Amp Camp Amp - ACA
Indeed, I personally would believe the NRC measurements over the Audioholics measurements which do not show that trough.
But more importantly, the NRC shows you a "listening window" FR curve where you see on an overall sensitivity of 79-81dB @ 1m for this speaker. Since this was measured in an anechoic chamber there are no reflections. In a regular room you should get a few dB more. The impedance low is also 4 ohms at really one area (150-250 Hz), but everywhere else the impedance is higher. Phase angles are also benign as it should be with a 2 way. Bear in mind the output impedance of the ACA is > 2 ohms.
I'll be interested to see the UMIK-1 measurements and see how they compare, at least in > 300Hz area.
All a bit off topic, my apologies.
Best,
Anand.
The Boards have arrived....next weekend ACA should be playing music in my ears
Sent from my iPhone using Tapatalk Pro
Hi All,
I'm working on the PSU for my "ACA on Steroids" and I need some advice. Planning on using the standard Pass PSU topology, except set up as dual mono single-voltage supplies rather than a pos/neg supply. I've attached a schematic of my proposed PSU. I'm planning on using the components I have on hand, so the caps will be 5600uf Elnas, and the pi resistors will be 1.2R. Bleeder resistors will be 2.2K. A couple of questions:
1) What is the value of C9? Am I correct in interpreting that as 330uf?
2) Is it imperative to use CL60 thermistors, or will CL50 (7R) or CL70 (16R) work? Don't know if my local electronics store has CL60, but they might have the others.
Thanks,
Chuck
hi, @kpsthakur,
my acas only had the originally recommended 3300µF electrolytic cap (C1) but I always disliked the high frequency response. so after three years I thought it was time for a change.
The best electrolytic cap (I know of):>>http://de.rs-online.com/web/p/aluminium-elektrolytkondensatoren/1908911/<<
due to little space: one 10µF MKT:>>https://www.intertechnik.de/Shop/Frequenzweichenbauteile/Kondensatoren/MKT-axial-160-V/_MKTA10160_1768,de,7467,3876<<
and for smooth high frequency 0,47µF Tinfoil:>>https://www.intertechnik.de/Shop/Frequenzweichenbauteile/Kondensatoren/Audyn-Cap-KP-SN/_KPSN047250_1768,de,277,48479<<
all three in a parallel constellation acting as one cap.
the big sikorel cap had to be placed next to the pcb, wire connected, glued with silicone.
the acas are driven by my ba3fe clone and play exquisite with my 93dB Isophon Orchester 2000 from 1976 as well as less sensitive SMGA Magneplanars.
->amp pictures in the gallery
Troubleshooting no sound
I just built a pair of ACA's and I've got no sound coming from one, with 0V on Pin 2 of Q1. I've not had much luck (or enough patience?) with searching the forum for troubleshooting/testing steps. Any recommendations?
Thanks,
Jim
Duck: Gold plated pads (ENIG) on a pcb are harder to solder than tin plated pads. I pre-apply a little rosin flux (I think paste is the easiest to use) on the pad right before soldering.
For speaker binding posts, you need a larger soldering iron with a wide chisel tip for extra mass. I also melt a glob of solder on the end of the soldering tip to get a little more mass before soldering to large items.
Please try to scratch clean the pins, pads before soldering to remove oxidised layer, heat the pads using solder for 3-4 seconds before applying solder, solder will flow properly to heated pads and scratched pins probably called heat reflow method
