SP AUDIO 8K, need help
Hello,
I am looking for the electronic diagram of this amp or the component references (all mosfets, dual diode, C5, D32, D48 and R104.
THANKS
All of the output FETs use the same driver components so you can get the part numbers and values from those.
Are the dual rectifiers actually defective?
I don't have the diagram for this amp but a similar amp uses the IR4227 for output FETs. Someone else may have a more definitive answer.
The PS FETs may be IRF1404 if they use 10 ohm gate resistors.
Reactions: coed1992
