go to this website : Tokopedia.Com its an Indonesian online thingy, I purchase Shinkoh there no worries reliable
just type shinkoh resistors in search.
Plenty here for less than 4 euros each: https://partsconnexion.com/shinkoh-resistor-750k-ohm-0-5w-1-tolerance/
Thank you, may take a look there.go to this website : Tokopedia.Com its an Indonesian online thingy, I purchase Shinkoh there no worries reliable
Thank you for pointing this out, that's a pretty good deal right there. It's just that these are around 1,000 times the resistance I need. The topic reads 750R-1K range, which, I know, is asking for some very rare stuff.Plenty here for less than 4 euros each: https://partsconnexion.com/shinkoh-resistor-750k-ohm-0-5w-1-tolerance/
The reason for posting here is that hopefully there are some members here who have hung on to some of these and can spare two resistors.
partsconnexion's shinkoh ranges have depleted lots, I too bought some from them & other stuff as well
Are you still looking for those Shinkos?
I might be able to help you get them here and ship them to you (only the 750R 1/2W seems to be available).
My estimate for 2 resistors, including shipping, is around $22.
Just PM me if you're interested!
You could also consider these new smd tantalums. Nobody has compared them to shinkoh, but there are a few very positive reports.
If its for grid stopper duties, the small form factor should also be an advantage and could allow you to use a smaller value.
https://eu.mouser.com/ProductDetail/Vishay-Thin-Film/PNM1206E1001BST5?qs=oBjDkOCjPF1yfL5d/O1R6w==
Thank you for this suggestion LongRanger. Unfortunately this board takes only THT resistors in these positions but these SMDs could be interesting for other projects. Can you post links to some of these reports if on this forum? I have looked at Welwyn/TT tants but found available values to be patchy.
1206 is quite big. They probably fit on the THT layout.
Availability is unfortunately limited but one can get creative with paralleling resistors(this in itself could also increase sound quality since many people prefer higher wattage resistors).
I guess the more we buy these resistors the more they will get stocked.
They are both about cheaper magnetic versions.
https://www.diyaudio.com/community/...lifier-from-jm-plantefeve.407035/post-7790240
https://www.bartola.co.uk/valves/2021/11/21/01a-preamp-by-nash/
Dont know which version andrea was using: https://www.diyaudio.com/community/...ed-master-clock-group-buy.291925/post-7294021
Also grid leak seems to be the best place for tantalums. As a grid stopper some find them too coloring.
