Sons of VHex
This is the same schematic as published above (VHex-CP-V1.2-02 As Build). No changes, just cosmetics and better looking ... hope so. 🙂
Have a nice day,
Dan
  • VHex-CP-V1.2-02 As Build(170112).pdf
vSingle - a simple high-quality front-end
Hello All,
A very simple front-end desidn, based on the same principle, as the first VHex front-end. The critical, most non-linear piece is a single-transistor transconductance stage at the input (Q4). All the rest is driven by the current - highly linear current conversions.
Open loop 1KHz THD is less than 0.05%, with 40db NFB it comes down to 0.0005%, showing around 0.001% in combination with VHex+ OPS (2-nd picture is showing the Fourier analysis at 50W @ 8 ohm, +/-50V rails). 2-nd and 3-rd harmonics are dominant, all the rest are significantly lower.
Simple light compensation, good stability margins.
The VAS output stage can be easily adapted to any swing (OPS rails) - just adjust the value of R16 for having around 3mA through it.
PSRR is lower than the one, shown by the balanced designs, so I recommend to use regulated +/-15V supply (or at least having the good cap multipliers).
The layout is going to be rather simple - a good exercise for somebody who'd like to try 😉
Valery
Hello All,
Valery
A single side pcb will be useful
