Hi All,
I’m starting this thread to share a new project of a 4-way sealed speaker. It will use the following drivers:
• Tweeter: Peerless XT25SC90-04
• Mid High: HiVi Research DMB-A soft dome
• Mid Bass: Vifa P17WJ-00-08
• Woofers: Two Dayton Audio DC200-8 8” Classic woofers
The woofers will be mounted on the sides opposing each other. The driver selection wasn’t based on extensive research or data analysis - I simply listened to the mid-dome driver at a friend’s place and loved it, so I’m designing this speaker around it. Below are the SketchUp 3D models of the box:
The box will be 1050mm tall, 450mm deep, and 264mm wide on the outside. It will be built with 18mm MDF, with an additional 12mm layer of plywood or MDF on the sides. The midbass chamber will have approximately 11 liters, targeting a Qtc of 0.707. The woofers’ chamber will have about 65 liters, with a Qtc between 0.6 and 0.7.
The box will be veneered with two types of wood:
The sides will be finished with an Imbuia veneer, a typical Brazilian wood that resembles walnut. The front, back, and top will be finished with an ebony veneer. I’m not sure what type of wood the ebony veneer is, as it has been artificially darkened. I haven’t decided yet between a matte or semi-gloss finish, but I’m leaning towards matte. The design for the feet is still in progress.
My goals with this build are:
• Have fun building it. I’m well aware that designing a 4-way speaker isn’t easy, and I could have chosen a proven design. However, that would only challenge my woodworking and building skills, which isn’t my primary goal.
• My current 2-channel system uses a pair of Klipsch RP-6000F floorstanders. I’ll consider this build a success if it offers better soundstage, imaging, and clarity.
The build is already underway, and I’ll be updating this thread with pictures of the progress. Please feel free to contribute, offer criticism, ask questions, or even make fun of it! No hard fellings! 🤣
