Vince:
Thanks -- I did look there but perhaps didn't dig deep enough. The funny thing is that I'd swear some of those unwanted entries are new.
Scott
Scott
Things like this make me wish there was some sort of documentation. Something beyond the brief faq/release notes.
Is it possible to change the background from black to something easier to read like white?
I successfully updated Daphile to the latest beta 25.04 from 24.06 using the firmware update feature in Daphile. It is running on a dedicated mini-pc. The Lyrion verion is updated to 9.03
Nice to hear)I successfully updated Daphile to the latest beta 25.04 from 24.06
Do you use UPnPBridge on Daphile with HQPlayer?
Just asked to be sure if it works ok like in previous 24.06
Thanks in advance
How do you pull a beta from the Daphile firmware updater? I tried updater today and nothing happened.
No. Several plugins including Qobuz work without problems.Do you use UPnPBridge on Daphile with HQPlayer?
- In the browser interface for Daphile go to http://192.168.xx.xxx/cgi-bin/Devel/ where 192.168.xx.xxxx is the IP of your Daphile player or server
- Select beta firmware option
- Place a Checkmark beside “Show R&D in main menu”
- Set “Firmware Source” to https://www.daphile.com/firmware/private-beta/
- Save R&D settings
- In the browser interface for Daphile go to http://192.168.xx.xxx/cgi-bin/Settings/ where 192.68.xx.xxx is the IP of Daphile.
- Check firmware
- Wait for the download and installation to complete, then reboot
- Verify version at Info.
Hi everyone. It's been a while since I used daphile last time. Now I am back and can't figure out how to use Tidal. Before it was possible through mySB, but it's gone now. I have installed the latest daphile beta and don't see any tidal plugin there. So what is the solution?
I think you need to search for " TIDAL local (v1.5.3 - 4102)" in the 3rd party plugins. I don't use Daphile anymore (running Docker container instead), but it should be the same for Daphile. You need to run LMS 9.x so check your version of LMs in Daphile.Hi everyone. It's been a while since I used daphile last time. Now I am back and can't figure out how to use Tidal. Before it was possible through mySB, but it's gone now. I have installed the latest daphile beta and don't see any tidal plugin there. So what is the solution?
Hi Everyone ! I am using Daphile with JCAT USB XE EVO card, and I am experiencing Interruptions in music. I have tryied to increase the buffer but it seems that will not help. Can you post here your setting please ( some settings that works )
Another question is : Did someone compared SQ differences when using wifi vs LAN ? Bacause in my oppinion there is no difference ...
That (sorry to say scam) card is a standard PCI-e USB controller, with some added filters (which a good externally-powered DAC will have no use of anyway). It works just like any other XHCI USB controllers, e.g. like that internally implemented in the chipset of your motherboard.I am using Daphile with JCAT USB XE EVO card, and I am experiencing Interruptions in music.
What is the character of the interruptions?
IMO you will need to go through some logs to troubleshoot the issue. System, dmesg, player logs, whatever is available through the daphile UI (or directly via SSH/console).
Why should the way incoming network stream is delivered to the player make an audible difference, apart of drop outs if the connection is not stable and the input cache runs out (more likely for wifi)?Did someone compared SQ differences when using wifi vs LAN ? Bacause in my oppinion there is no difference ...
The USB card is very sensitive to the external power suply, that I can tell you for sure ( I mean the Sound Quality, SQ )
How and why, I don't know, however, the card is not useless in my oppinion.
There are some small interruptions in sound. It's strange that sometimes a restart of Daphile solves the issue.
Every reasonable DAC has its own power supply, therefore the power from the USB host (the filter of which is so dearly paid in that card) is not used at all.The USB card is very sensitive to the external power suply, that I can tell you for sure ( I mean the Sound Quality, SQ )
If a DAC uses the USB power supply (unlikely except for the lowest-price DACs), then the option is a dirt-cheap USB Y split with external PSU option.
Another IMO the best option which also avoids ground loops (quite frequent with desktop PCs) is a USB isolator with separate power supply on the device side. While there are countless USB2 highspeed (480Mbps) isolators, most of them have noisy/weak DC/DC converters onboard. While these are easy to desolder, this board looks very nice https://www.ebay.com/itm/355964912542 - just feed clean 5V into the USB-C connector.
But it's your money.
Any issues in the logs?There are some small interruptions in sound. It's strange that sometimes a restart of Daphile solves the issue.
- PC Based
- Daphile - Audiophile Music Server & Player OS
