Would you buy a used car from that guy
Nope! I reckon the key factor is that the bowls are not tuned - there is nothing for the mind to grab on to, which it can use to try and make sense of the "chaos of sound" - it has to deal with the raw sound, and if that is not inherently self-consistent, well, it just sounds like a mess ...What about chime bars or tubular bells Frank, they ARE tuned instruments
The mind will latch onto the tune produced by the instrumental bells, and then ignore the bad rendition of the harmonics - it will "fill the gaps" ...
On an OT, singing bowls are about as good a way of highlighting system issues as anything - have a CD of these played by a decent practitioner, plus a real one, nice piece of shiny brass, in-house - not used for audio purposes, whatsoever! The genuine article creates an intense tone that cuts like a knife through your skull, it's all those higher harmonics going full chat - playing back the recording, a typical dud setup outputs a dull, dead grinding that makes no acoustic sense at all - what's this crap supposed to be, a casual listener would be prompted to say.
So, sometimes the ears are a touch useful ...
VA - Ultrasone Test Demo CD (2006)
Dan.
My Thoughts Also...
Dan.
Not a chance.Would you buy a used car from that guy
Dan.
The 180 hours run-in time indicates that it takes a long time to get accustomed to the crappy sound... or to prevent customers to ask their money back..but this Memento - BE Beryllium Solid Core Cable RCA Interconnects is brilliant. I love when new wonder material is used for one path, but not the other. Be alloy for signal, copper for return.
Maybe better links to:
Synergistic Research - Acoustic ART System
System | Synergistic Research
Tibetan Prayer Bowls look alike's.
Acoustic ART BASIK | Synergistic Research
Is a book with prayers for better sound included?
It's not clear, does it have items which are not music, which can be compared to real world items one has around the house - an example, dropping a set of keys on hard tiles ... ?
The Synergistic Research Tesla T2 SE, T3 SE and PowerCell 4.
Dan.
The inventor, Nenno de Zoete (a.k.a. Swami Amano Subhauti) is heavily into spiritual meditation and has no technical background.
Dan.
That situation does not call for prayers but for spells (or sedatives)Prayer book is for when the missis finds out what the fancy bowls cost......
Yeah, it's full of ''real sounds'' tracks.It's not clear, does it have items which are not music, which can be compared to real world items one has around the house - an example, dropping a set of keys on hard tiles ... ?
Do yourself a favour and download it.
Dan.
Okay, I see your point - there's plenty there, for humbling most audio setups of a pretentious nature, good one!Yeah, it's full of ''real sounds'' tracks.
NASA admits functional test of zero point energy inertial drive.
And it works.
Sucks to be a flat earther. sucks to be a negative proofer.
Time to put the head on the curb and take back all the virulence, violence and ridicule that the monkey has cast at and into those who knew better.
So when the time finally came for all those derisive, nasty, viscous, borderline psychotic negative people to take their garbage back home, to get what is coming to them....suddenly the room was empty and so silent you could hear a pin drop.
They all went home shamefaced and silent. Brooding, waiting for the moment when they could pounce out there and fling poo again. There ain't no learning in them.
They can dish it out but they cannot take it. Not a single stand-up thinking human among them. Some of those people are in this thread. There is no getting around that.
In the final analysis, this is just one instance out of a thousand in the past and and thousand more to come.
Shawyer says that his company, Satellite Propulsion Research Ltd., has successfully tested experimental versions of the thruster. But many scientists have dismissed or downplayed such claims, saying the propulsion system violates the law of conservation of momentum, Wired UK reported.
In 2012, however, a team of Chinese researchers built their own version of the system and found that it does indeed work, generating enough thrust to potentially power a satellite. (ed: 72 grams) Then, an American scientist named Guido Fetta constructed his own device, which he calls the "Cannae Drive," and convinced the NASA team — which included warp drive researcher Sonny White — to try it out, which they did over the course of eight days in August 2013.
And it works.
- Member Areas
- The Lounge
- Funniest snake oil theories
