Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Output transformers for DACs
Thread Tools
Old 17th September 2020, 03:34 PM   #461
bisesik is offline bisesik  Kazakhstan
Originally Posted by beardman View Post
time to tell how the bisesik trafo play
my dac is JLsound AK4493,,with clock board and usb input
i have used 3 different output board
JLsound output board with Newclassd discrete opamp---absolute not bad
Mirand discrete output board---a little bit better
and now bisesik output trafo---by far the best
sound from the trafo..strong, dynamic,open,,nice for the ear,,lovely sound
i use the muting from JLsound output board,,so i have no click from the dac
well done bisesik
Best Bjarne
Thank you for your feedback!
Originally Posted by potstip View Post
Hello Ivan;
4493 needs Low pass filter after dac chip. With output transformer are we eliminate this? Or still we need it before or after transformer?
Hello Erkan,
Transformers have their own FR limitation, but in case of 1:1 transformer the LPF is a bit out from the desired ~70-80kHz and it is laying in the range over 120kHz I suppose. It is a theoretical things anyway, practice is more important. In general the answer depends on the particular setup. I do not use any additional LPF within my setup, as I hear details loss if I apply any capacitor across the output no matter what is the type of the DAC (R2R, delta-sigma, SDM). Using transformers of course. The best ever way for me is to use Ext2 filter in HQPlayer without any other LPFs (DAC is in the NOS-mode) as I do not know any other (HW-transports included) way to get the maximum from any DAC but HQP.
If you want to discover the impact of the additional LPFs I do recommend to read the Rasmussen' thread here on diyaudio forum. According to his research (if to be short) - it is needed to be at -0.7dB at 10kHz and -1.5dB at 20kHz. He recommended to use Zobbel network across the output. I have tried in the past to shunt with 1kOhm+nF(0.5nF to 5nF) to be at the needed points, but as I said earlier, HQP with Ext2 makes it much better and I do not use any extra LPF circuits.
Ivan
Old 23rd September 2020, 02:06 AM   #462
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Hi Ivan,
I have a little issue with the right channel output transformer for Ian's dual ES9038Q2M DAC. Seems like a high pitch ground loop on the right channel only (RCA). I swapped the cables left to right and the sound followed on the other channel. So I know it is the channel. I did solder the jumpers for RCA output and also removed the XLR jacks carefully due to space restrictions. What I don't know is if it is coming from the DAC board or the transformer board. I tried to separate the transformer output using ribbons but it didn't make any difference. Do you know what next I could check?
It is not loud and I have to be at 6-8 inches to hear it but I prefer silent to not lose micro details.
The transformer output sounds just amazing!
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | FSSA2 | MoFo | FC-100 | Modulus-686 | SimpelStark+ |
DACs : Mirand AK4490 + Discrete Output | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 23rd September 2020, 06:06 AM   #463
Hi Do,
Try to connect the right RCA's ground not at the j6 jumper, but on another point, under the grounding screw of the "Tr1 Left" transformer for example or even without grounding the right channel. I mean try to find another grounding point of the Right RCA please instead of j6. Thank you!
Ivan
Old 24th September 2020, 02:59 AM   #464
pinnocchio's Avatar
ok, I'll try playing with that. I will have to ground both RCA though as my amplifiers are all build in dual mono or mono-bloc.
Do
Old 24th September 2020, 06:56 AM   #465
Flikoman is offline Flikoman  Croatia
Any info on AD1865 implemetation?
Old 24th September 2020, 12:41 PM   #466
I suspect that you know a little more about me, than what I have said here on this forum.
1865 is my lovely-favourite DAC right now :-)
I believe there is no any chances to achieve such a resulting SQ rather than to use high-turns-ratioed transformers right after its I_out. OpAmps are just far-far away in this terms...
Ivan
Old 24th September 2020, 06:15 PM   #467
Did you make a transformer like that and tested it? I have AD1865 with AD825 opamp, sound is excellent, but would like to try with trafo.
Old 24th September 2020, 08:57 PM   #468
Yes I did. AD1865 have a weak current output compared to other DACs, that is why the best SQ possible is at level of 0.3-0.4Vrms out (after transformer) for AD1865 in SE-mode (regular stereo mode for single chip). Differential connection is better in that terms as 0.775V (0dBu) is a kind of standard for many (tube) amplifiers. The minimum load (input impedance of the next stage) should be 10kOhm as the turns ratio is 22.
Ivan
Old 25th September 2020, 04:22 AM   #469
Attachment 878269
0.3Vrms? That is pretty low. I don't think I have a preamp with about 10, 11x gain. It can be made, but ....
I'm interested still, but it is a kind of a risk ... what is the price?
Old 25th September 2020, 05:26 AM   #470
Just use higher i/v loading resistor (impedance) to be at the desired output level (1.4Vrms is possible). Price is the same - $170 for pair (without PCB).
Ivan
Output transformers for DACsHide this!Advertise here!
Thread Tools
PC based I2S Output for compatible DACs Vortex Digital Line Level 1 5th May 2018 08:37 PM
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 08:36 AM
D2A aragon dac with blowed output stage after the dacs... inertial Solid State 0 8th July 2013 05:04 PM
Differential output DACs, can I use only one output. oon_the_kid Digital Line Level 14 4th July 2011 03:09 AM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 05:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
