to TboneAK
Two possibilities for a linear regulated powersupply:
LV-Regulator
The σ11 regulated power supply
and many more....
Perhaps the DIYAudiostore could think about offering boards?
single polarity and a symmetrical one?
Greets
Dirk
LV-Regulator
and many more....
Greets
Dirk
Fixed Resisor Values
Hello Frank: If you know, I'd like to set-up the 6-24 as a sub/mains x-over:
LP/HP @ 45 Hz. (LR 24 db./octave).
Ideally, if I could have a gang-switch (4-6 position) to select 45,50,55, 60 and/or 80Hz that would make the 6-24 much easier to select/experiment with crossover frequency. Could that be incorporated/ in the 6-24 design?
If not, is there a slope calculator I could use to determine the (fixed) resistor values required for 45 Hz. LP/HP setting ?
Thank you,
pete
There are no dedicated test points. The 10k series resisters are directly above and below the pots so that gives you one end of each pot. For high pass there's a plated through hole next to P1 and for P2 you can use one end of the bias resister. For lo pass I used the caps but if you can't get under them you can use resisters leads too as you can see in the schematic.
Thank you,
pete
LV-Regulator
and many more....
Greets
Dirk
Dirk,
Thanks description of your psu's and for the links. I was digging through my stuff and stumbled on a pair of Simple Cap-Mx Regulated Low-Noise PSU from XRK-971. Impulse buy along with some other bits... Anyway I think one of these will do the trick.
Did you ever get your second 6-24 hooked up to a Subwoofer?
I'm planning a tri-amped, two boards, build. The third amp will be for a subwoofer and I am curious how it worked out.
The plan is: Board #1 would have a XO at say 100hz. The LP output signal would drive the sub amp. The HP output signal would feed the input of board #2. This would create a band pass between the two boards for the LF driver in my 2-way speakers. Correct?
I'm thinking that I could use a 3 pole, 2 position, 2 deck switch to switch board #1 in/out of the signal path to board #2. This wayI can remove Board #1 out of the signal path when the sub is not needed, and leave the LF drivers in my speakers with only the LP signal from board #2. It's not always "Dance Club" time at the house according to my wife.
Does this sound feasible?
to TboneAK
Hello TboneAK,
my second 6-24XO board is stuffed and ready to play. I bought a case
from Modushop Italy and some more stuff to complete the build. But it
is not finished yet. So the Subwoofer has to wait a little bit till it gets 'feed'
by the 6-24XO for sub.
Your idea with the switch between the two 6-24XO-boards should work.
And: are there really girls/wifes who don't like the 'danceclub'???
Greets
Dirk.
Hello TboneAK,
Greets
Dirk.
Hi Dirk,
My wife does indeed like the dance club idea, but doesn’t want the thump when it’s quiet time. That’s why I’m considering the switch. My 8” drivers do a good job, but I really like the sub sound when it’s disco time. Turn on the DJ light, fog machine and turn up the bass. We have one of these hanging in the corner, it’s a bit over the top.
Kinta FX | CHAUVET DJ
Looking forward to seeing how your build turns out. I’m in the planning stages right now. But will post some pics once I start building.
Tbone
Tbone
Thank you,
pete
Pete, What you want to do is certainly possible. I don't know of a calculator app where you put in the crossover point and get component values for the 6-24 design. Creating one would be similar to making the one we have.
I'd probably just try to zero in on the values by trial and error in the secret labs app or in microcap. Tedious I know, but once you get one the rest should be easy.
My Strategy for Adjusting the Filters
Expanding on my last post: Since Pete wants to use 24 dB/octave and Nelson says in the manual:
"... the classic L-R alignment will result from P2 potentiometers to be at around 1/2 the resistance of the other pots".
While that sentence my be open to interpretation I take it to mean that you can just run P2 from it's lowest value to half it's range and then set P1 to double that. Also, I believe both stages of a 24 dB/Oct LP or HP will be the same for maximum slope, so basically you can have just two variables to tweak. One for HP and one for LP. All the other R values follow.
I could be wrong in some of my assumptions so please correct me. I can say I successfully used the above method on my 6-24 when tested with REW. I'm waiting for my second amp before I can do listening tests.
Will the Super Regulator really do 24 V out?
super - regulators:
Also very, very nice are the super-regulators of Per Anders Sjöström.(diyAudio-member)
Going up to 24V. The SSR01 and SSR02 coming to my mind....
You can buy the bare pcb or readily finished.
SSR02 Sjostrom Super Regulator Built
Greets
Dirk
Greets
Dirk
I haven't been able to find a build guide for the DIY biamp 6-24 crossover. Nelson mentions that 6L6 was going to do one but I can't find it. Does one exist? I'm a novice builder so the project is daunting without more detailed instructions than a parts list and labels on a circuit board.
PaulInWA #654
Most important to read and understand (I hope you did?):
https://www.firstwatt.com/pdf/art_diy biamp_6-24_ crossover.pdf
Till now there is no pictured build guide. You can build this active crossover in so many ways (6- / 12- / 18-/ 24-dB-slope and you have to calculate your resistor- and cap- values (in the filters) on your own - for your special requirements = crossover points/range your speakers demand).
Greets
Dirk
Greets
Dirk
Still wondering how to translate the resistors R1 through R4 in the Mike Rothacher crossover program to P1 and P2 of the first stage and P1 and P2 of the second stage of the crossover. Is R1 = P1 first stage, R2 = P2 first stage, R3 = P1 second stage, R4 = P2 second stage. Have I got this right?
Also, see post 218, 596 & 597.Still wondering how to translate the resistors R1 through R4 in the Mike Rothacher crossover program to P1 and P2 of the first stage and P1 and P2 of the second stage of the crossover. Is R1 = P1 first stage, R2 = P2 first stage, R3 = P1 second stage, R4 = P2 second stage. Have I got this right?
Kind of confusing. The default values in the app have R1 half the value or R2, and so on... The manual recommends that P2 be "around" 1/2 P1 (at least for 24db/oct) so that's how I remember which is which. Note that the resisters in the app include the 10k series resister so it's not just the value of the pots -- Maybe that's part of the reason they aren't labeled P1 and P2... r1 and so on also seems to be the HTML/javascript variable names so there's that too...
So I think you have it, R1 = P1 and R3 = P1 and so on
translate NP-schematic to MRcalculator (6-24XO)
Hello 6-24XO-builders,
it seems that many builders are confused how to translate the part-numbers in
the schematic of Nelson Pass to the Mike Rothacher - calculator.
Believe me, I also was stretching my brain alittle bit.....
Please be patient with me, because I am not an electronic engineer and no teacher!
Let's start with a simple 6dB high pass filter (in the Nelson Pass-schematic):
And now the MRcalculator:
The value of R2 (MRcalc) corresponds to the value of P1(0 Ohm up to 50kOhm-how you adjust it) + the 10kOhm resistor (NPschematic).
If you adjust P1 to 12,5kOhm +the 10kOhm resistor inline you get 22,5kOhm (22500Ohm).
To make the confusion perfect:
In the MRcalc is the second stage bypassed = in the NelsonPass-schematic is
the first stage bypassed!
I hope I made no mistake!
Greets
Dirk
Greets
Dirk
- DIY biamp 6-24 crossover
