If I put my notes here, I might be able to find them again later!
B-board v2 line driver : development circuit
Original version is here.
I've been meaning to get around to updating this by folding in the improvements to the diamond buffer stage made during development of the Sapphire 3 headphone amplifier. Here is the first look of the bboard v2 under LTSpice.
I've gone back to simple emitter resistors on the input, running under much lower current to keep the input impedance high. The output is simplified to a basic Sziklai compound transistor pair with the bulk of the bias current running in the second transistor.
In terms of distortion, for line level output level, CCS loaded input has no advantage. I'll have to double-check PSRR and a few other things before signing off on this version though.
FYI only, not a production circuit.
Total Comments 7
Comments
Posted 1st November 2015 at 03:26 AM by abraxalito -
Posted 2nd November 2015 at 01:04 PM by rjm -
Posted 4th November 2015 at 01:15 PM by abraxalito -
I've had a chance to confirm that now. About 50 dB for resistors and 75 dB for a CCS, but the PSRR of the CCS version starts to drop above 5 kHz due to C1 C2, while it drops above 30 kHz when C1 C2 are removed. At 100 kHz the PSRR is 50 dB and 66 dB respectively.
Thing is, the response peaks badly when those capacitors are removed.
What to do, what to do?Posted 5th November 2015 at 01:32 AM by rjm -
Here's a crazy notion - replace R11 and R12 with 1.4mA CCSs. Then you can have your 100pF caps to iron out the 10MHz+ peaking and still get decent PSRR - 76dB at LF and still 64dB @ 20kHz. But two more CCss means more complexity.... But transistors are really cheap when SOT23s so the cost-up is pretty insignificant.
An alternative comes to mind - split R11/12 into two and decouple the centre point with a big enough cap. Not tried that but should also improve HF PSRR.Posted 6th November 2015 at 02:17 AM by abraxalito
Updated 6th November 2015 at 02:23 AM by abraxalito -
Posted 10th November 2015 at 12:38 AM by rjm -
Posted 10th November 2015 at 01:47 PM by abraxalito
