Heat tracking of discrete BJT Darlington pair using dissimilar devices
- By SomeJoe
- Electronic Design
- 3 Replies
Hello,
In a scenario where a darlington pair is built using a high-current low-beta device driven by a signal high-beta transistor, what is the recommendation for placement of the driver, close to the output device's heatsink or on the contrary farther away so it doesn't pick up heat from the high-current pass transistor? Logically the driver should thermally track the output device, since in a monolithic Darlington they are on the same die no? I also have observed that the darlington input drivers tend to be next to their output transistors in power amplifiers. Thermal issues causes and effects are still a bit fuzzy to me, I would appreciate an explanation of the thermal effects at play in such a situation.
Below is a tentative pcb layout where I put the driver (Q1, TO-92) inside the output's transistor (Q2) heatsink fins, the output device being on the other side of that heatsink. Note that this circuit is high voltage (200-400V).
As always, thanks for any insights. Regards,
- Joris
- Joris
