| Specification | Details |
| Amplifier Type | Hybrid (Tube + MOSFET) |
| Tube Used | Tung-Sol 12AU7 (Dual Triode) |
| MOSFETs Used | IRLZ44N N-Channel MOSFETs |
| Power Output | ≥1W/channel into 32Ω; ≥300mW/channel into 300Ω |
| Power Supply | AnTek AS-1T150 Transformer |
| PCB Design Software | KiCad |
| Chassis | WHAMMY Case (80mm H x 210mm W x 230mm D) |
| Volume Control | Single Blue Velvet 10kΩ Audio-Taper Potentiometer |
| Testing | To be conducted by a certified electrician |
| Component | Specification | Quantity | Description/Notes |
| 12AU7 Tube | Tung-Sol 12AU7 (Dual Triode) | 1 | High-quality audio tube |
| Tube Sockets | 5-Pin Ceramic Tube Sockets | 2 | One per triode channel |
| Cathode Resistor (Rk) | 100Ω, 1W, Metal Film | 1 | Sets baseline cathode bias |
| Cathode Bias Potentiometer | 1kΩ, 1W, Audio-Taper (Blue Velvet) | 1 | Single potentiometer for both channels |
| Decoupling Capacitors (Ck) | 0.1µF, Ceramic | 2 | One per channel; stabilizes bias voltage |
| Grid Resistors | 1MΩ, Metal Film | 2 | Connects RCA inputs to tube grids |
| Coupling Capacitors | 10µF, 400V, Film (e.g., Panasonic EEFUE0G101R)| 2 | Blocks DC; allows AC audio signal to pass to MOSFET gates|
| Stability Capacitors | 100pF, Ceramic | 2 | From MOSFET gate to source for high-frequency damping|
| IRLZ44N MOSFETs | N-Channel, Logic-Level | 2 | One per channel; consider heatsinks if necessary|
| Gate Resistors | 10kΩ, 1/4W, Metal Film | 2 | One per MOSFET gate for stability |
| Source Resistors (Rs) | 1.7Ω, 10W, Wirewound | 2 | Handles current buffering; ensures low impedance output|
| Output Capacitors | 100µF, 50V, Film (e.g., Nichicon UFW100C) | 2 | DC blocking at headphone outputs; non-polarized film capacitors|
| Heatsinks for MOSFETs | Suitable for IRLZ44N (e.g., Velleman AN20) | 2 | Ensure proper thermal management |
| Transformer | AnTek AS-1T150 | 1 | Provides 150V AC @ 0.33A and 6.3V AC @ 3A |
| Rectifier Diodes | 1N4007 | 4 | Full-wave bridge rectifier for B+ supply |
| Filter Capacitors | 220µF, 250V, Electrolytic (e.g., Nichicon UG2J221MPD) | 2 | Smoothes B+ DC supply |
| Schottky Diodes | 1N5819 | 2 | Voltage doubler configuration; low forward voltage drop|
| Electrolytic Capacitors | 1000µF, 25V, Electrolytic (e.g., Panasonic EEU-FC1C100) | 2 | Filter capacitors for voltage doubler |
| Volume Potentiometer | Blue Velvet, 10kΩ, Audio-Taper | 1 | Controls overall volume before tube stage |
| RCA Input Jacks | Shielded, Mono | 2 | One per channel; high-quality for audio fidelity|
| Headphone Output Jack | 3.5mm Stereo, Gold-Plated | 1 | High-quality, gold-plated recommended |
| Fuses | 1A Slow-Blow, 250mA Slow-Blow, 500mA | 3 | Protects AC input, B+ supply, and low-voltage DC|
| Star Ground Bus | Bus bar or Heavy Gauge Wire | 1 | Central ground point to minimize ground loops|
| TVS Diodes | Suitable for AC Mains Protection | 2 | Protects against voltage spikes |
| Chassis | WHAMMY Case, 80mm (H) x 210mm (W) x 230mm (D) | 1 | Accommodates all components; ensure proper ventilation|
| Mounting Hardware | Screws, Standoffs, Thermal Paste for Heatsinks | As Needed | Secure components within the chassis |
| On/Off Switch | SPST, Rated for AC Mains | 1 | Controls power to the amplifier |
| Fuse Holders | Inline Holders for Respective Fuses | 3 | Mounts for 1A, 250mA, and 500mA fuses |
| PCB | 2-Layer, Custom-Designed | 1 | Designed in KiCad; ensure high-voltage isolation|
| Connectors | Screw Terminals for Transformer Connections | 1 Set | Facilitates power connections to PCB |
| Wires and Cables | Various Gauges, Shielded for Audio | As Needed | High-quality for signal paths; proper gauge for power|
| Thermal Vias | For Heatsink PCB Areas | As Needed | Enhances thermal management on PCB |
| Mounting Hardware | Screws, Standoffs, Spacers | As Needed | For PCB and component mounting within chassis|
