Daphile - Audiophile Music Server & Player OS
Light/dark theme:
Go to Settings, then bottom right corner.
Reactions: SRMcGee
How do you pull a beta from the Daphile firmware updater? I tried updater today and nothing happened.
Hi everyone. It's been a while since I used daphile last time. Now I am back and can't figure out how to use Tidal. Before it was possible through mySB, but it's gone now. I have installed the latest daphile beta and don't see any tidal plugin there. So what is the solution?
I think you need to search for " TIDAL local (v1.5.3 - 4102)" in the 3rd party plugins. I don't use Daphile anymore (running Docker container instead), but it should be the same for Daphile. You need to run LMS 9.x so check your version of LMs in Daphile.
