@WaltJ I can not find the part two what is called "A 1V Reference with Mirrors". Is this article available in the same website?
When will be your new advanced regulator schematic available that you were working on with some diyaudio members?
Next week I will try with some other opamps like OPA1611 to see if I will get it working on.
I missed that "coming" word. But it is good to know when then. I'm too impatient.you mean the one he says is "coming"
IE not yet available but keep an eye out for?
As promised, these are the most recently modified, added and/or updated RefsnRegs file(s) as of 5/16/24:
LEDs_as_Audio_Voltage_References_P2.pdf Part 2 of 2 parts. Smoke and mirror stuff for low noise in your audio reg.
Here is the URL: https://refsnregs.waltjung.org/LEDs_as_Audio_Voltage_References_P2.pdf
Enjoy, links within for contact.
Walt Jung
Walt Jung
You should have the P2 writeup now. It is not a new regulator, but a new reference for a lv regulator. If you are still having troubles, post your sch. Opa1611 looks like it wont work on 1v ref, but will on 2.5v.@WaltJ I can not find the part two what is called "A 1V Reference with Mirrors". Is this article available in the same website?
wj
is there any advantage of using a Current Feedback type of opamp in this project ? I already have a nicely working >5A version with ADA4898-1, but think about pushing it to the absolute limit, i.e. GLED431 , string of LEDs instead of zener, bulk foil resistor on feedback. Some photos for eye joy. last picture is FFT from my LCLC filter (14x3300uF Nichicon UKW 11mR ESR) under 5A step with 0.5A/us, and what Superreg output.
