Retro Amp 50W Single Supply
After a few hiccups, some good news..
I decided to give the board another run with the 1.6A 48V Sony SMPS tonight and it went well.
There is a 25KHz noise on the output shown on the 'scope but this is low amplitude so shouldn't be a problem.
Plugged in the test speaker (4 Ohm) for low power testing - there is an audible noise floor with no input connected. Definitely noticeable but I'll save that problem for later.
Played some music via my mobile phone and I have to say I was impressed by the clarity even through really terrible speakers and crocodile clips!
Once the enclosure arrives, I'll get it setup properly with shielded cables etc and give it a proper run with the 8 Ohm boxes.
:D
If you intend to use this amp without preamp with just 10k log pot at the input I suggest not to change the gain from the schematic. It works just fine.
Hi Ivan,
I reduced the gain on the amp purely on the simulated distortion being reduced by doing so. I intend to try 3.6k, 4.7k and the schematic 6.8k in R6 and see how it sounds for each.
I tried it out tonight with my mobile phone and 3.6k in R6 and it was sufficiently powered to get a feel for the sound without turning the phone volume up past 66%.
Hi all,
Success!!. It fired up without any trouble.
Transformer , a big hefty 400VA 2x 35VAC that I had.
On - board PSU used consisting of 2 rectifier diodes and 10kuF cap.
PSU voltage 53.7 V
Mid-point voltage - 27.6V
no hum or hiss or any kind., transistors and zobel cool.
bias set to 15mV across 0.33R emitter, so bias current is =45mA.
Sound: very nice, relaxed sound, although caps haven't been broken-in and only a single channel. Still using ordinary caps. When building stereo, I intend use good ones I have. Test speaker is a full ranger with Dayton reference series RS100-8, 4" in a 3.2 liter box, that was gathering dust (you can see;))
It seems on board PSU is sufficient to get a good sound without any hum. SO two channels of these and a transformer would make a compact amplifier with some other hardware like chassis and connectors thrown in.
attached: some pics and sound recorded thro mobile phone, so not good quality.
regards
Prasi
edit: o/p device MJL21194. pic shows how the bias diodes mounted to heatsink with kapton tape, forgot to put in heatsink blob. will do it with stereo build.
  • apex ax6_sound_rec.zip
Thanks guys,
yes, mine is dead silent either with no i/p connected and with i/p connected but not playing.
I dont think there is any difference in using 0.33R vs 0.47R, higher value could only help a tiny bit with bias stability.
I dont think negative of smps connection to chassis would help. Some other forum members might be able to tell which SMPS are good and have been used for audio w/o problems.
regards
Prasi
Hello Ivan,
As I mentioned I used a speaker with Dayton reference series RS100-8, which isnt super sensitive driver at 84.6dB.
I have another computer speaker thats quite sensitive, lets see if that brings up any hum issues to light.
I continued my listening for 2-3 hours into the night yesterday, have to say there is no need for tone control / bass adjustment. Its a pleasure to listen to. Thanks Mr. Mile for the circuit.
once built in stereo with good caps and a bit of break-in, I will put it on my floorstanders that go pretty deep. That would be a good test.
regards
Prasi
Yes, the factory is in Mumbai.
They still produce Peerless drivers. XLS Encore kit from GR-Research is based on Peerless drivers produced in India.
But somehow the general market availability of peerless drivers seems to have gone down in India.
diyaudiocart still has some drivers left.
My floorstandrs are based on their 6.5" woofer and a very good 1" silk dome tweeter.
