100W Ultimate Fidelity Amplifier
Hi Rick,
I see that you say that those two 680R resistors measure alright but are they browned? Just because they still measure doesn't mean they didn't get hot. It might just be that the 47R went first before they got hot enough to fail. I can't find the schematic for the MK2. Double check that you have all the right transistors in the right place and that the layout matches the schematic. I can't think of anything else right now.
OK I see it. The layout comes from post#2095 which uses BC546. When Wiljj redid it he just changed the name of the part without changing orientation. If you inverted the 2N5551's it should work. I would re-flow all solder joints to make sure you don't have a cold joint.
A2
100W with OP and 2 outputs... just for fun.
Looks like you are getting closer. Is it -1.6V or -1.6mV? Unless the LTP pair are very imbalanced, you still have a problem. Did you match hfe the input pair?
What is the voltage drop across each of the two R22 emitter resistors? That will help to know the bias.
Thanks, Terry
