Pearl Two
.... I just use the SK170 and I like to try a substitute with higher Gfs.
This is the graph from 2sk170's datasheet. It shows a correlation between Idss and transconductance. Look at it carefully and be aware that 2sk170 comes in three Idss groups (GR, BL and V), ranging from 2.6mA to 20mA...
The World Is My Oyster lyrics
[Mostly instrumental]
The world is my oyster
Ha ha ha ha ha ........
Yeah yeah
Yeah yeah
Yeah yeah
Yeah yeah
Yeah yeah
Yeah yeah
:rofl:
Pearl Two Problem
Guys, just finished the pearl two using Pass boards and I have a problem.
Power supply is in a separate box. It checked out ok. But when I connect it to the circuit chassis strange things happen. On turn on things sound fine but within a couple of minutes the volume fades away.
When I checked out the voltages, the positive supply rail at R4 starts dropping from 24.06 volts to around 5.74 volts in about two minutes. The negative rail goes up to 62.1 volts.
This happens with both boards whether one or both are connected to the power supply.
Any suggestions? I have checked the layout and it looks ok. I'm not a techie so I'm a little lost.
Rudy
