Isolated DSC2 DAC
- By savan
- Digital Line Level
- 14 Replies
Hello,
This is fully isolated DSC2 DAC project, I'm finished this dac and here is project files for their build. Curently I'm not tested this but my hope somebody from you do it. Note that main buck regulator accept maximum 100V and minimum 5V at the DC imput, and I have set fixed 4.4Vout from the buck. You no need clean DC on DC input since push pull and LT3042 will make clean supply DC voltage for DSC2. Main care must be done to iso push pull reglators because it not accept more than 5.5V!!! You need to wire ferite to 1.2mH on primary and on secondary you need to have 7V, so please do the things carefully right before you put the rest of components on board! Take a look to schematic!
PCB dimension: 90 x 81.5 mm
Ferite is: FEPTN10/6-3E25
dimension: 10,6x5,2x4,4 mm
AL 2250nH
Primary: 1.2mH + 1.2mH, with center tap! Secondary - do it yourself for 7 Vout.
DSC diff current: my choice was 8mA diff, if you need less calculate your resistor values for dsc! My choice was 10k resistors since my i/v frontend accept this value. This is also I think good enought for an transformer based i/v, and I used those 10k values in original dsc2.5.2 with this audio transformer -> https://it.aliexpress.com/item/32810421236.html
Resitor value calculation formula for IdiffMax=+-8mA :
5V / ((0.008A / 32) + (0.008A / 32)) = Rvalue
C_NP and R_NP components if need! Its connected to one of the mount hole pad which will be connected to the case trought metal spacer, and in case you have some noise on iso side you can put resistor and capacior there e.g. 1M + 10nF .
Let see your build, thanks! Enjoy!
AL 2250nH
