Some people might like a Vbe multiplier onboard with various configurations. I like the one at this link but am open to others.
http://www.tcaas.btinternet.co.uk/jc-3.gif
There is a good discussion of alternatives here:
http://www.hagtech.com/pdf/vbe.pdf
dshortt9 said:Some people might like a Vbe multiplier onboard with various configurations. I like the one at this link but am open to others.
I can make place for such VBE multiplier. It's easy to convert it to multiplier that I used on my first LM4702 PCB (jumper + NPN transistor instead of PNP).
This is only a draft. You can see FETs on this schematic but there is a place for TO247/SOT93 transistor with ECB pinout.
http://www.audio.webd.pl/pdf/monster_amp.pdf
Like I have said before, I disagree with the National guys saying you don't need a heat sink on this chip. I have run it without cooling for a while, but I don't think it is a good idea.veteran said:dfdye, maybe it won't be much bigger I can place transistors in front of LM4702 (mine is running quite hot so I will need a little heatsink for it).
Oh, and no surprise that the board will be big!
My prototype output boards have been larger than I would have wanted but I think with a separate board you can be a little more efficient with the layout. Since you are working with one board, I can see the potential problems. Good luck! I am sure you will get something good.
BTW, I think you have inspired me to try Mosfets with your board.
That looks like a great start, but with my limited experience, I have to ask why you have two transistors (T1 & T50) when most of the designs I have seen/used only use one. This is not questioning whether it will work, but I simply don't know the answer.veteran said:This is only a draft. You can see FETs on this schematic but there is a place for TO247/SOT93 transistor with ECB pinout.
Joined 2002
I moved my test board on a bigger heatsink. It's time to order some Toshiba's transistors
I thought there might be some advantage but after further thought I can not think of any. Works the same as one. Looks better on paper?
Work in progress. Board will be big... but not to big - about 130x120mm. Power transistors on the left and right edge. I added emiter resistors for PNPs.
Dshortt9, if there is some place why not try it
Quick question: What mosfets are you using? I am about to drop an order in for some other stuff and I figured I would play around with mosfets since they seem to be in the mix and working well.
Thanks!
David
PS What PCB software are you using? I have hit the size limit in the free version of Eagle and am looking at alternatives before I bite the bullet and buy a full version of Eagle.
Thanks!
David
- Group Buys
- Fast GB: LM4702 high power amp test board ;)
