About possible Babelfish J interest
Official Court Jester
Joined 2003
well , since I forgot to instruct my amplifiers to reach melting and working temperature instantly , there is no use of puttin' da lid from start :rofl:
if possible , work one channel solo , then second channel
less things to take care of in same time
if you're not sure in things , better to read some tutorials around ....... even if some other amps are in question , there are similar general rules
and , I believe I already covered few things in this very thread
ask again , if needed
Joined 2003
So next on my list was to build proper preamp to match the babelfish j. I know this is bit OT, but do you have any suggestions? Should I look for tube or SS could also work OK?
beg 6L6 and boyz- for Iron Pre .... to put it ASAP in Store
or go berserk .... and go for Iron Pumpkin
:rofl: - I'm heavily biased
you have more than enough info in few related threads to make your own iteration , if you are eager to
So I've been playing babelfish for a few evenings already. Haven't tested it yet with pair of Monitor Audio bookshelves, rather connected it to DIY full-range Alpair speakers. Before I had these speakers connected to class T tripath chinese amp so obviously the first impression was "whoa! where all these sounds come from" :D Bass is so much more tighter, more pronounced. I can hear every single recorded detail. It brought Alpairs to next level, though I think the bottleneck switched to speakers now :))
Attaching few photos.. Still planning to get the front plate Babelfish J logo made, I think I seen it attached in this thread somewhere. Also need to allocate some proper space for the amp, otherwise it is serving now as good heater for the doggo.. :D
Thanks ZM again for help! With the amount of information around it is quite a good project for the beginners.
offset behavior
Dear all,
I had nothing to do this morning, so I checked the dc-offset of my Babelfish j, that I built about two years ago. That time the dc-Offset started at 800mV and sank to about 0 really slow.
Now it starts at 1,2 V and sinks as slowly as earlier to zero, as you can see in the diagram.
Will 1,2 V destroy the loudspeakers? What should I do to lower the initial offset?
Best regards, axel
