If I put my notes here, I might be able to find them again later!
Just the buffer, ma'am.
I've had quite a few requests for the bboard buffer circuit without the built-in regulators, so here is a bboard 2.1 standalone 2-layer board, measuring 5x8 cm. Gerber files attached in zip file.
It is designed for +/-12 V rails, but the circuit will work with anything from +/-5 V to +/-18 V. A regulated power supply is recommended.
This is a line buffer. It intended to drive cables, not headphones.
Available for $15/pair shipped. Several people have asked me about kits. I figured the BOM was so basic it wouldn't be necessary but I can send you the boards with the parts to populate them for $50/shipped. You will still need to provide the power supply.
BOM attached. (updated to 21f4)
Total Comments 0
