I'm sure it will sound even better with one of these sitting near it!
Bybee Audio Video Signal Enhancer
Nah that's waaaay to cheap, must be a con
If you use this very reasonably priced wire you wont need any of that quantum bothering stuff - Audio Note AN-CABLE-900.1 SOGON96 silver speaker wire Hifi Collective
As an added bonus, self flagellation with silver wire works way better than it does with copper. A banker told me so it must be true!
I think it's about time we moved on, how about titanium wire? or maybe a potent blend of polonium and mercury cryo treated on board the international space station.
Hifi Collective of your money more like....they must be trippin'.
Some more sensible prices here - http://www.ab-system.hk
Dan.
Dan.
You call that sensible prices?
Are you on drugs?
If yes, then can I get some?
If no, maybe you should try some.
but this Memento - BE Beryllium Solid Core Cable RCA Interconnects is brilliant. I love when new wonder material is used for one path, but not the other. Be alloy for signal, copper for return.
@tattoo: Actually, I have one of their HA USB to spdif adapters. It was quite reasonably priced and works perfectly. Their cable prices are far more than they need to be , but far less than some other wire peddlers are charging. In the old white hat vs black hat classification, I'd put them in "light gray."
Reality Is For People Who Can't Handle Drugs....
USB Isolator for USD23.00 + postage USD3.00 sounds perfectly sensible to me, so much so that I just ordered one for T&M purposes.
Dan.
I think you misunderstand me,You call that sensible prices?
Are you on drugs?
Dan.
"This cable need 180 hour run in." It's like letting green bananas get yellow.
Truth In Advertising ? ....
I'm not sure that this translated like they think it does...600W type R bovine pure linear computer power / have a fever PC power supply
Dan.
Dan.
- Member Areas
- The Lounge
- Funniest snake oil theories
