get even more volume).
Of course the Hog is old, and the lead acid batteries are long gone. A couple of the pots are broken from over-tightening, but these should be pretty simple to replace. But for the batteries, I am thinking to go with li-ion and improve on the run time and weight. So I am wondering: the TDA7240A amp and the NJM4558 op amp in this thing can actually take 18V, so why not run it on 18V and make it a little louder? Would this damage the rest of the circuitry? Obviously I will have to get a different charger, but I would anyway get one that matches to the battery I get. I am looking at 18Vpower tool batteries as a good option. Obviously these will run a little over 18V when full, but this should not be a problem for the chips, right?
I also found this mod: https://www.talkbass.com/threads/is-there-a-pignose-for-bass.74568/#:~:text=I've had a,resistor (was 47k). and it obviously sounds simple and desirable. So I am interested to know if there is a risk of damage to anything doing this? What about doing both - increasing the voltage and the gain mod?
See the schematic and chip datasheets attached.
Pre - Estate Sale : Cool Rare parts and accessories
Hi All,
It's been awhile since I have been active on this site, situations beyond human control have taken me away from my beloved audio hobby, and left me in a fight for life. Unfortunately, that fight has been lost; cancer has won, and now, I am dying. That said, I am now starting to go through the years of accumulation,and begin liquidation of my toys. Cancer treatments / surgery are horrifyingly expensive, especially when one doesn't have great insurance, and I am trying to be able to pay for a decent burial, leave my other half a little something, and honestly, put food on the table for the next little while. This is the first pile of stuff that I've gone through, there will be much more to come! Make me offers folks, no reasonable offers refused! I accept Venmo and Zelle payments. Thanks!
Krell Industries: CD clamps / center pucks for the early MD series cd transports, Model KDI. Quantity 2, asking $100.00 each. These are impossible to find, for the most part.
Krell Industries Star - Clamp cd clamp. For the KPS20i & 30 players. Rarest of all, and the only clamp that these machines function with. $300.00
Gryphon "The Exorcist" : Interesting little system / cable demagnetizing widget. Super-clean condition. $150.00
Theta timebase linque conditioner : Anti - jitter box. Nice condition. $200.00
Acoustat MK-121-2A electrostatic interfaces. With the famous (and preferred) Medallion series transformers. This is the second pair I owned, was going to build myself another pair of 3x4 electrostats, but never got around to it. Asking $350.00 for the pair. SOLD
Selenium D3300ti - 2" throat high-frequency compression drivers. VG condition. Nice-sounding, smooth drivers. Asking $200.00 / pair
Miscellaneous VPI, Rega, etc. tonearm counter-weights, many available. $50.00 to 100.00 each.
Bozak B199a - 12" woofers. 2 pair. 1 is good, original condition, second is still original except that one cone was poorly patched after it was damaged (not by me!) Asking 200.00 / all 4
Velodyne various subwoofer drivers. 2- 12" DD series (servo), one 10" DD series (servo), and 2-MASSIVE 8" (not sure of series). Asking 125.00 each for 12", 100.00 for 10", 200.00Pair for the 8" units. 107.JPG108.JPG110.JPG111.JPG112.JPG113.JPG114.JPG115.JPG116.JPG135.JPG137.JPGDSC00267.JPGDSC00268.JPG
LAPT problem
So im making one P3A more .....
This time i thought like testing 1216 -2922 Lapt combo
if my rails are more or less up to 36+36 volts i am ok above that i get oscilation
anyone gan guess why?
is it because 1216-2922 is lapt ?
with in the day i will replace them with the standard 1302-3281 combo to make sure thta nothing else is wrong in the circuit and get back ...
this is a bit weird since all the rest is pretty much the same and i ve made this board and choice of parts a gozillion times .
Stability issues in LTP with elevated grid
I'm currently fiddling around with a tube preamp prototype, in which I've decided to try out using a 6SL7 differential amplifier/LTP as a front end. The operating point is set using a cascoded BJT-CCS in the tail. This is then AC-coupled to a grounded-cathode amplifier stage, which is DC-coupled to a cathode follower as a final stage. Both of these stages uses a single 6SN7.
To make it easier to stabilize the NFB-loop, I have tried to DC-couple the feedback path from the cathode follower to G2 on the input stage LTP. Therefore, the grids are elevated to 33 V by the voltage divider in the NFB-network, and a capacitor provides the AC-ground path for each grid-leak resistor.
I've noted that the elevated grid circuit is having issues with low frequency oscillation at <1 Hz. This is without signal, an is probably started by grid current from the first half of the 6SL7 (?). I discovered it when measuring the DC-voltage (33 V in the schematic), and found that it is fluctuating up and down slowly. Am I missing something obvious here? Is there some simple way to stabilize this elevated grid circuit? Increasing the capacitance will only slow down the time constant, and then it takes ages for the cap to charge up.
please change thread title
I started a thread about a Horn, but I didn't put this into the title and that is a disservice to the project !
Can you change the title for me, dear Mods,
https://www.diyaudio.com/community/threads/khorner-fast-waw-using-altec-808-8a.383814/
Instead of "khorner fast waw using altec 808-8a" let's try "The legendary K-Horn using altec 511B and 808-8a" ???
Thx
CM915 Power Amp Info
I recently acquired a CM Labs CM915 professional power amp and I'm looking for information about the amp. I believe it was manufactured in 1983. Is the 915 a special order amp? I read someplace that CM Labs took special orders for their amps. Any information and history of the CM line would greatly be appreciated. Did the 915 follow the 914, or was it produced alongside the 914?
I've attached a few photos.
MTM/ D' Appolito tweeter position, middle or to the side?
Quick question.
Making an MTM style T-line with 6" Tang band mids and 1" Tweets.
The Fs of the tweeters is 1,4kHz, so I don't know if I can make a lower crossover point than 2,8kHz?
Should I place the tweeter in between the mids or put the mids closer and the tweeter next to them?
The tweeter seems to have pretty optimal response at that width, when it's on the side, when I looked at it with a baffle simulator.
That would also get the mids closer together, but I have heard that the off-axis response will be unsymmetrical.
What would be better?
Unholy Alliance Phono Amp
Combining glass, sand and iron (I'll be using an MC step up), and various ideas picked up here. The basic schematic is from Dmitry (don't know if he posts here, but has some good stuff on his site): www.dmitrynizh.com/3a5-phono.htm.
The HV supplies are based on Salas' shunt reg., and the transistors in the filament supply are those recommended by Rod Coleman. Gyrator from discussions among Wavebourn, Michael Koster, Kenpeter, Revintage, Smoking amp, etc..
I still have to build the case work, so I haven't given it a listen. As shown, the response is within 0.3dB from 20Hz to 20kHz. I can tweak the network resistor values a bit, to get it even closer Channel to channel it's within 0.1dB over the entire range, if I match the tubes. (BTW, the Hagerman calculator seems off to me. I actually measured the Rp of the tubes in the circuit (which were very close to the values measured from the curves), so my calculations there are accurate, and I was a little suprised that my initial measurements were off at the 20kHz end by 0.75dB. When I calculated the time constants from the Hagtec calculator values, they were lower than the expected 75 and 3180us.)
The circuit values are as tested.
Sheldon
Considering selling my F4
Was bought like 10 years ago. Factory built probably my Nelson Pass himself. Has been in continuos use since then. Now mostly displaced by an X25 and Vfet. Has its scratches by its continuous movements -none in faceplate- works like new. Exploring to sell it. Has original manual and box. I have not determined price yet because I have to check on shipping options which have to be by air.
Thanks for looking.
Marantz CD73 Philips CD303 improving CD-R playback
For all you who like the beautiful sound of TDA1540s but have trouble playing CD-R then this small mod might help playback.
This is specifically for the Marantz CD73 and Philips CD303 however experience shows that so many players from this era have the same decoder setup.
I've been playing around with these players now for some time, and can suggest many other changes to improve sound reproduction, and many things never to do even though they're on this site....
This focuses on the RF side on the top decoder board. People may suggest tampering with the mechanism however apart from a total re-cap I would highly advise against it.
This is for the SONY decoder board, the Philips board is described below.
Capacitors 22nf near the SAA7011 are nice big RF foil antennas, degrading the RF. Pull these out and swap them around (reverse the polarity) putting the high impedance on the inside where it should be. This is easy 5 minutes work.
Solder a cap (I used a 8.2pf mylar) to the top of the resistor (part 3552) next to the de-modulator SAA7011 on one leg(this also goes to pin 13 of the SAA7011) and the other leg of the cap to the cap (part 2655) that goes to the SONY daughter board..
Almost there... you might have to decouple the clock a tiny bit, maybe one or two turns anti-clockwise. This is the white screw thing next to the SAA7011. Be careful the screw thread is weak. Some SONY boards use a mismatch of components. If this is the case the cap can be soldered on the track side of the board.
This is for the Philips board, 2 bottom pictures:
This mod would be interesting to many owners of these CD players, not just the Marantz CD73 but Philips CD300, Marantz CD44, 74 ect. Pretty much any identical chipset.
Again 22nf foil Capacitors near the SAA7011 need swapping around (reverse the polarity) as described above. Yellow arrow.
Inside this Philips CD303 there is a resistor with a ferrite bead next to the 7010 Decoder. You need a 220pF cap to go from this resistor (not the bead side) and to RF ground.
Have a look at mine, there was a nice place to put it that makes it look factory. Red arrow.
This is where you play a CD with the top open and IF NEEDED carefully decouple the clock one or two turns anti-clockwise (green arrow). My suggestion is find a CD-R that is scratched and had no chance of playing before and put it in, when playing decouple the clock to improve playback. When satisfactory stop playback then press play. If the CD wont track initially then you have decoupled too much. Screw it back half a turn at a time and press stop and play again. Once it plays satisfactory then test the player with proper store bought discs to ensure all is good.
The second last picture shows the block diagram of the decoder board and the red arrows show the location to connect the capacitor. This will mainly help those who want to adapt this to a player that is not a CD73 or CD303.
The Last picture is a close up view of the Philips decoder board for easier reference. The Blue arrow shows the electrical connection of the capacitor.
While you're there why not a recap? I prefer Nichikon fine gold series. Especially the two that pass the audio to the OPAMPS. I have also found decoupling the DACs with 100nf WIMA caps to be an improvement also....
Hope this helps others enjoy the glory of these 14bit(noise shaped) players! Feel free to comment on results. 🙂
PYLsgWPPKA7cXUf4l5qmNOfuRmV0diSriVZjgfl82Tz6-cUgzI6z2GH6-xWZd1a8KIJ9hsHIJMIKCOaPgvJtLwXhuvWpwl4JCK_UIaCIMmWNFdakJraPquDJEN1CPMIKggtHclci=w1204-h903-no
BsSLy91KWhxw8visBNJpg3aF6x7M5y0ECG7XPwBboyI-6fFsWpHlG0ZhAUDy-MrZ5aHOXsDlx6PCHuEr1JW2zCVHKVJrtRSrs9zFc3VGxcSf4iY21NVRiNHce2kisi5YIj3AbSqZ=w1204-h903-no
9Qg7W9rTPui3j47031bHyuL9DxxXFMfBg8gPelpnCH-14XXzH_dxtX4S19GOQJyK9tbfOGh3wedfirNVN8X4DhNBmxoU8ms8XN5lbHF1AlF_W0W_vq9TbmZblpvGvrkQ88w1QQ_O=w1204-h903-no
597S7YS4Gq0emauRJXGswxwUrs0rAvhKk_HrWtNZF-Ynv05RZHtBA3XszGxZf0J1trWK6YBRSDXiSU6tDLSLoK2nGxY-vPFBhefOcZelTQ2FqUEIh1iktJj4ADr81lmQkguhoBCamfSRhU6S5PXkGaHDDNJoNv9yOXm7eImosiLaM88GzyYcUrIKpK2MZtBXdv3ECyDb7RcXB7zvIMoDNrzUOzD98Y88jDFgSBCMzg9CSlZyOY7ehsQvjdPqxXfReUb_7or-ywWy31XaHEPvu6EVBnA1a2PJ2P6acVeUfQVBovSTi-MpGCxdwhz4BWIRqlrQNdHvspe9-Sz0F6kgo2qggkqmOhWsu0fqwuqwN6Iw0pEIL-oBlJUrQq2SHq-hxnoZt4IKGXoe6p0SVMmU7p-6L55JgjvXvRajTWMPuIrfoy8GD_i0AmGQRIioSBJ1Zoe61sOPhP1Q3MkOmEnhd6qT2i9VGiOWLWXH4-GSHS31inOuzOw11PH1MGRzomCphHil0Ni6I7M084Wv-SG0kr8jYPDsA5ib8si4_MTDjDRbcx5bqVx0oaAZsjHtmIwpaGgiZlp09rShwNULc5V05b5sqYjVy0KisFeOiRU=w1204-h903-no
Subwoofer wiring woes
Hi all,
I recently bought a 300w sub with a broken power board for 15 quid.
I stripped out the power board and the fancy low pass filter, frequency modulator, and volume control board out. Then bought an L7 MOSFET mono power board that supports 300-350 W at 8 ohms as well as requiring 2x 50 V in, this is exactly what the transformer outputs and what the driver requires.
I also picked up a 2M ohm potentiometer for volume control and a 100Hz or so highpass/lowpass filter (i always get it the wrong way round)
because it's a mono out board I'm having a lot of trouble trying to work out how to correctly wire it all?
Any help?
Finlay.
(https://www.ebay.co.uk/itm/221254643945?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20200818143230&meid=f1091f7470794e6eb76178fa92c156f5&pid=101224&rk=2&rkt=5&sd=224405663394&itm=221254643945&pmt=1&noa=1&pg=2047675&algv=DefaultOrganicWeb&_trksid=p2047675.c101224.m-1 link for power board)
(https://www.hifigear.co.uk/epos-els-subwoofer.html link to sub)
HM100X - Simple 100W power amplifier BR
Hello friends...
Here in Brazil we have a very active diy audio community and due to research I am bringing a new circuit for your enjoyment.
It is a simple audio amplifier, polarized with diodes, with an option for ground suspension of the input signal, 100W, full CCS and differential current mirror
Around here in Brazil we have a lot of bad circuits that are shared on the web that leave DIY people very frustrated when they set up and it doesn't work, so whenever I can I share new tried and tested ideas.
Here are some data measured on a bench
Power: 100W @ 4 Ohm
Sensitivity: 380mV
Input Impedance: 47kOhm
Frequency Response: 10Hz~191KHz @ 3dB
Damping Factor: 995
Simulated THD: 0.02% @ 1KHz (real life measurement will happen soon)
Schematic:
PCB:
Prototype PCB:
SCHEMATIC UPDATED: 08/17/21
🙂 I am a happy DipTrace user🙂
Reactions: Zohaib Ahmad
Dipole midrange in a 3 way.
I have a three way loudspeaker with a dipole midrange. Is the sound emanating from the rear side of the midrange supposed to be reflected back to the listener or is it ideally supposed to disappear and never be heard by the listener? I asked as my loudspeaker position is not ideal as the left speaker is located where the rear of the speaker opens up to another room, while the right speaker is 2 feet away from the corner. No other positions is available at the moment.
Which Preamplifier is Suitable For Class A (Jean Hiraga 30 W or Pass Lab)
Hello Everyone,
I make Two channel Jean Hiraga Super 30 W Class A amplifier....
Just I am using this amp with Blameless Preamp. (Only Volume Control No Tone Control)
Sound is very Nice But on small Speakers "feel" lack of Bass ....
What is your idea about Preamplifier for Class A ? With Tone Control ? or without Tone Control.?
Which Other Preamplifier are suitable ..please suggest
Thanks In advance...
Operational amplifier AD623 is a good choice
The instrument operational amplifier AD623 directly replaces the single operational amplifier op27, and the effect is very good
I observed that the internal circuit of AD623 consists of three operational amplifiers, but in fact, it can directly replace single operational amplifiers such as 5534, 797 and op27
I wonder if there will be any other problems with this application
Actual Filament Current about 300Bs
Hello, I'm constructing a 300B Single Ended Headphone AMP for my friend. And I'v finished the design and test of a Filament Constant Current Source for DHTs, using the schematic based on the public version of Rod Coleman's Kits.
But now I have a severe problem that my friend has a pair of Takatsuki 300Bs on his present AMP, and it's hard for him to test the actual filament current by himself. My filament kits can only provide current higher than 1.3A due to the resistor values, should I change the resistor values for a lower minimum current?
Any actual filament current about 300Bs provided will be of great help, Thanks🙂
(Actual means accurate 5Volts on the pins of the tube)
Here are some pictures😏
My first speaker+amp build with Dayton RS100-4
Hi everyone !
I am new in this forum, and also in diy audio, so sorry in advance if there is a lack of technical informations/measures.
I would like to show you my first speaker build.
I must admit that after beginning to design a cabinet with speakerboxlite.com I found this article and chose to copy this design (for the technical part) since it was made with the full range drivers that I intended to use (the Dayton RS100-4).
My goal was to make small enough speakers with a small amplifier and a DAC to put on my desk and use them on my PC.
Since I didn’t like the design of the front panel with two ports, I changed the design a bit to cover them with fabric in a single slot.
For the amplifier / DAC part, I found the Up2stream Amp v3 from Arylic which turned out to be just perfect for me since it includes a DAC with Wifi, ethernet, bluetooth and usb inputs, plus a mini-jack analog input. It’s sold without a case, so I could do the design of my choice.
I have no measurements of the frequency response, but I can say that it was a big improvement over my Audioengine A2+ (It’s also not exactly the same size) and that I’m now just waiting for an opportunity to get into a new project.
I hope you’ll like it, well, at least the look since I didn't really design the rest of it ;-)
Some "not so nice" picture while it was made :
And some better photos made once it was finnished :
Reactions: stv
Pace SX-100 VS Hakko FR300/301
Have been a Hakko 808 / FR300 user for over 15 years. Being in the UK, I used to deal with the excellent and friendly Dancap Electronics, which made everything so easy (one phone call, 24 hrs later the new tips / filters / etc arrived). A couple of years back, Dancap got bought out by HK Wentworth... Having bought from Dancap for years, I no longer had credit and was asked to pay for everything in advance. As of 2022, Wentworth have introduced a £250 MOQ. Although I use the FR-300 (have 3 Hakko desoldering machines, an 808, 471, FR300) as a job, the £250 MOQ doesn't sit well with me, as Wentworth are such a PITA to deal with.
The SX-100 is easily found at Farnell, and the tips are cheaper. I can get just about every part on 24-hour delivery. Obviously, it's pricier than a Hakko unit - but if I'm being forced to spend £250 to keep it going, I can put the Hakko stuff on Ebay and added to the £250 I'll have nearly as much as the SX-100 costs. The convenience of the SX-100 is light years better than anything Hakko, and the parts are less expensive, so the investment will likely be recouped on a year or two.
So, my question is, how do they stack up against each other? The FR300 works fine on 2-layer, but starts to become harder work on 4-layer. The SX-100 has more heat power, but does it have more suction? The best aspect to the FR300 is the power of the motor. The Hakko bench 471 doesn't have anywhere near the suction power of the FR300.
Will I regret going to the SX-100?
Thank you in advance!
The Aleph-X
We'll pick up the story in the middle.
I sent Nelson Pass a schematic back in December to ask if it qualified as an "Aleph-X" circuit. He made encouraging noises, but warned me that I’d have a problem with DC offset. Normally, I would have begun prototyping then, but a virus showed up on my PC and started corroding my stories and, sorry folks, but I had to save what I could of my stories. They make me money. So far, I’ve yet to figure out a way to make audio pay; at least not without going back into retail.
About a month ago I finally got to build a prototype. What you see is the result of my fiddlings, plus a nudge from Nelson. In particular, the very first thing I did after Nelson warned of DC offset was to draw a schematic showing two 1k resistors to ground, one at each output. I tried it, it didn’t work, and no value I regarded as reasonable at the time seemed to make any difference, so I abandoned the idea. Nelson suggested putting in grounding resistors on the order of 30 ohms, which nearly gave me a heart attack. <i>That</i> low? But it worked. I’d like to thank him for that hint, because I never would have gone back and reexamined the idea without a nudge. I had the front end worked out, which by itself will get rid of a fair proportion of the DC offset, but not all. Put in the resistors, and the thing suddenly becomes manageable.
I hereby release Version 1.0 of the Aleph-X.
A word about nomenclature:
--Nelson’s commercial version of the amplifier is called the XA200. I am specifically avoiding calling this an XA-anything, as I don’t want there to be any confusion about this circuit vs. the real thing. It accomplishes pretty much the same objectives, but I don’t know how close it is to what Nelson’s building. In short, don’t confuse the two. Don’t ask Nelson why he did the circuit this way or that. He didn’t. I did. It ain’t his fault. This is just me staying up late at night after I get home from work, trying things.
--I was sometimes referring to the circuit as the Mini-AX during my R&D. I’ve decided to fall back on my earlier name to avoid any confusion with the Mini-A that I did a couple of months ago. Besides, some wag would probably decide that if it’s a Mini-AX, then clearly it must be a hatchet, and I’ve had about all the ‘humor’ I can stand.
--When I say "X," I mean Super Symmetry. A bad habit, I suppose, and I got caught on this very issue in a recent thread, and although most of you will know what I mean when I say X, there is the possibility that someone sufficiently familiar with the Pass Labs product would point out that not all X product is "X." <i>Sigh.</i>
Acknowledgments:
This circuit is directly based on two active patents belonging to Nelson Pass of Pass Labs, 5,376,899 and 5,710,522. In a sense, any circuit built using information gleaned from either or both of these patents belongs to Nelson. Period. If he says desist, ours is not to question why. We desist. Immediately. In particular, this circuit is not to be built for commercial purposes. Nelson has to make a living, and this is his intellectual property we’re playing with.
On to the circuit.
If you’re familiar with the Alephs, the schematic will fit like a pair of old, comfortable shoes. Everything is just about where you’d expect it to be. Well, almost everything. The input resistor network is the same as the Volksamp Aleph models. There are two other things about the front end that will catch your attention. One is the little resistor triptych that I’ve substituted for the usual 221 ohm Source resistor above Q6. Why? Well, that’s the absolute DC offset adjustment. It works by setting the DC voltage present at both of the output stage Gates. Since it’s common mode, i.e. the same current is fed through both sides of the front end differential, it amounts to zilch as far as the signal is concerned. The values I chose will give you a little over 10% play in the front end current, but I needed very little of that with the test circuit.
The other oddity about the front end is the way the signal criss-crosses over to the opposite side. That’s what makes this an "X" circuit. That’s necessary so that the feedback coming in via R16 and R30 will be of the proper phase.
I’ve added two things to the Aleph output stages that aren’t canon: The pots, V1 and V3, and the output resistors to ground. V1 and V3 serve any number of purposes, depending on your point of view. You can run your bias up and down to suit the amount of heatsinking you have on hand or for sound quality purposes. You can view it as a distortion-buster, in that an imbalance in drive between the sides will give you some zillionth of a percent distortion, and you can tune the sides to be in harmony with one another. And lastly, you can use them to zero out small amounts of relative DC offset between the sides. If you want to use them to set the bias, then replace them with a fixed resistor, that’s fine. For that matter, you can replace V1 with a fixed resistor once you determine the proper value. Any remaining DC will be equal across both outputs (like the SOZ, for instance), and the speaker won’t notice it at all. But make sure to at least start with a pot in there, as having 10 volts of DC offset will hamper the voltage swing at the outputs. Get it as close to 0V as you can before you put in a fixed resistor; don’t just assume the standard 221 ohm resistor will do the trick.
There are resistors on each output, going to ground. Nelson suggested 30 ohms. I’ve played with a wide selection of values and can assure you that if you get much higher than 40 or 50 ohms, the thing starts getting pretty twitchy. You can adjust the front end pot all you want, but it won’t stay put. If you use a lower value, it snaps into place quite nicely, but then you’re wasting valuable output power straight to ground, so it turns out that something around 30 ohms really is a pretty good compromise.
The resistors can be removed entirely if you want, but you’ll have to use a servo to tame the DC. I’ve worked one up—discrete, no less—and if enough people are interested, I’ll post that, too. For the time being, the schematic shows the purist way, sans servo.
One last thing, be prepared to fiddle with the values of R12 and R34 in order to balance the current source against the output. Turns out the value is sensitive to the thermal environment, and yours will be different from mine.
So what’ll it do?
Well, clearly, it’s derived from the Mini-A, which was (given enough current capability) a 10W amp. This is a bridged Mini-A, so it’ll do four times the output, minus a bit for the resistors grounding the outputs, call it about 37W or so. I’ve used .22 ohm resistors for the output MOSFET’s Sources, so it’ll do a pretty good job of servicing a 4 ohm load. If you want to actually double into 4 ohms, you’ll need to go a whisker lower. If you’re confident that your speakers are a level 6 or 8 ohm load, feel free to back off the bias current by putting in, say, .33 or .39 ohm resistors under the Sources. Since the first thing people did after I posted the write-up on the Mini-A was ask whether it would drive 4 ohms, I figured I would start there and let people back up if they wanted to.
If you want more power, you’re going to need to start doubling up on the output devices. That’s pretty easy to do, so I’ll leave that to the individual. (What, you thought I’d give you a full-blown XA200? You’re going to have to work for it.)
This is a more ambitious circuit than the Mini-A in many ways. It will, for one thing, require a more substantial power supply. The circuit, as drawn, will pull a bit over 4.5 amps. Think in terms of a 200VA transformer, minimum. Lots of capacitance is in order. In fact, you might go so far as to consider a regulated power supply. Nelson just published a nice paper on regulated supplies over at www.passdiy.com.
A word about parts is in order. While, strictly speaking, you don’t have to match the output devices for this amp, it’s not a bad idea. The closer the two sides are to behaving identically, the better performance you’ll get out of it, and the less trouble you’ll have with DC offset. That said, I managed to get rid of all DC with a set of unmatched IRF644s.
Which brings me to another, related, point. There’s been a lot of talk about matching parts in other threads. I know I had trouble getting IRF644s to settle down in the test rig—waiting as long as ten minutes before I got figures I thought I could live with. Funny thing...I got in some IRF044s for this project, stuck them in for testing, and the little fellers sat right down and behaved themselves in less than a minute. Clearly, there’s some sort of thermal thing going on here, but I’m still mulling it over.
I’d like to end by noting that I’ve been remiss in answering e-mail for a while, mainly because I only have so many hours in a day, and I needed every available waking moment to work on the circuit. I know at one point not too long ago, Joe Berry sent me a schematic of an Aleph-Xish kind of circuit. It wasn’t like this one, but by the second or third try he had the differential cross-over trick in hand, but nothing in place to handle the DC offset. I believe he was modeling the circuit, rather than building it. What he ever did about the DC, I don’t know, as he was one of the people I quit responding to ‘cause I just couldn’t afford the time. Sorry, Joe. I’m back among the living now, except that I’m so tired I can hardly see straight. Staying up late so much has taken a toll.
Maybe now I can get some sleep.
Except...I had this really neat idea the other day...
Grey
P.S.: I had a more elaborate write-up, but ran into the 10,000 character limit on posts. Bummer. Had to edit the thing pretty savagely to get it to fit. Apologies to anyone expecting puns and jokes like in the Mini-A write-up. There just wasn't room.
14years of (nearly) daily use electrolytics which were overvoltaged.
Hi, I have used 40V 68 000uf caps on 43.7V rails for a 14 years. It was my daily background amp so it had around 20-35hours a week or total 25 000+ working hours. it was class A amp with lot of heat inside. I thought it was time to recap and maybe replace them with 63V rating. Measured them 8psc in series and capasistance were within spec (for a sngle cap) Epcos sikorel caps.
I had also accident when i wrongly soldered in 25V 220uf Nichicon KZ instead of 100V 47uf (same cap size) in 66V suply . I did noticed this AFTER 2 days (around 2-3 working hours) when after adjustments i decided to assemble amplifier completely.
having gone trought this all I can do is to recomend take manufacturers specified ratings with grain of salt. this definately looks like a scam to me (forcing customer to buy higher voltage cap=more expensive, by spreading wrong information)
Need p3a schematic for 2sC5200 2sa1943 pair
Dear friends I just need p3a rod Elliot amp schematic that uses 2sC5200 2sa1943 I have found on Internet many times but could not get good results I have some schematics downloaded from internet.. If there any need of changes so tell me. If any one have good working schematic than he can easily upload here ..
Thanks in advance ...
I have some schematics which one is better? 1st one or 2nd one?
Anthem MCA5 Noise
My MCA5 has developed a crackling noise on a single channel (left main) recently. The sound to the speaker sounds like it's cutting in/out. I disassembled and checked all connections. Reassembled, and everything sounded just fine. But, a few days later the noise continued.
This amp is most likely the same design as the MCA50, but I've read that the MCA50 upped the rated power to 225 WPC vs 200 for the MCA5. They also increased heat sink sizing. I've owned the MCA5 for abotu 17 years and I've used it regularly for years. The only real difference lately is that I'm using the balanced inputs lately. For many years I used the coax inputs.
I have the tools and capability to replace PCB components, but I'm not entirely sure where to start. Any help would be appreciated.
Shoulder slung, waveguide, synth beamer
First-time poster, long-time reader. I have looked as deep as I can but I have not found discussions regarding a design in this direction.
In university in the 80s, I saw a performance where the artists left the stage with battery-powered units containing a small synth and an amplified speaker in the end of a 3-4 foot long acrylic tube about 4" in diameter. They bounced sound off objects and turned the whole auditorium into a moving sound environment. It was very cool. The idea of moving outdoors in a sculpture park, or industrial space, tiled tunnel, and creating soundscapes is compelling.
I am starting to build a more capable version and working through the theories of projected sound. The intent is to have a beam of sound. As this is an instrument and not reproducing existing sound, there can be color, naturally would like the sound as true as possible given the constraints.
I am starting to firm up the design directions. The system will run off a lithium-ion bike battery 48V 15A powering a 100W amplifier. The system will allow various synth options. This being said and the models below, I am not an audio expert and am very open to directions. The horns will be produced from either composite materials, carbon fiber or flax fiber, or thermo molded acrylic.
Horn designs with compression drivers seem best suited to this task. Conical shapes seem to intuitively beam more than flared end shapes. I have designed the length and throat diameter around the lower frequency of the driver 300 Hz, as well as the maximum manageable portable size. The horn in the images below is 1.14 meters and has a diameter of 0.36 meters. The taper is based on the linear progression of the length and the circumference being equal, with a smooth curve from 50.8mm at the mouth.
The second design is based on a parabolic reflector. Based on systems used in museums for projecting into specific listening areas. The system would ideally be modular so that different waveguides could be fitted bayonet style. The dish is sized larger than the horn, but I am unclear on the approach here for sizing to frequency. The compression driver is piped forward and reflects from the rear-facing parabolic dome to the main parabolic dish. The intent is to direct waves forward in as tight a beam as possible and have them break up and reflect back from objects in the environment.
stratotron001.jpg stratotron003.jpg stratotron004.jpg stratotron005.jpg stratotron008.jpg
Thanks for your time!
Thoughts on driver measurement
Had a thought. It is a bit of a pain, and some times risky even when you think you have limited the sweep bandwidth, to test a tweeter directly on an amp to get the response and phase for crossover design, SOP is to add a blocking cap, but now you have a 90 degree phase shift in the phase measurement
Could one just plop the data into Excel and add 90 degrees to make a valid acoustical phase component?
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,744
Members
7,886,463
Messages
Filter
Forum Statistics
Threads
406,154
Messages
7,886,463
Members
507,744
Latest member
HMac60
